![](/i/fill.gif) |
Wasn't it J?rg 'Yadgar' Bleimann who wrote:
>High!
>Since about two months I'm fiddling around with a PoV script to place
>randomly distributed objects on a plane without
>overlappings... as long as I restrained myself to spheres, it worked
>very well, even with random radii, but as I started to
>check random cubes for overlappings, the problems began.
>I'm pretty sure that the collision condition stated in lines 112 and 113
>is incomplete, as it checks only for the x and z
>coordinates of the lower left front corner and the upper right back
>corner, whereas the left back and right front corners
>should also be taken into consideration.
That's easy to do, you just add the tests for the other two corners
>But regardless of that, the condition even as it is now never becomes
>true - the warning statement given in line 114 is never
>displayed! What did I wrong?
As soon as you find one box that doesn't overlap you #define cflag=0
which causes you to jump out of the loop, so you ended up only testing
against the very first box. The code that was commented out, using a
second cflag2 control variable was nearly right except that it should
have been initially set to 0, not 1.
Here are the relevant lines corrected (German comments removed to
prevent line wrap)
#declare cflag2=0;
#declare b=0;
#while (b<a & cflag=1)
#if ((((objs[b][0]<objs[a][0]) & (objs[a][0]<objs[b][2]))
& ((objs[b][1]<objs[a][1]) & (objs[a][1]<objs[b][3])))
| (((objs[b][0]<objs[a][2]) & (objs[a][2]<objs[b][2]))
& ((objs[b][1]<objs[a][3]) & (objs[a][3]<objs[b][3])))
& ((objs[b][1]<objs[a][1]) & (objs[a][1]<objs[b][3]))))
#warning "Error! Cubes overlapping!"
#declare c=c+1;
#declare cflag2=1;
#else
//#declare cflag=0;
#declare c=0;
#declare b=b+1;
#if (cflag2=0)
#declare cflag=0;
Unfortunately, this still isn't quite sufficient, because it is possible
for cubes of different sizes to overlap without any corners of [a] being
inside [b]. There's an example in the upper left where a grey box [a]
lies on top of a red box [b].
For as complete check you can do this:-
#declare cflag2=0;
#declare b=0;
#if ((objs[b][2]>objs[a][0]) & (objs[b][0]<objs[a][2])
& (objs[b][3]>objs[a][1]) & (objs[b][1]<objs[a][3]))
#declare c=c+1;
#declare cflag2=1;
#else
//#declare cflag=0;
#declare c=0;
#declare b=b+1;
#if (cflag2=0)
#declare cflag=0;
Mike Williams
Gentleman of Leisure
![](/i/fill.gif) |
![](/i/fill.gif) |
news:3F08B04A.5FC5BAB8@tiscalinet.de:
> High!
Low !
I see that Mike has already replied to you question.
Below is my rewrite of your script (if you're interested).
And further below there is another version which uses POV-
Ray's "built in" 3D-vectors more extensively.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version 3.5;
#default {
finish {
ambient color White
diffuse 0
#declare NrOfSquares = 150;
#declare MaxErrors = 4000;
#declare FrameSizeX = 3;
#declare FrameSizeZ = 5;
#declare OffsetX = -2;
#declare OffsetY = 0;
#declare OffsetZ = 3;
#declare SizeMin = 0.2;
#declare SizeMax = 0.4;
#declare Seed = seed(400);
#declare High = max(FrameSizeX, FrameSizeZ);
#declare SizeScope = SizeMax - SizeMin;
#declare Cubes = array[NrOfSquares][4]
#declare CubesHeights = array[NrOfSquares]
#declare IminX = 0;
#declare IminZ = 1;
#declare ImaxX = 2;
#declare ImaxZ = 3;
#declare ErrorCnt = 0;
#declare TryCnt = 0;
#declare A = 0;
#while (A < NrOfSquares & ErrorCnt < MaxErrors)
#declare Error = true;
#while (Error & ErrorCnt < MaxErrors)
#declare CubesHeights[A] = SizeMin + rand(Seed)*SizeScope;
#declare Cubes[A][IminX] = OffsetX + rand(Seed)*FrameSizeX;
#declare Cubes[A][IminZ] = OffsetZ + rand(Seed)*FrameSizeZ;
#declare Cubes[A][ImaxX] = Cubes[A][IminX] + CubesHeights[A];
#declare Cubes[A][ImaxZ] = Cubes[A][IminZ] + CubesHeights[A];
#if (
Cubes[A][ImaxX] <= OffsetX + FrameSizeX &
Cubes[A][ImaxZ] <= OffsetZ + FrameSizeZ)
#declare Error = false;
#end // if
#declare TryCnt = TryCnt + 1;
#debug
concat(
"\n",
str(TryCnt, 1, 0), ". attempt to place the ",
str(A + 1, 1, 0), ". cube. "
#if (Error)
#declare ErrorCnt = ErrorCnt + 1;
// #debug "--> Result: Cube outside frame."
