what are they what do they do?
http://www.geocities.com/siliconvalley/horizon/7128
visit and sign the book
remove "spam" to reply
Joe
> Joe
I will give a simple explanation because it is the only one I know.
1. You use a height field to make mountains (other stuff too, suppose).
2. A heightfield is actually a normal 2D picture (looks like one of
those arty tie-died Tshirts).
2b. Pov looks at each color in the tie-die, works out its number (each
color is numberred), and that is the height of the mountain at that
point.
3. there are a couple of utilities you can use to generate them, and you
can even use win paintbrush, but you would have to be skilled or stupid.
4. To use, a) generate the heightfield somehow (I use terrain maker)
b) do the 'insert>shapes>heightfield' thing in POV3.0
c) under filename, put the one you want to use
> > Joe
> point.
Jarrod,
I am having a similar problem. I am working on a project to use POV-Ray
in Radio Astronomy. My problem is that I have a "contour map" in false
color that I want to use as my height field. That way, I can get a good
estimate of the shape of the radio source. Do you know of anyway to do
this? I am basically wanting to turn a 2d map into a 3d contour map.
Any help would be appreciated from anyone,
Bob Ratliff
Morehead State University
Morehead Astrophysical Observatory
> Jarrod,
> Bob Ratliff
Just a little tip: If your image is in 256 colours you may want to
re-order the pallete so that the lowest colour is at top and the highest
colour is at the botto, or is that the other way round??? Anyway, povray
uses the pallete and the order of the colours in it to determine which
colour is the highest point in the image and which colour is the lowest.
The read the docs. Try 7.5.2.5(it contains all the gory details about
heightfields.)
Cheers, Matthew
Using a global setting of "hf_gray_16" aids in creating a smooth and
precise field. The larger you render the first step the better the final
image will appear (to a point).
This may not create an image as you expect it to appear, but it will
nevertheless have three dimensional characteristics. I came up with the
following two files to create hf's from any image. Even a black&white image
can benefit from this process (and has).
On the first pass, use this file to create your height_field input file.
// FC_HF.pov
global_settings { max_trace_level 25 assumed_gamma 2.2 hf_gray_16 }
object { box { <-4,-3,1>,<4,3,1.1> } texture {
pigment { image_map { tga "FalseColor.tga" once }
translate <-.5,-.5,-.5> scale <8,6,1> } } }
camera { location <0,0,-5> direction z look_at 0 }
light_source { <0,0,-65500> color rgb 1 }
Then, use this file to finish it up.
// Final.pov
height_field { tga "FC_HF.tga" smooth rotate -90*x
texture { pigment { image_map { tga "FalseColor.tga map_type 0 once } } }
translate <-.5,-.5,-.5> scale <8,1,6> translate 1*z }
Additionally, you can rotate the height_field in the final source in order
to see the 3D effects.
Paul Hinds
gri### [at] swbell net
> final
> the
> image
> file.
> // FC_HF.pov
> // Final.pov
> order
> Paul Hinds
Good files, Grimdude, but, especially for a case where you are trying to
accurately render a dataset, I recommend that you create the height
field with an orthographic camera and ambient 1.0 to avoid false
perspective and shading artifacts. This also makes it easy to make the
height field exactly fit the false color image. Also, if you set
assumed_gamma to 1.0 and set display_gamma to 2.2 (or 1.8 or whatever)
in your .ini file, your colors will have better dynamic range, there
will be less need for pumping color values over 1 (and losing some
detail), and people with nonClone machines will be able to run your
POV's and get the same results as you. I posted a .zip a day or two ago
that illustrates these things if you are interested. Aside from these
quibbles, it uses the same basic two step approach you describe.
Jerry Anning
cle### [at] dhol com
Oh, you mean the 345Kb thing? Heh, I was afraid to look :)
Paul Hinds
> POV-Ray
> false
> good
> do
The first thing is that, if possible, the *brightness* of your false
color should correspond to the parameter that you want to map. Given
that, the higher the resolution (the larger the size), the smoother your
image will be. What you do, basically, is first, use the false color
image to make a special format gray scale height field map. Then, you
use that to render the height field and lay the original false color
image on it. The accompanying .zip file contains an example of the
process. Gradmap.tga was randomly splotted together in CorelPaint.
Call that our original false color contour map. It was fed to
gradhgt.pov, which was rendered with gradhgt.ini. This produced
gradhgt.tga, a 16 bit grayscale height field map. Using gradhgt.tga to
form the height field and gradmap.tga to color it, the final image,
gradimg.tga. was produced with gradimg.pov and gradimg.ini. I used
POVWin to do this, but any version of POV would work. Email if you need
a hand or more info. This is easiest if your original map is square, as
this was, but other aspect ratios can be accommodated. Good luck.
Jerry Anning
Download 'htfields.zip' (345 KB)
Jerry, et al..
Thanks for the information and the files. I will see if what I can do
using them and let you know how it goes. I am also trying to do the
same thing using Hi-Q which my boss thinks might do it easier, but if
it is easier, I have yet to find a way ;)
Thanks,
Bob Ratliff
Systems Administrator
Joe Conklin <spa### [at] csrlink net> wrote in article
<34d5373f.0@news.povray.org>...
| Joe
Subject: Feeling good-natured today ?? (was: RTFM (was RE:heightfield?))
Date: 9 Feb 1998 16:28:03
Message: <34df82f9.0@news.povray.org>
>Tristan Wibberley wrote :
>RTFM
How nice !!! Especially after there have been numerous responds giving very
detailed explanations.......
- K-
Sorry to all who I may have insulted.
I got up on the wrong side of the bed that day, and there is a wall there,
so I had a headache ;-)
I also had no sleep the night before (dunno why, I just couldn't)
what I really meant was just RTM, 'cos I found it useful.
Tristan Wibberley
(Remove the '.NO_LUNCHEON_MEAT' from my
email address to reply.)
Kent Friberg <kef### [at] No Spam Thanx online no> wrote in article
<34df82f9.0@news.povray.org>...
| >RTFM
very
| - K-
Subject: Re: Feeling good-natured today ?? (was: RTFM (was RE:heightfield?))
Date: 11 Feb 1998 10:16:55
Message: <34e1e3e9.0@news.povray.org>
Tristan Wibberley wrote in message
<01bd36d5$de1cb840$181657a8@W_tristan.gb.tandem.com>...
Well, we all have our bad days I suppose, and yeah, there is a slight
difference between RTM&RTFM :-)
-and btw RTM *IS* really useful, at least in POV's case ;-)
- K-
Message: <34e1de1e.0@news.povray.org>
- K-
Joe Conklin wrote:
> what are they what
mostly what.
> do they do?
they definitely do.
