Version 7 is out! See my post in p.b.images for details.
Sam
Download 'lb7.zip' (21 KB)
I'm getting an "invalid or corrupted" error message...
Where are you getting this message? It sounds like the zip file is
corrupted, but I checked it with both Filzip and 7-Zip, and everything
seems fine.
Have you tried downloading it again?
> seems fine.
It seems to be a problem with Windows XP. Windows gives the same error message
for the hf_tools zip file. I'll give 7-zip a try. Thanks again!
Dave Blandston
7-zip opened the file. My guess is there's some proprietary formatting involved.
I'm excited to try out your code now.
Dave Blandston
> Regards,
> Dave Blandston
Apparently a 7-ZIPped ZIP,the archive should be extracted with 7-ZIP(7Z.EXE e
LB7.ZIP),& the result unzipped as usual. This applies also to Sam's
HF_TOOLS.ZIP.
Don't know why,but 7-ZIP's output(in both cases) is '[Content]',which I renamed
TMP.ZIP before using the excellent util ENZIP.
Tony Mayne
>> Regards,
>> Dave Blandston
> HF_TOOLS.ZIP.
> Tony Mayne
As you are using 7zip, make sure that you actualy output a ZIP file and
not a .7Z file.
I use IZArc, and it will correctly uncompress a valid archive even if it
don't have the right extention. It's quite possible that other utilities
may not be able to cope with a *.7Z file ranamed as *.ZIP. I think of
winzip, PKZip and the integrated windows zip support.
