POV-Ray : Newsgroups : povray.binaries.scene-files : And's pattern blend playground : Re: And's pattern blend playground Server Time
30 Mar 2026 12:04:20 EDT (-0400)
Date: 25 Jun 2018 02:45:01
Message: <web.5b308ebf86da4c362d85b1510@news.povray.org>
> With thanks to And, a little playground when you have nothing better to
> do :-)
>   Persistence of Vision Ray Tracer Scene Description File
>   File name   : And_Pattern blend.pov
>   Version     : 3.71
>   Description : Pattern blending of a photograph.
>   Date        : 2 March 2018
>   Author      : And
>   E-mail      : in p.b.i. pattern blend (by And):
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5a996d03fe35f84f1c2f7e850%40news.povray.org%3E/
>   See also:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5a996d03fe35f84f1c2f7e850%40news.povray.org%3E/?mtop=4210
77&moff=20
> // Render settings 3.7 (right-click on a line below):
> // Be sure to set the image width and height
> // for glasses.jpg:
> // +w1024 +h768 +a0.3 +am2 +bm2 +rp0 +bs8 +wt6
> #version 3.71;
> //#version unofficial patch 3.71; //UberPOV
> #include "stdinc.inc"
> #local Rad     = off;     // radiosity switch
> global_settings {
>    assumed_gamma 1.0
>    max_trace_level 5
>    noise_generator 2
>    #if (Rad)
>      radiosity {
>        pretrace_start   0.08
>        pretrace_end     0.004
>        count            100, 1000
>        nearest_count    10, 5
>        error_bound      1
>        recursion_limit  1
>        low_error_factor 0.3
>        gray_threshold   0.0
>        minimum_reuse    0.015
>        maximum_reuse    0.1
>        brightness       1
>        adc_bailout      0.01/2
>        normal           off
>        media            off
>        always_sample    off
>        //max_sample     1.0
>    #end
> camera {
>    orthographic
>    location  <0.0, 0.0, -10.0>
>    look_at   <0.0, 0.0,  0.0>
>    right     x*image_width
>    up        y*image_height
>    angle 5.8*1
> background {color rgb 1}
> // Controls:
> #local Mono    = off;    // monochrome/polychrome switch
> #local Gamma   = 5;      // play with this value for interesting results
> #local Pattern = 1;      // 1=crackle solid; 2=granite; 3=agate;
> 4=bumps; 5=quilted; 6=bozo;
> #local N       = 0.1;  // use N <= 1.0
> #local rotZ    = 40;     // rotation angle of the pattern around the z-axis
> // Load here your image:
> #declare p_original =
> pigment {
>    image_map {
>      jpeg "glasses.jpg" gamma Gamma
>      map_type 0
>      interpolate 2
> #if (Mono)
> #declare p_modify =
> pigment{
>      pigment_pattern{p_original}
>      pigment_map {
>      #for(i,0,255)
>        [i/255  #switch (Pattern)
>                #case(1)
>                  crackle solid
>                #break #case(2)
>                  granite
>                #break #case(3)
>                  agate
>                #break #case(4)
>                  bumps
>                #break #case(5)
>                  quilted control0 0.5 control1 1
>                #break #case(6)
>                  bozo
>                #end
>                scale (1/<image_width, image_height, 1>)*N
>                rotate <0,0, rotZ>
>                color_map {
>                  [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.1>]
>                  [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.9>]
>      #end
> #else
> #declare f_original =
> function {pigment {p_original}}
> #declare f_o_R = function {f_original (x,y,z).red}
> #declare f_o_G = function {f_original (x,y,z).green}
> #declare f_o_B = function {f_original (x,y,z).blue}
> #declare f_modify =
> pigment {
>    average
>    pigment_map {
>      [1    function {f_o_R (x,y,z)}
>            pigment_map {
>              #for (i, 0, 255)
>                           #case(1)
>                             crackle solid
>                           #break #case(2)
>                             granite
>                           #break #case(3)
>                             agate
>                           #break #case(4)
>                             bumps
>                           #break #case(5)
>                           #break #case(6)
>                             bozo
>                           #end
>                           rotate <0,0, rotZ>
>                           color_map {
>                             [0.2+0.6*(1-pow (i/255,1/3)) srgbt <0,0,0,0.1>]
>                             [0.2+0.6*(1-pow (i/255,1/3)) srgbt <3,0,0,0.9>]
>              #end
>      [1    function {f_o_G (x,y,z)}
>            pigment_map {
>              #for (i, 0, 255)
>                           #case(1)
>                             crackle solid
>                           #break #case(2)
>                             granite
>                           #break #case(3)
>                             agate
>                           #break #case(4)
>                             bumps
>                           #break #case(5)
>                           #break #case(6)
>                             bozo
>                           #end
>                           rotate <0,0, rotZ>
>                           color_map {
>                             [0.2+0.6*(1-pow (i/255,1/3)) srgbt <0,3,0,0.9>]
>              #end
>      [1    function {f_o_B (x,y,z)}
>            pigment_map {
>              #for (i, 0, 255)
>                           #case(1)
>                             crackle solid
>                           #break #case(2)
>                             granite
>                           #break #case(3)
>                             agate
>                           #break #case(4)
>                             bumps
>                           #break #case(5)
>                           #break #case(6)
>                             bozo
>                           #end
>                           rotate <0,0, rotZ>
>                           color_map {
>                             [0.2+0.6*(1-pow (i/255,1/3)) srgbt <0,0,3,0.9>]
>               #end
> #end
> plane {
>    z, 0
>    #if (Mono)
>      pigment {p_modify
>    #else
>      pigment {f_modify
>    #end
>      translate -0.5
>      scale <image_width, image_height, 1>
>      scale 0.001
>    finish {emission 1 diffuse 0}
>    no_shadow
> Thomas
Well, I didn't know you post an article here.
