POV-Ray : Newsgroups : povray.binaries.scene-files : AT Devil Plate : Re: AT Devil Plate Server Time
25 Mar 2026 04:09:27 EDT (-0400)
  Re: AT Devil Plate
Date: 5 Apr 2025 08:25:00
Message: <web.67f1205ad1f5ea8e4e78ec763b2af915@news.povray.org>
> > F(x,y,z,t) = if(y<(44/10)&y>-(24/10),ThickIsoExterior((10*x/15),y,z,t),1)
> There are likely several ways to go about this.
> Enclosing the inequalities in parentheses evaluates them as a Boolean.
> If you multiply them, if either one is false, then the product is zero.
> If they are both true, then you get 1 * 1 = 1;
> so you could try:
> F(x,y,z,t) =
> select ( (y<(44/10)) * (y>-(24/10)),
> 0, 1, ThickIsoExterior((10*x/15),y,z,t)
> A zero gets added in to use the "4-parameter version" of select, and then since
> false = 0, the 1 is the next parameter, and true = 1, so ThickIsoExterior is the
> last parameter.
> Hope that makes sense.
> - BW
> select(A, B, C [,D])
> It can be used with three or four parameters Select compares the first argument
> with zero, depending on the outcome it will return B, C or D. A,B,C,D can be
> floats or funtions.
> When used with three parameters, if A < 0 it will return B, else C (A >= 0).
> When used with four parameters, if A < 0 it will return B. If A = 0 it will
> return C. Else it will return D (A > 0).
Thanks, B.E.
Now it's clearer what select() is good for.
I have to chew on that for a while.
