Below is the source code for an image I posted 27. May to the
povray.binaries.images news group.
Tor Olav
// ===== 1 ======= 2 ======= 3 ======= 4 ======= 5 ======= 6 ======= 7
// Copyright 2000 by Tor Olav Kristensen
// Except for the code for the DiamondTexture and the DiamondInterior
// which I borrowed (and modified) from the posting Sigmund Kyrre Aas
// made to this news group; povray.binaries.scene-files, 26. May 2000:
// "Brilliant diamond".
// mailto:tor### [at] hotmail com
// http://www.crosswinds.net/~tok/tokrays.html
#version 3.1;
global_settings {
ambient_light 0.5
max_trace_level 30
#macro Tilt(Thing, Vector)
#local xAngle = degrees((Vector.z < 0 ? -1 : 1)*
acos(vnormalize((x + z)*Vector).x));
#local yAngle = degrees(acos(vnormalize(Vector).y));
object {
Thing
rotate xAngle*y
rotate -yAngle*z
rotate -xAngle*y
#end // macro Tilt
#macro MCircleSpread(Thing, Radius, NrOfThings, Start)
#local dAngle = 360/NrOfThings;
#local Angle = Start*dAngle;
#local Cnt = 0;
#while (Cnt < NrOfThings)
object {
Thing
translate Radius*x
rotate Angle*y
#local Angle = Angle + dAngle;
#local Cnt = Cnt + 1;
#end // while
#end // macro MCircleSpread
#declare cR = 1.4; // To adjust the brightness of pigment
#declare RedPigment =
granite
turbulence 0.4
color_map {
[ 0.0 rgb <0.6, 0.1, 0.1>*cR ]
[ 0.8 rgb <0.3, 0.0, 0.0>*cR ]
[ 0.8 rgb <0.6, 0.1, 0.1>*cR ]
[ 1.0 rgb <0.2, 0.0, 0.0>*cR ]
#declare DiamondTexture =
color rgbf <0.81, 0.81, 0.8, 0.8>
finish {
ambient 0.01
diffuse 0.4
#declare DiamondInterior =
interior {
caustics 1
ior 2.417
fade_power 1000 // Experiment with
fade_distance 80 // these values
// Also try other numbers here
#declare FacetSides = 8; // This will make 8*9 + 2 = 74 facets
#declare Brilliant =
intersection {
plane { y, 0 }
MCircleSpread(plane { y, 0 rotate -27*z }, 3.00, FacetSides, 1/2)
MCircleSpread(plane { y, 0 rotate -42*z }, 3.25, FacetSides, 0 )
MCircleSpread(plane { y, 0 rotate -47*z }, 3.62, FacetSides, 1/4)
MCircleSpread(plane { y, 0 rotate -47*z }, 3.62, FacetSides, 3/4)
MCircleSpread(plane { y, 0 rotate -90*z }, 6.20, FacetSides, 1/4)
MCircleSpread(plane { y, 0 rotate -90*z }, 6.20, FacetSides, 3/4)
MCircleSpread(plane { y, 0 rotate -135*z }, 9.10, FacetSides, 1/4)
MCircleSpread(plane { y, 0 rotate -135*z }, 9.10, FacetSides, 3/4)
MCircleSpread(plane { y, 0 rotate -137*z }, 9.43, FacetSides, 0 )
plane { -y, 8.2 }
bounded_by { cylinder { 0.1*y, -8.3*y, 6.20/cos(pi/FacetSides) } }
#declare Diamond =
object {
Brilliant
interior { DiamondInterior }
texture { DiamondTexture }
#declare DimLight = light_source { -3*y, color White*0.15 }
#declare NrOfStringLights = 9;
#declare LightString = // Lights to be put inside diamond
union {
#declare Cnt = 0;
#while (Cnt < NrOfStringLights)
object { DimLight translate -(Cnt + 0.1)*y }
#declare Cnt = Cnt + 1;
#end // while
#declare NrOfRingLights = 8;
#declare LightRing = // Can be used instead of LightString
union {
MCircleSpread(DimLight, 1, NrOfRingLights, 0.0)
translate -y
#declare LitDiamond =
union {
object { Diamond }
object { LightString }
// object { LightRing }
translate 4*y
#declare vCamera = <5, 2, 0>;
// Make the diamond's crown face the camera
object {
Tilt(LitDiamond, vCamera)
// translate 6*z // To make place for the second copy below
// Second copy of diamond viewed from another angle
object {
Tilt(LitDiamond, <-1, 2, 0>)
translate -16*z
plane {
y, -8
pigment { color Blue/2 }
finish {
ambient 0.2
specular 0.3
reflection 0.3
sky_sphere {
RedPigment
scale 4
rotate -20*y
#declare AreaLight =
light_source {
50*y,
color White*0.6
area_light 3*x, 3*z, 3, 3
adaptive 1
jitter
Tilt(AreaLight, <-1, 2, 0>)
location vCamera*4
look_at -4*z
angle 100
Updated file with photons and radiosity, I am not sure if the settings
are sane or not... :-)
Look in binaries.images for a traced version of the source, however that
image is not traced with the new settings for the diamond texture. I
added some parameters after I've traced the image in order to see if I
could get rid of the "dirty" look.
