POV-Ray : Newsgroups : povray.binaries.scene-files : Capriccio v.12 Server Time
10 Oct 2026 01:37:11 EDT (-0400)
  Capriccio v.12 (Message 1 to 4 of 4)
Subject: Capriccio v.12
Date: 27 Apr 2003 21:57:29
Message: <3EAC88B7.A2991B2C@mail.com>
Add files from this archive to capriccio11.zip
Gena.
Download 'capriccio12.zip' (557 KB)
Subject: INI file for Capriccio
Date: 29 Apr 2003 11:26:23
Message: <3eae999f@news.povray.org>
There needed to be an easier way to choose render settings.
The vertical resolutions are matched up with common ones, aspect ratio
determines width. I just rounded the decimal number I got, up or down.
Make any changes you feel it needs. Check on the Library_Path lines, of
course.
Download 'CAPRICCIO.INI.txt' (2 KB)
Subject: Re: INI file for Capriccio, take two
Date: 29 Apr 2003 18:11:00
Message: <3eaef874@news.povray.org>
An afterthought...
That 413X512 resolution might as well be replaced with:
[484X600 Low Quality]
Width=484
Height=600
Antialias=off
Quality=7
[484X600 Medium Quality]
Width=484
Height=600
Antialias=on
I hadn't realized until after I posted the file that I left out 800X600
displays. The 413 by 512 pixels was only to use a certain size I could see
well enough, not based on an actual display resolution. Funny thing that I
left out the most commonly used one, sorry.
I'll go ahead and attach that file again with the change, it's such a small
file.
Bob Hughes
Subject: Changes for the stairs
Date: 4 May 2003 17:13:44
Message: <3EB58288.FC6511F5@gmx.de>
first version, will probably work on the displacement function and the
textures.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Download 'capriccio13.zip' (7 KB)
