POV-Ray : Newsgroups : povray.binaries.scene-files : fractal cubes for Yadgar (his work) Server Time
10 Oct 2026 06:37:11 EDT (-0400)
  fractal cubes for Yadgar (his work) (Message 1 to 3 of 3)
Subject: fractal cubes for Yadgar (his work)
Date: 10 Apr 2002 22:05:27
Message: <3cb4ef67@news.povray.org>
here is your source,
I tried to improve it for you.
K
Download 'Boxesfra.pov.txt' (4 KB)
Subject: Re: fractal cubes for Yadgar (his work)
Date: 13 Apr 2002 05:08:32
Message: <3CB7F62D.30A4DABB@tiscalinet.de>
High!
> K
I looked it up and tried it out... awesome! But how is it possible?
Shouldn't each new cb2 definition override the previous one?
Eager to learn,
Yadgar
Now playing: Chip Meditation (Software)
Date: 14 Apr 2002 00:47:44
Message: <3cb909f0@news.povray.org>
The new definitions do override.
but the order is important.
#declare cb2 = object
  union
    object{ cb }
    object{ cb2 scale 1/2.5 translate <1, 1, 1> }
    object{ cb2 scale 1/2.5 translate <1, 1, -1> }
    object{ cb2 scale 1/2.5 translate <1, -1, 1> }
    object{ cb2 scale 1/2.5 translate <1, -1, -1> }
    object{ cb2 scale 1/2.5 translate <-1, 1, 1> }
    object{ cb2 scale 1/2.5 translate <-1, 1, -1> }
    object{ cb2 scale 1/2.5 translate <-1, -1, 1> }
    object{ cb2 scale 1/2.5 translate <-1, -1, -1> }
POV creates the new object that is defined, before it assigns it to cb2.
it is like the statement.
a = a + 1;
a + 1   is figured out first, and the result is stored in a.
this is a very common statement in many computer programs (C++)
using this method, you should be able to easily add iterations (cut and
paste)
but be warned, that by doing that the number of cubes, will grow
exponentially, so will the time needed to render.
best of luck with you next projects.
K
"Yadgar" <yad### [at] tiscalinetde> wrote in message
news:3CB7F62D.30A4DABB@tiscalinet.de...
> High!
> > K
> Eager to learn,
> Yadgar
