Here is the scene file for an unrolling strategy I've had in mind for awhile. I
finally sat down and finished it. A sample of the results is in p.b.i. I didn't
implement this as a macro because of it's dependence on the camera. You really
need the whole scene file.
This can be useful for several things, but primarily the results can be used as
a background image in a paint program to help align texture details when
cylindrically or spherically mapping objects not supporting UV-mapping. You
could also use it to support uv-mapping 'in reverse' (so to speak) if you use it
as a target in an image morphing package (i.e. Hijaak Morph)
light_source{0,1}#macro c(J,a)sphere{0,1pigment{rgb z}scale a translate J+O}
#end#macro B(R,V,O)c(0,4)intersection{c(V,R)difference{c(-z*4x+10)c(-z*4.1x+
10)c(0<7.5,45,5>)}}#end B(12,0z*25)B(8y*4<0,12,50>) // Batronyx ^"^
On Thu, 10 Jan 2002 07:38:07 -0600, "Batronyx" <bat### [at] alliancecable net>
where exactly ? ;-)
ABX
awhile. I
You forgot the attachment. But I had the same idea yesterday and I'm glad I
don't have to do everything myself. :o) I suppose it works only with
triangles?
Hugo
DOH!
Sorry! I was trying to get these posted before I dashed off to work this
morning.
Just as well I suppose since I also forgot to mention something:
The scene file has a generic reference to a "Wrapobject" rather than the skull I
posted in p.b.i. You should of course supply your own object to unwrap.
Download 'unwrap.pov.txt' (3 KB)
"Hugo" <hua### [at] post3 tele dk> wrote in message news:3c3d9e12@news.povray.org...
Sorry about that. I just posted it with the attachment.
>I suppose it works only with triangles?
No. It should work with just about any object already suited to cylindrical or
spherical mapping. The method is quite uncomplicated and should be very easy to
modify to suit similar purposes ( i.e. unwrap top-to-bottom ).
Sorry, what is the exact syntax for the object in the Wrapobject field? How
would put, say, a sphere with an image map?
And you have a "t" missing in image_height.
Thanks,
D.
"Batronyx" <bat### [at] alliancecable net> wrote in message
news:3c3e3c4d@news.povray.org...
> DOH!
> morning.
skull I
J+O}
> #end#macro
Your program is very nice, thank you! I can't imagine a better way to do it,
with pov. But I'd like if you explain how to make it work all the way
through. I found out how to unroll my object. It's just that putting the
texture back causes much trouble. It doesn't fit.
Hugo
I think I finally got it to work! :o) I will experiment more with it. Btw,
to avoid black dots in the unrolled surface, I took the camera a bit off
zero. Location is then <.00001,.00001,-1000>
Seems like a nice feature you've given us ... thanks Batronyx!!
Hugo
"Dennis Milller" <dhm### [at] mediaone net> wrote in message
news:3c3fafd2$1@news.povray.org...
> Thanks,
> D.
Sorry about the "t" :(
<sdl>
#declare MySphereObject =
sphere{ 0,1
pigment{image_map { png "test.png"
map_type 1 interpolate 2 }
#declare Wrapobject = MySphereObject
finish{ambient 1}
Center_Trans(Wrapobject, x+y+z)}
</sdl>
the confusion may have come from the "WrapTex" which isn't really used anywhere.
It is just there as a suggestion so that you could do this if you want:
<sdl>
#include "fancyobject.inc"
#declare Wrapobject = MyFancyObject
texture { Wraptex }
</sdl>
Hope that helps.
"Hugo" <hua### [at] post3 tele dk> wrote in message news:3c40a81c$1@news.povray.org...
Well good! Because I just now saw both posts and I wasn't sure what your problem
was exactly :)
> Btw, to avoid black dots in the unrolled surface, I took the camera a bit off
Thanks for the tip. You know I should have known this anyway. It's been
suggested in the docs since v2.2.
You're more than welcome. I'm glad you find it useful. :)
Hi. I changed your code to:
sphere{ 0,1
pigment{image_map { tga "d:\me\me001.tga"
//finish{ambient 1}
and when I try to render it, first I get an error on the finish line. When I
comment that out, I get an error in transforms.inc, line 116:
transform {translate -Axis*((Mx - Mn)/2 + Mn)}
the error says:
"Expected object or directive; transform found."
Any suggestions?
thanks,
D.
news:3c4112f9@news.povray.org...
How
> > Thanks,
> > D.
> <sdl>
> sphere{ 0,1
> finish{ambient 1}
> </sdl>
anywhere.
> <sdl>
> texture { Wraptex }
> </sdl>
> Hope that helps.
J+O}
> #end#macro
> file://finish{ambient 1}
As far as I'm aware, you can't declare an object + finish like that.. Put an
object { } wrapper around them.. Concerning the transformation error, I
haven't got that line to work either, so I comment out Center_Trans.. The
line is not necessary if your object is already at origin, which would be
the case most of the time.
If you get further errors (not likely, but...) it could be that a variable
somewhere in Unwarp.pov has already been declared as another type of
variable in your scene file (or in an include file, that you use in your
scene file).. For example, if you have a line that #declares A=30; you
can't afterwards do function (A) { x+a } because Pov doesn't allow A to be
declared twice in that way.. So use #local variables whenever you can or
#undef them when nolonger needed.
Maybe you knew this already, but... :o) I just typed it...
Hugo
news:3c424087$1@news.povray.org...
> sphere{ 0,1
> //finish{ambient 1}
In both cases it is because, as Hugo has pointed out, I forgot to use the proper
syntax. That's what I get for doing things in a hurry. Try this;
#declare Wrapobject = object{
MySphereObject
finish{ambient 1}
}//end object
The above syntax is allowed for pigments, but if for some reason this doesn't
work, put a texture{} wrapper around the finish statement.
I've been using PoV since 2.2, and I still don't always remember syntactic
things. 95% of the time, I just keep the help file open for reference. You may
want to consider this. Especially if your depending on me :D
"Hugo" <hua### [at] post3 tele dk> wrote in message news:3c42a240@news.povray.org...
Thanks for catching my syntax error. Your problem with the Center_Trans macro
may be to another of my mistakes; Do you see the unmatched closing brace at the
end of the line? It would of course disappear when you comment/delete that line.
Also, it isn't enough for your object to merely encompass the origin, it must be
precisely centered or the FitScaleY transform won't behave properly. You may
have meant that . . . but . . .I wrote it :D
Nope, that didn't work. I don;t understand - does this same code work on
your machine?
d.
MySphereObject
texture { finish{ambient 1} }
}//end object
news:3c43b124$1@news.povray.org...
> > sphere{ 0,1
> > //finish{ambient 1}
When I
proper
> MySphereObject
> finish{ambient 1}
> }//end object
doesn't
may
J+O}
> #end#macro