// =====1=======2======= 3 ======= 4 ======= 5 ======= 6 ======= 7
#version unofficial MegaPov 0.5;
global_settings {
ambient_light 0.5
max_trace_level 10
photons{
count 20000
spacing .01
gather 60, 100
autostop 0
jitter .4
max_trace_level 4
//load_file "brilliant.ph"
ini_option "+QR"
ini_option "Preview_Start_Size=16"
ini_option "Preview_End_Size=8"
radiosity{
count 25
nearest_count 4
error_bound 2.5
recursion_limit 2
low_error_factor .5
gray_threshold 0.0
minimum_reuse 0.015
brightness 1
adc_bailout 0.01/(18*2)
#macro create_spectrum(nelems,bright)
#local elem=1;
color_map{
#while(elem<=nelems)
/* h goes from 0 at red end to 1.0 at blue end */
#local h = (elem-1)/(nelems-1);
/* co-h goes from 1.0 at red end to 0.0 at blue end */
#local coh = 1.0 - h;
#local Huered = 0.9 - (h/0.5);
#local Hueblue = 1.0 - (coh/0.6);
#if (Huered < 0.0) #local Huered = 0.0; #end
#if (Hueblue < 0.0) #local Hueblue = 0.0; #end
#local Huered=1.0 - (1.0-Huered)*(1.0-Huered);
#local Hueblue=1.0 - (1.0-Hueblue)*(1.0-Hueblue);
#local Huegreen = 1.0 - Huered - Hueblue;
#if (h>0.85)
#local Huered = 4*(h-0.85); // was 4 - changed to 8
#local ybulge = -4.0*(h-0.1)*(h-0.6);
#if (ybulge<0) #local ybulge=0; #end
#local Huered = Huered+ybulge;// * 0.5; // added * 0.5
#local Huegreen = Huegreen+ybulge;
[bright, color rgb <Huered,Huegreen,Hueblue>]
#debug
concat("<",str(Huered,0,3),",",str(Huegreen,0,3),",",str(Hueblue,0,3),">\n")
#local elem=elem+1;
#end // while
#end // macro
object {
Thing
rotate xAngle*y
rotate -yAngle*z
rotate -xAngle*y
#end // macro Tilt
#local Cnt = 0;
object {
Thing
translate Radius*x
rotate Angle*y
#end // while
granite
turbulence 0.4
color_map {
color rgbf <1.0, 1.0, 1.0, 0.95>
finish {
// ambient 0.01
// diffuse 0.4
ambient 0.1
diffuse 0.1
reflection .25
specular 1
roughness 0.001
interior {
caustics 1
ior 2.417
dispersion 0.75
disp_nelems 10 // 10
intersection {
plane { y, 0 }
plane { -y, 8.2 } // 8.2
#declare Diamond =
object {
Brilliant
#declare DimLight = light_source { -3*y, color White*0.15 /* photons {
global refraction on reflection on } */ }
union {
#declare Cnt = 0;
#end // while
union {
translate -y
union {
object { Diamond }
translate 4*y
object {
photons {
target
refraction on
reflection on
ignore_photons
object {
photons {
target
ignore_photons
refraction on
reflection on
translate -16*z
plane {
y, -8
finish {
ambient 0.2
specular 0.3
reflection 0.3
photons { ignore_photons }
sky_sphere {
color rgb <1, 1, 1>
scale 4
rotate -20*y
light_source {
50*y,
color White*0.6
adaptive 1
jitter
photons {
global
area_light
refraction on
reflection on
//create_spectrum(16,0.1)
location vCamera*4
look_at -4*z
angle 100
Børge Berg-Olsen
+47 90 62 71 78 DoD#2101, DoDRT#017, NIC#015, PJ#006, OGM#007
azo### [at] dod no, Ducati M600 Ubesudlet: Aldri eid en J&%#PS.
