POV-Ray : Newsgroups : povray.binaries.scene-files : Simulated urbanism macro scene: version 2013.03.29 Server Time
9 Oct 2026 00:21:02 EDT (-0400)
  Simulated urbanism macro scene: version 2013.03.29 (Message 1 to 4 of 4)
Subject: Simulated urbanism macro scene: version 2013.03.29
Date: 29 Mar 2013 11:56:10
Message: <5155b99a@news.povray.org>
This is the latest version of the macro. See p.b.i. for example image
and discussion.
Download 'windows-1252' (16 KB)
Subject: Re: Simulated urbanism macro scene: version 2013.03.29
Date: 29 Mar 2013 15:56:36
Message: <5155f1f4@news.povray.org>
I haven't used this, but is there a specific reason why the macro
returns the result in a fixed variable name? If you simply write
union {
   object {HouseBlock}
   object {Single}
without #declare you can use the macro like this
#declare HouseBlock = Urbanism(
or like this
object
   Urbanism(...)
   textures {...}
Also there are some other uses of #declare in the macro
that are probably intended to be #local.
Not a criticisms, just a general observation that coding is
usually less confusing if something you call "returns a value"
as opposed to having "side effects".
Date: 30 Mar 2013 04:07:56
Message: <51569d5c$1@news.povray.org>
> union {
>    object {HouseBlock}
>    object {Single}
> or like this
> object
>    Urbanism(...)
>    textures {...}
You are perfectly right on this. No reason at all for my particular
choice ;-)
This is different. Those #declare are exchanged between the two macros.
#local does not work in that case.
Sure. However, I slightly prefer my method (your first comment) because
I like to have defined terms in my code most of the time.
Date: 30 Mar 2013 04:44:32
Message: <5156a5f0$1@news.povray.org>
Eerr... Apart from those, there are some more  #declare that could be
#local indeed ;-)
In due time. There will probably be more future changes...
