POV-Ray : Newsgroups : povray.binaries.scene-files : Wind pattern code and reed stalk example Server Time
8 Oct 2026 20:48:43 EDT (-0400)
  Wind pattern code and reed stalk example (Message 1 to 25 of 25)
Subject: Wind pattern code and reed stalk example
Date: 19 Sep 2014 08:45:31
Message: <541c256b@news.povray.org>
Attached is my code. You have all latitude to make changes, experiment,
or expand.
Enjoy!
Download 'wind_pattern.zip' (75 KB)
Subject: Re: Wind pattern code and reed stalk example
Date: 19 Sep 2014 15:55:01
Message: <web.541c89c0825f35c27a3e03fe0@news.povray.org>
> or expand.
> Enjoy!
> Thomas
In the console there are a lot of lines:
File '/usr/share/povray-3.7/include/math.inc' line 232: Possible Parse Error:
Normalizing zero-length vector.
But, the render started.
Interesting work! :)
Download 'wind_pattern.jpg' (86 KB)
Preview of image 'wind_pattern.jpg'
Date: 20 Sep 2014 03:22:07
Message: <541d2b1f@news.povray.org>
I know but I don't know what to do about that. As far as I know I have
dealt with all zero-length vectors.
Anyway, they have no effect on the render.
Thanks! :-)
Date: 20 Sep 2014 10:05:00
Message: <web.541d885c825f35c27a3e03fe0@news.povray.org>
> Thanks! :-)
> Thomas
Thomas, anything I didn't understand in your files.
I would like to interpret it for Blender.
You can explain one after another, what it is necessary to do?
1 .
2 .
3 .
And so on :)
Thanks!
Date: 21 Sep 2014 04:27:59
Message: <541e8c0f@news.povray.org>
OK. How about this?
1. This technique uses the normals read at random locations on a
height_field to calculate the bending angle and orientation of reed
stalks as if they were blown by the wind.
2. Any height_field might do. However, a wave pattern is often observed
when watching corn or reed fields, so a height_field based on a ripple
or wave pattern will be most effective.
3. The first step is the creation of an image_map showing such a wave
pattern. This is done by setting parameter Mapping to 'on'. The code
provides a selection of settings but anything can changed until you get
an image satisfying to you. When this is indeed the case, you can set
parameter Mapping to 'off'.
4. Before going on, you will need one or more sets of reed stalks. Those
stalks need to be articulated following the Inverse Kinematic (IK)
procedure. This sounds more complicated than it is in reality when using
a modelling program. Just remember that each section of the stalk is
rotated /at the origin/ *and* /at its base/ and nested hierarchically
from extremity to base.
5. Now build a height_field using the wave pattern image_map. Play in
particular with the vertical scale of the height_field as this
influences the normals and hence the /strength/ of the wind to some degree.
6. To determine the random locations on the height_field, VRand_In_Obj()
is used as basis for the trace() function. This means that /any/ object
can be used to select the points. This can be useful to model irregular
reed fields with open patches of water for instance. In the provided
example, a simple box is used. The object can have any size but is only
effective when situated over the height_field of course.
7. A parameter WindStrength is provided to control the impact of the
wind on the bending of the reed stalks. Small amounts will already have
important effects, so be careful with this.
8. Provide the number of locations you need for filling the reed or corn
field.
Date: 21 Sep 2014 09:45:01
Message: <web.541ed590825f35c27a3e03fe0@news.povray.org>
> OK. How about this?
Thanks, I will understand.
I doubt that I will be able to study it. :(
Date: 21 Sep 2014 10:25:25
Message: <541edfd5$1@news.povray.org>
On 21-9-2014 15:41, LanuHum wrote:
>> OK. How about this?
Don't hesitate to ask if in doubt, though.
Date: 21 Sep 2014 11:40:01
Message: <web.541ef117825f35c27a3e03fe0@news.povray.org>
> > Thomas de Groot <tho### [at] degrootorg> wrote:
> >> OK. How about this?
> Thomas
Thanks!
Problem in English which I don't know.
I translate your messages, using an online translator of an intenet.
Therefore it is difficult to understand even an overall picture:
Why HF how HF influences mesh is used is a secret.
I still will try to study example.
Probably, time is necessary to understand.
I will ask questions if I will be able to start understanding though something.
Date: 22 Sep 2014 03:19:34
Message: <541fcd86$1@news.povray.org>
I think those are basic concepts, also in Blender?
The /normal/ of a point on a surface is the vector /perpendicular/ to
the surface (see also the Docs: paragraph 2.3.5.2). Using trace() you
can get the normal at a certain point. Knowing the normal, you can
calculate the angle it makes with a horizontal plane, or the angle it
makes with another vector around an axis.
Date: 22 Sep 2014 13:10:01
Message: <web.5420573b825f35c27a3e03fe0@news.povray.org>
> Thomas
Thomas,thanks.
I started understanding your mechanism.
But, I had an idea to use means of Blender (force field : wind) to do without
excess mathematical calculations.
