Here is a zip containing files you may use to render the mandelbulb in
POV-Ray. It contains the following files, mbsdl_* for use with any
version of POV-Ray, and mb_* for use with a patched POV-Ray.
mbsdl_standalone.pov and mb_standalone.pov are minimal files with no
dependencies.
mbsdl.inc This is the include file used by all of the mbsdl_*
files below.
mbsdl_stage1.pov mb_stage1.pov Minimal files
mbsdl_basic.pov mb_basic.pov A mandelbulb isosurface colored by a
'bulb function
mbsdl_powers.pov mb_powers.pov Six mandelbulbs, powers 2-7
mbsdl_multi_p.pov mb_multi_p.pov Six composite power bulbs
mbsdl_pattern.pov mb_pattern.pov Use f_mandelbulb() as a pigment pattern
mbsdl_media.pov mb_media.pov Use f_mandelbulb() as a media density
mbsdl_renderall.sh mb_renderall.sh Bash scripts to render them all. (Linux)
There is also a long README.TXT, patches and replacement files to add
f_mandelbulb() internally, and a patch to extend the expiration of beta 34.
Download 'f_mandelbulb.010.zip' (57 KB)
Here are small anti-aliased images of each of the scene files.
Download 'mb_basic.png' (70 KB)
Download 'mb_media.png' (57 KB)
Download 'mb_multi_p.png' (50 KB)
Download 'mb_pattern.png' (52 KB)
Download 'mb_powers.png' (59 KB)
Download 'mb_stage1.png' (11 KB)
Download 'mb_standalone.png' (36 KB)
Preview of image 'mb_basic.png'
Preview of image 'mb_media.png'
Preview of image 'mb_multi_p.png'
Preview of image 'mb_pattern.png'
Preview of image 'mb_powers.png'
Preview of image 'mb_stage1.png'
Preview of image 'mb_standalone.png'
Here's the update. [I see the .binaries, so I should be OK.]
I incremented straight to 0.020 since the new function has one more
parameter than the old (making it incompatible with existing calls), a
phase parameter between p_phi and i.
I also put in a clunky way to switch between using the SDL and internal
function, if you compiled it into POV-Ray with the internal patch. Just
rename or remove the mbsdl.inc file and the sample scenes will switch to
using the internal function. I updated the README.TXT to try to explain
these and other mostly minor changes.
Also, I added another sample showing the four major variations. The
mb_variations.pov scene file is set to show the four power 8 variations,
but I also attached an image of the power two variants to highlight the
differences.
Happy 'Bulbing!
~David
Download 'f_mandelbulb.020.zip' (50 KB)
Download 'mb_variations.png' (35 KB)
Download 'mb2_variations.png' (34 KB)
Preview of image 'mb_variations.png'
Preview of image 'mb2_variations.png'
This looks an awful lot like a 3D version of the tricorn to me.
http://en.wikipedia.org/wiki/Tricorn_%28mathematics%29
It's made with the new function using a phase of 0, p_r=2, p_theta=-2,
p_phi=2 at ten iterations. (Note the negative p_theta.)
On another note, Paolo Bonzini recently published a paper describing how
to express the mandelbulb function variations as a quaternion function
mapping. I generalized his expression to work with any scalar power,
and besides being more flexible, it looks like it will be more
computationally efficient than the non-integral exponent versions of the
White, Nylander, et. al., formulae (the ones currently in use).
This quaternion version requires only 1 atan2, 1 cos, 1 sin, 2 sqrt, 1
fractional pow(), and 3 scalar divisions per iteration (along with a
bunch of fast multiplies and adds). Unfortunately, the expression
becomes extremely cumbersome when attempting to shoehorn it into a
single SDL function, so no working code yet.
I also plan to flirt with insanity by taking a crack at reworking it for
full quaternion power exponents.
~David
Download 'mb_iso_tricorn.png' (130 KB)
Preview of image 'mb_iso_tricorn.png'
Well, something cracked, all right. Since I had to recompile anyway, I
went ahead and coded a full quaternion power version. Once I worked out
the math (or more accurately, it worked me out), the resulting algorithm
isn't that much more computationally intensive than the old White and
Naylander formulas, and may even be a touch faster. (It would still be
too much to code in SDL unless I can learn how to build functions from
macros, or write an external script to make the SDL function.)
However, although it returns a reasonable straight power-two mandelbulb,
the current code doesn't seem to be doing higher powers quite right.
Regardless, what varying the imaginary parts of the quaternion power
does is indescribable.
There are much weirder 'bulbs than the one attached, but this (2,0,1,0)
quaternion power beast seemed appropriate for the new year.
Wishing ya'll the best!
