POV-Ray : Newsgroups : povray.binaries.scene-files : @MichaelJF: sample of Rock texture from "Crossing Border" scene : Re: @MichaelJF: sample of Rock texture from "Crossing Border" scene Server Time
13 Mar 2026 05:51:39 EDT (-0400)
Date: 24 Feb 2019 13:57:20
Message: <5c72e910$1@news.povray.org>
Am 23.02.2019 um 08:56 schrieb Thomas de Groot:
> On 22-2-2019 19:52, MichaelJF wrote:
>> Am 29.01.2019 um 13:33 schrieb Thomas de Groot:
>>> Finally. I had to strongly clean up my code as successive additions,
>>> changes, tweakings, had made it - at least working for the Crossing
>>> Border scene - but not for any other one.
>>> Here is a test landscape scene, in addition to the bump_map I used
>>> which may not be the best for the purpose. A better one should be
>>> generated one day. I think about that. However, it works fine as-is.
>> Hi Thomas,
>> many, many thanks for your work. I was distracted a while from the
>> POV-newsgroups by occupational issues unfortunatelly, but not inactive
>> completelly. I soon found a spot in your scene suiting my needs to
>> have a better scene to present my idea to model steam fog. Your
>> texture is great seen at a certain distance, as my steam fog approach
>> is, but at a close distance both approaches have their limits. May I
>> ask you what kind of rock you tried to model specifically? A sort of
>> sedimentary rock I would presume. But you are the geologist and can
>> give hints to your model. As a statistician I can do guesswork only.
> Yes, the limitations of my rock approach derive almost entirely from the
> use of a bump_map.A much better approach would be using an isosurface,
> as the layered rocks are better modelled by functions. I think I have
> done things like that in my long dormant (dead?) Geomorph macros, more
> than ten years ago.
Hi Thomas,
interesting hint, I will search my archives. IIRC you have posted it to
the scene-files ages ago.
> The rocks are supposed to be sedimentary deposits, very typical in
> particular for the Jurassic and Cretaceous period of the Alpine regions.
> When I was a student, we called them "pyjama formations", which tells my
> age as I do not see any stripped pyjamas any more in modern stores, and
> with the exception of quaint humoristic movies from a certain period...
Very likely you are some years senior to me but I remember this kind of
fashion as well.
Best regards
Michael