Wind is applied to particles, but there is no realistic bend
It is necessary to find only the solution of a realistic bend of a trunk of a
plant also means of Blender
Download 'force_field_wind.jpg' (99 KB)
Preview of image 'force_field_wind.jpg'
Date: 22 Sep 2014 13:35:20
Message: <54205dd8$1@news.povray.org>
On 22/09/2014 18:07, LanuHum wrote:
> Thomas,thanks.
Just a suggestion LanuHum,
Can Blender apply wind to cloth?
Can you create a stalk as a "cloth" with only 2 degrees of freedom and
very stiff?
If so then you can apply "wind" to the "clothified"* stalk.
*Using Poser terminology.
Regards
Date: 22 Sep 2014 15:15:00
Message: <web.5420749d825f35c27a3e03fe0@news.povray.org>
Yes.
> very stiff?
I don't think that such option will be real for a large number of triangles. The
scene will be very heavy.
I am inclined to use only data, to process and write down the file
Date: 22 Sep 2014 15:40:49
Message: <54207b41@news.povray.org>
> Yes.
>> very stiff?
Fair enough. It was just a thought.
Keep up the good work. :-)
Regards
Date: 23 Sep 2014 03:17:08
Message: <54211e74@news.povray.org>
On 22-9-2014 19:07, LanuHum wrote:
> Thomas,thanks.
Ah yes, that is an idea. Like Stephen suggested, something Poser also
does. Only thing indeed is the bending.
It seems to me, looking at your image, that the rate of bending should
be inverted. What I mean is this: Now, the angle goes from high at the
start to gradually low towards the top, producing a concave-up bending
shape. Could you /invert/ the calculation for this? Thus making a
convex-up bending shape?
Alternatively, can you make the wind power in Blender to increase upwards?
Date: 23 Sep 2014 12:45:01
Message: <web.5421a2c0825f35c27a3e03fe0@news.povray.org>
> Thomas
If to use sphere_sweep probably it is possible to reach desirable result of a
bend.
It is necessary to study influence of several wind modifiers for increase in
wind power from above.
If the result is effective then it is necessary to think of leaves. :)
Download 'force_field_wind_render.jpg' (95 KB)
Preview of image 'force_field_wind_render.jpg'
Date: 23 Sep 2014 13:35:00
Message: <web.5421af2b825f35c27a3e03fe0@news.povray.org>
Now there are a lot of modifiers
Download 'wind.blend.jpg' (375 KB)
Preview of image 'wind.blend.jpg'
Date: 24 Sep 2014 03:59:42
Message: <542279ee$1@news.povray.org>
This is looking very good! Exactly how I think it should be.
Date: 24 Sep 2014 12:20:00
Message: <web.5422ee73825f35c27a3e03fe0@news.povray.org>
> Thomas
I develop leaves :)
Download 'wind_with_leaves.jpg' (104 KB)
Preview of image 'wind_with_leaves.jpg'
Date: 24 Sep 2014 13:19:47
Message: <5422fd33$1@news.povray.org>
>> Thomas
> I develop leaves :)
You do it well. Bravo!
Regards
Date: 24 Sep 2014 15:10:01
Message: <web.542316ad825f35c27a3e03fe0@news.povray.org>
> > I develop leaves :)
> Regards
>      Stephen
It only scheme (plan).
In high resolution it won't look good.
Besides, I used manual editing. For animation automatic process is necessary.
Date: 24 Sep 2014 18:50:38
Message: <54234abe$1@news.povray.org>
>>> I develop leaves :)
>> Regards
>>       Stephen
Yes
Proof of concept?
It can be done.
I have not used Forces nor animation in Blender, yet. Sounds like fun. :-)
Regards
Date: 25 Sep 2014 03:24:02
Message: <5423c312$1@news.povray.org>
>> Thomas
> I develop leaves :)
Look at that! You did it!
Date: 27 Sep 2014 09:23:07
Message: <5426ba3b$1@news.povray.org>
>> Error:
because sometimes <Norm> is equal to <0.000, 1.000, 0.000>
then, you caculate VerAng with :
	#local VerAng = VAngleD(<Norm.x, 0, Norm.z>, Norm);
first parameter become <0.000, 0.000, 0.000>
VAngleD use vnormalize that is not defined for a null vector.
and you get :
	Possible Parse Error: Normalizing zero-length vector.
you can, for exemple, correct this by adding smalls values to <Norm>
	#if ((Norm.x = 0.0) &  (Norm.z = 0.0))
		#local Norm = <0.0001, Norm.y, 0.0001>;
no visible difference in fact :)
Kurtz le pirate
Compagnie de la Banquise
Date: 27 Sep 2014 10:26:05
Message: <5426c8fd$1@news.povray.org>
> and you get :
>      #end
Simple and effective indeed. Thank you. I had difficulty in visualizing
what was exactly happening.
Date: 1 Oct 2014 04:29:05
Message: <542bbb51$1@news.povray.org>
LanuHum wrote on 24/09/2014 18.16:
>> Thomas
> I develop leaves :)
Very nices!
Paolo
