Subject: stack overflow excerption, see p.b.i
Date: 13 Feb 2003 07:09:39
Message: <3e4b8b03@news.povray.org>
scene file for povray.binaries.images "fish glass".
"stack overflow excerption" in POVray 3.5, Windows 98SE. No problems in
MegaPOV 1.
Dirk "DIRKO" Legler
On Thu, 13 Feb 2003 13:09:36 +0100, "Dirk \"DIRKO\" Legler" <dir### [at] dirko net>
> MegaPOV 1.
where ? :-)
ABX
*argh* I forgot to attach the scene-file..
INI-settings are standard from quickres.ini. It crashes in POVray and
doesn't crash in MegaPOV, no matter which settings I use from quickres.ini .
DIRKO
Download 'crash.pov.txt' (2 KB)
It's in this section
#version 3.5;
#declare Photons=off;
global_settings {
assumed_gamma 1.5
max_trace_level 500
I think you set max_trace_level too high, try a small value, and work up to
an acceptable level
Kruger
"Dirk "DIRKO" Legler" <dir### [at] dirko net> wrote in message
news:3e4b8b03@news.povray.org...
> MegaPOV 1.
> Dirk "DIRKO" Legler
Subject: Re: stack overflow excerption, see p.b.i
Date: 14 Feb 2003 11:38:16
Message: <3e4d1b78$1@news.povray.org>
Thanks! The level was that high because I got a black water surface before
setting it higher.. Now it's at 100 and everything works fine.. except that
there are some white/grey dots in the background..
DIRKO
"Kruger" <wal### [at] yahoo com> schrieb im Newsbeitrag
news:3e4c3b65$1@news.povray.org...
> #version 3.5;
> global_settings {
> assumed_gamma 1.5
> max_trace_level 500
to
> an acceptable level
> Kruger
> > MegaPOV 1.
> > Dirk "DIRKO" Legler
Date: 15 Feb 2003 02:30:17
Message: <3e4dec89@news.povray.org>
Hi Dirk
With ior=1.3 : crash
With ior=1.29 : don't crash
Philippe
"Dirk "DIRKO" Legler" <dir### [at] dirko net> a écrit dans le message de news:
3e4d1b78$1@news.povray.org...
that
> DIRKO
> > #version 3.5;
> > global_settings {
> > assumed_gamma 1.5
> > max_trace_level 500
> to
> > an acceptable level
> > Kruger
in
> > > MegaPOV 1.
> > > Dirk "DIRKO" Legler
Date: 15 Feb 2003 07:00:34
Message: <3e4e2be2@news.povray.org>
"Philippe_Gibone" <Ph.### [at] wanadoo fr> schrieb im Newsbeitrag
news:3e4dec89@news.povray.org...
> Hi Dirk
> Philippe
I solved it by decreasing the max_trace_level.
ior=1.29 would be wrong.. real ior is 1.33 so my ior already is wrong ;)
Can anyone explain why it doesn't crash just because of 0.01 difference?
DIRKO
well, I looked at POV help, and my best guess is it relates to the angle of
refraction. with a diferent angle, you would strick different areas inside
your bowl, and each time you hit it creates new rays. Well with a decreased
angle, I expect it doesn't get to an unstable number of trace levels. But
since you want a realistic refraction of the water stay with the ior=1.33
and tweek the trace level.
I'm sure others may have a better way of explaining this if I confused you.
Kruger
news:3e4e2be2@news.povray.org...
> > Hi Dirk
> > Philippe
> DIRKO
