POV-Ray : Newsgroups : povray.binaries.scene-files : Granite_21 macro - beta #1.4 : Re: Granite_21 macro - beta #1.5 Server Time
31 Mar 2026 03:15:07 EDT (-0400)
Date: 31 May 2021 11:05:58
Message: <60b4fb56$1@news.povray.org>
Op 31-5-2021 om 12:26 schreef Bald Eagle:
>> There is indeed an error there. Replace the following line:
>> #ifndef (_GRANITE_FILE_INC_)  #include "DakotaRedGranite.inc"  #end
>> by:
>> #ifndef (_GRANITE_FILE_INC_)  #local Granite_file =
> So, I guess I'm still not understanding your intent.
> Working backwards,
> You have :"DakotaRedGranite.inc", so I guess the file you recently supplied
> needs to be renamed with capitals.
No.
> Before this, You're checking to see if _GRANITE_FILE_INC_ is a declared
> identifier.  Where is this identifier supposed to be properly declared?   In the
> include file?
This is an ancient trick I learned decades ago ;-). The form
_GRANITE_FILE_INC_ (the last underscore is maybe redundant) somehow
covers all the possible forms of writing (capitals, dots, etc) of which
a file name is composed. And it works perfectly well for me.
And then...!!!! [thunderclap]
So I forgot to give you the proper Line 70, which should be of course,
after Line 69, as given:
#include Granite_file
Sometimes I get blind to the most obvious things... :-/
For the proper use, you declare the file you want, /before/ calling the
macro. Example:
#declare Granite_file = "MyElectricGranite.inc";
Which includes the necessary paths too of course, like:
#declare Granite_file = "FolderA/FolderB/MyElectricGranite.inc";
> I just looked through "dakotaredgranite.inc" and it doesn't get declared in
> there.
> Also, this implies that _GRANITE_FILE_INC_ is a requisite line in any color_map
> include file.  Correct?
No. It should be all controlled by the above.
> Also, the arrays in any include file must have the proper names: A_Granite_map1,
> A_Granite_map2, etc.
Yes indeed. Those names are then used by the macro.
> I see no real problem there at the moment, although it will need to be clear how
> to properly implement multiple granite materials in a scene, so a demo ought to
> have that feature and some comments.  Just pointing it out, since some people
> like to have all of their include stuff at the top of a scene, and then do all
> the processing later.
YEs, that might give some clashes. Nothing very serious but one has to
be aware of /what/ the macro exactly does.
> One last thing that occurred to me as I was trying to get to sleep - I decided
> that I don't like the way I implemented the array for the color_map:
> 1. it uses separate entries for the color vector rather than a single vector.
> 2. That makes it difficult if not impossible to use rgbft colors
> a 2d array with color_map location and color vector would likely be better.  The
> macro probably has to get tested with an rgbft statement as well to make sure an
> vector promotion happens as expected, etc.
The granite include files, as I have defined them, use a 2d array
already. As the macro can render veins, where transmit info is supplied
by the corresponding array (the map2 one) it is just a matter of reading
the proper info in the right place. The macro takes care of that.
Thanks for your thoughts! It keeps me on my toes. ;-)