#end // if
#end // while
#if (!Error & A > 0)
#declare B = 0;
#while (!Error & B < A)
#if (
Cubes[A][IminX] < Cubes[B][ImaxX] &
Cubes[A][IminZ] < Cubes[B][ImaxZ] &
Cubes[A][ImaxX] > Cubes[B][IminX] &
Cubes[A][ImaxZ] > Cubes[B][IminZ])
#end // if
#declare B = B + 1;
#end // while
#if (Error)
// #debug "--> Result: Cubes overlapping."
#end // if
#end // if
#end // while
#if (!Error)
#debug "--> Result: Cube plazed !\n"
#end // if
#declare A = A + 1;
#end // while
#declare NrOfSquares = (Error ? A - 1: A);
#debug "\n"
#debug "\n"
#debug concat ("Number of cubes placed: ", str(NrOfSquares, 0, 0))
#debug "\n"
#debug concat ("Number of errors: ", str(ErrorCnt, 0, 0))
#debug "\n"
#debug "\n"
#declare A = 0;
#while (A < NrOfSquares)
box {
<Cubes[A][IminX], 0, Cubes[A][IminZ]>,
<Cubes[A][ImaxX], CubesHeights[A], Cubes[A][ImaxZ]>
pigment { color rgb <rand(Seed), rand(Seed), rand(Seed)> }
#declare A = A + 1;
#end // while
#declare vOffset = <OffsetX, OffsetY, OffsetZ>;
#declare W = High/100;
#declare pA = -<W, 0.00, W>/2;
#declare pB = <W, 0.02, W>/2;
union {
box { pA, pB + FrameSizeZ*z }
box { pA, pB + FrameSizeZ*z translate FrameSizeX*x }
box { pA, pB + FrameSizeX*x }
box { pA, pB + FrameSizeX*x translate FrameSizeZ*z }
translate vOffset
pigment { color Blue }
background { color White }
orthographic
location <FrameSizeX, High*4, FrameSizeZ>/2
look_at <FrameSizeX, 0, FrameSizeZ>/2
translate vOffset
angle 40
#version 3.5;
#default {
finish {
ambient color White
diffuse 0
#declare NrOfCubes = 400;
#declare MaxErrors = 10000;
#declare vFrameSize = <5, 0, 4>;
#declare pOffset = <-2, 0, 3>;
#declare SizeMin = 0.1;
#declare Seed = seed(314);
#declare High = max(vFrameSize.x, vFrameSize.z);
#declare Cubes = array[NrOfCubes][2]
#declare Imin = 0;
#declare Imax = 1;
#declare A = 0;
#while (A < NrOfCubes & ErrorCnt < MaxErrors)
#declare Cubes[A][Imin] =
pOffset + vFrameSize*<rand(Seed), 0, rand(Seed)>;
#declare Cubes[A][Imax] =
Cubes[A][Imin] + <1, 1, 1>*(SizeMin + SizeScope*rand(Seed));
#if (
Cubes[A][Imax].x <= pOffset.x + vFrameSize.x &
Cubes[A][Imax].z <= pOffset.z + vFrameSize.z)
#end // if
#debug
concat(
"\n",
#if (Error)
#end // if
#end // while
#declare B = 0;
#if (
Cubes[A][Imin].x < Cubes[B][Imax].x &
Cubes[A][Imin].z < Cubes[B][Imax].z &
Cubes[A][Imax].x > Cubes[B][Imin].x &
Cubes[A][Imax].z > Cubes[B][Imin].z)
#end // if
#declare B = B + 1;
#end // while
#if (Error)
#end // if
#end // if
#end // while
#if (!Error)
#end // if
#declare A = A + 1;
#end // while
#declare NrOfCubes = (Error ? A - 1: A);
#debug "\n"
#debug "\n"
#debug concat ("Number of cubes placed: ", str(NrOfCubes, 0, 0))
#debug "\n"
#debug "\n"
#debug "\n"
#declare A = 0;
#while (A < NrOfCubes)
box {
Cubes[A][Imin], Cubes[A][Imax]
#declare A = A + 1;
#end // while
#declare W = High/200;
union {
box { pA, pB + vFrameSize*z }
box { pA, pB + vFrameSize*z translate vFrameSize*x }
box { pA, pB + vFrameSize*x }
box { pA, pB + vFrameSize*x translate vFrameSize*z }
translate pOffset
orthographic
location 2*High*y
look_at 0*y
translate pOffset + vFrameSize*(x + z)/2
angle 40
![](/i/fill.gif) |