~David Wagner
Download 'mbq2010_beast_512.png' (136 KB)
Preview of image 'mbq2010_beast_512.png'
Earlier, I blathered:
I found and corrected one error that only applied to using a power with
an imaginary part. I attached the 2,0,1,0 mandelquat after rendering it
with the updated code.
For pure real power mandelbulbs, I'm still only getting the expected
results for power two, and still don't know why.
~David
Download 'mbq2010_beast_640.png' (199 KB)
Preview of image 'mbq2010_beast_640.png'
Subject: Mandelquat Mapping (WAS: Happy 2,0,1,0 Quaternion-power 'Bulb!)
Date: 3 Jan 2010 23:40:45
Message: <4b41714d$1@news.povray.org>
waggy babbled on:
Bonzini updated his paper today, and my pure real power results are
consistent with his. The formulas needed to reproduce arbitrary real
higher-power mandelbulbs using quaternions are quite different than
originally described (except for power two, after trig reduction), and
seem to involve even more trig functions than the classic formulation.
http://github.com/bonzini/mbulb/raw/master/mbulb.pdf
There still may or may not be errors in how my code handles the
imaginary part of quaternion powers. I think I need to take a step back
and figure out what it's supposed to do rather than continue to muck
about with variations.
If there's interest, I'll post what I have so far. Otherwise, I'll hang
onto it until I can describe what it does.
~David
David,
If you would like to see how hyou can build functions with macros,
then below is a macro that produces a function that is similar to
your recursive (non-quaternion) Mandelbrot function.
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#macro MandelBulbFunction(R_Pwr, R_BO, Ph_Pwr, Ph_Phase, Th_Pwr, Max_Iter)
#local ln_R_BO = ln(R_BO);
#local ln_R_Pwr = ln(R_Pwr);
#local J = Max_Iter - 1;
#local MB_Fns = array[Max_Iter][2]
#local I = Max_Iter;
#while (I > 0)
#local I = I - 1;
#local MB_Fns[I][1] =
function(x, y, z, _r, _rp, _ph, _th) {
#if (I = J)
0
#else
select(
_r - R_BO,
MB_Fns[I+1][0](
x,
y,
z,
x + _rp*cos(_ph)*cos(_th),
y + _rp*sin(_ph),
z + _rp*cos(_ph)*sin(_th)
1/(I - ln(ln(_r)/ln_R_BO)/ln_R_Pwr)
#end // if
#local MB_Fns[I][0] =
function(x, y, z, _ix, _iy, _iz) {
MB_Fns[I][1](
x,
y,
z,
f_r(_ix, _iy, _iz),
pow(f_r(_ix, _iy, _iz), R_Pwr),
Ph_Pwr*(f_ph(_ix, _iy, _iz) + Ph_Phase),
Th_Pwr*f_th(_ix, _iy, _iz)
#end // while
function { MB_Fns[0][0](x, y, z, x, y, z) }
#end // macro MandelBulbFunction
// It can be used like this:
#declare MandelBulbFn = MandelBulbFunction(8, 3, 8, pi/2, 8, 5)
Tor Olav
http://subcube.com
Thank you very much!
All things considered, unless there is a big performance hit for some
reason, I'd prefer to use this method to build the user-defined function
at parse time. The recursive formulation always struck me as an odd way
to iterate, and povray crashing when the function is defined at the
"wrong" time is reason enough not to stick with it.
Besides, if the quaternion road leads somewhere fruitful, trying to
combine all the intermediate expressions by hand would be a nightmare.
With Great Appreciation,
~David Wagner
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmail com> wrote:
> [SNIP]
could you please make a pov file with that for all the newbies to learn from?
> > [SNIP]
Ok. See the attached pov-file.
But it may not be the easiest example for new users to learn from.
Note that if one want to see more details at higher powers,
then this smoothing expression should probably be changed:
Tor Olav
http://subcube.com
Download 'mandelbulb.pov.txt' (3 KB)
That is very nice, indeed, and far easier to read than my formulation.
It probably renders faster than my recursive SDL hack, too.
A few quick renders seems to indicate your formula may match one of the
bizarre "negative power" variations related to the tricorn fractal
rather than one of the standard mandelbulb functions. (You should still
be able to get the "classic" mandelbulbs by messing with the phase and
the signs of the powers.) I don't have time right now to examine it in
detail, but I would take a look at the use of the built-in f_ph() and
f_th() functions; they don't correspond directly to published mandelbulb
functions[1], nor to the conventional spherical coordinate system[2].
Plain old isosurfaces are tough for new users to tackle at all, and more
power to those that do!
Can you explain what you mean here, or post an example?
