// Persistence of Vision Ray Tracer Scene Description File
// File: Geo_stuff.pov
// Vers: 3.1
// Desc: to build a #macro aimed to construct smooth gear_like shapes.
// Date: october, 23-24, 2001
// Auth: Pilot Alex
global_settings {
assumed_gamma 1.95
#macro Geo_flower (
rad_whole_thing, // define the radius of the whole shape
step_num, // ...how many pos_neg curved segments inside a 360
// it allows a range of possibilities from 2 to "any logical
number"!
line_thickness, //
// smoother, // it should be kept between 0 and 70
// I removed this keyword, so that its part of the code,
// cause it is not working properly //
circonf // does the shape do a complete 360, or only a 270,
etc...
surface ) // texture
#local steps = step_num;
#local rot_sampl = 360/(steps*2);
#local x1 = rad_whole_thing;
#local y1 = 0;
#local x2 = x1*cos(radians(rot_sampl));
#local y2 = x1*sin(radians(rot_sampl));
#local tor_rad = (sqrt(pow(x1-x2, 2)+pow(y1-y2, 2)))/2; //it gives
the rad...
#declare part_tobe_duplicated =
union {
difference {
torus { tor_rad, line_thickness translate x1*x
difference { plane { +x, 0 } plane { +z, 0 }
rotate < 0, -rot_sampl/2, 0 >
translate x1*x
difference { plane { +x, 0 } plane { -z, 0 }
rotate < 0, +rot_sampl/2, 0 >
translate x1*x
difference {
rotate -rot_sampl*y
plane { -x, 0
rotate < 0, (-rot_sampl/2), 0 >
translate x1*x
plane { -x, 0
rotate -(rot_sampl/2)*y
translate x1*x
rotate -rot_sampl*y
texture { surface }
#declare final_obj = union {
#local counter = 0;
#while ( counter < circonf )
object { part_tobe_duplicated
rotate < 0, -counter, 0 >
#local counter = counter+(360/steps);
object { final_obj
rotate -90*x
#declare surf_testing =
texture { pigment { Gray90 } finish { ambient 0.2 brilliance 1.5
specular 0.75 }}
object { Geo_flower ( 5, 3, 0.3, 360, surf_testing )
translate < 0, 0, 0 >
// #macro allowing to move a camera around any xyz vector...
// The xx, yy, and zz are the vector components of the new center
point....
// The "back" keyword is the distance of the cam from the
center_point...
// ...rot_adjust allow to be more specific with the reel focus area....
#macro flying_cam ( lens, xx, yy, zz, back, x_rot, y_rot, xrot_adjust,
yrot_adjust, y_trans )
#declare cam_2001 =
camera { location < 0, 0, -1 > look_at 0.000 angle lens
rotate xrot_adjust*x rotate yrot_adjust*y
camera { cam_2001
translate <0,y_trans,-back>
rotate <x_rot, y_rot, 0>
translate < xx, yy, zz >
flying_cam ( 30, 0, 0, 0, 40, -15, -30, 0, 0, 0 )
light_source { < 200, 200, -400 >, White*1.15 }
/////////// E N D O F T H I S C O D E ///////////////////////