The smoothing function should not smooth the surface itself, it should
just decrease the actual max_gradient of the function and make it easier
for the root solver to find the surface. To get to higher iteration
surfaces, lower the isosurface threshold to a value closer to zero (from
1/2 as it is now to 1/3, 1/4, and so on to get more and more fractal
detail.)
~David
[1]
http://www.skytopia.com/project/fractal/2mandelbulb.html#formula
[2]
http://en.wikipedia.org/wiki/Spherical_coordinate_system#Coordinate_system_conversions
I messed with the f_mandelbulb internal function, squeezed about 10-15% better
performance out of it, and posted what I have so far below. (Note the handy
sincos() function in the standard library saving a couple of trig calls.)
Interestingly, I also found an additional 10-15% improvement in render time by
seriously overloading the processors with one to two hundred POV-Ray worker
threads on eight cores and using smaller render block size (16 for 640*360
images). I'm guessing the extra switching cost is more than offset by keeping
the floating-point pipelines full.
~David Wagner
DBL f_mandelbulb(FPUContext *ctx, DBL *ptr, unsigned int) // 79
{ // Coded by David Wagner, and based on
// Daniel White's original squaring formula,
// Paul Nylander's generalization and phi phase shift formulation,
// the Normalized Iteration Count Algorithm,
// and Abram Hindle's POV-Ray internal function patch.
DBL cx=PARAM_X, cy=PARAM_Y, cz=PARAM_Z;
DBL halfp_r = PARAM(0);// Radial power exponent.
DBL p_theta = PARAM(1);// Power of elevation theta.
DBL p_phi = PARAM(2);// Power of azimuth phi.
DBL phase = PARAM(3);// Phase shift of phi.
int i_bailout = PARAM(4);// Maximum number of iterations.
DBL r2_bailout = pow(PARAM(5),2);// Assumed divergence radius.
DBL x = cx, y = cy, z = cz;
DBL r2 = x*x + y*y + z*z;
DBL rp, sinpphi, cospphi, sinptheta, cosptheta;
int i=1;
halfp_r*=0.5;
while(i < i_bailout && r2 < r2_bailout) {
++i;
rp = pow(r2,halfp_r);
sincos(p_phi * atan2(z,sqrt(x*x + y*y)) + phase, &sinpphi, &cospphi);
sincos(p_theta * atan2(y,x), &sinptheta, &cosptheta);
z = cz + rp * sinpphi;
x = cx + cosptheta * rp*cospphi;
y = cy + sinptheta * rp*cospphi;
if (i < i_bailout) {
return 1/( i + log(log(r2_bailout) / log( r2))
/ (log(halfp_r)+0.693147180559945) );
}// ==log(2*halfp_r)
return 1/( i + log(log(r2_bailout) / log(1+r2))
Except that it is non-standard...
Thorsten
Your guess is wrong as long as you counted "cores" as the logical number of
cores seen by the operating system - including simultaneous multi-threading
capabilities your processor may have.
What you are most likely seeing is that your OS gives your application
slightly higher priority as a whole if it is running more threads, either
because it is designed to detect compute-heavy applications or because its
internal scheduling is on a thread rather than process basis.
Thorsten
> Thorsten
Ah, thanks. It's a GNU C extension. I'll make a note to guard its use
with a macro, and use an alternative with other compilers.
Google does not make it easy to find anything about sincos() since it
returns results for sin_cos (where _ is any or no character).
~David
>> 10-15% better
>> handy
AFAIK it's part of the C99 standard.
> of cores seen by the operating system - including simultaneous
> multi-threading capabilities your processor may have.
I'm counting the eight physical cores in the two quad-core AMD 2344 HE
sockets F on the motherboard.
> either because it is designed to detect compute-heavy applications or
> because its internal scheduling is on a thread rather than process basis.
Interesting. This is a on recent install of Ubuntu 9.10 Server Edition
with their "server" kernel. I'll do some better timing tests after I
set up another one of these boards headless.
~David
> >> 10-15% better
> >> handy
So far as I can find, Gnu[1], Intel, HP[2], and Sun[3] include sincos() in libm
for C99. It may take a bit more digging to sort out what compiler flags (if
any) are needed to use it with each of these. I haven't found an answer for
Apple.
~David
[1] http://linux.die.net/man/3/sincos
[2] http://docs.hp.com/en/5992-2854/ch09s12.html
[3] http://docs.sun.com/app/docs/doc/816-5172/sincos-3m?a=view
> Apple.
Well, at least with gcc if your program is C, then the compiler option
would be "-std=c99" (I really can't understand why that's not the
default). With C++ you could try "-std=c++0x".
