POV-Ray : Newsgroups : povray.binaries.scene-files : Cedeaq's semi-random landscape revisited : Re: Cedeaq's semi-random landscape revisited Server Time
12 Sep 2025 21:32:46 EDT (-0400)
Date: 23 Jun 2018 11:58:51
Message: <5b2e6e3b$1@news.povray.org>
Le 18-06-22 à 22:34, Jörg "Yadgar" Bleimann a écrit :
> Hi(gh)!
> On 22.06.2018 09:36, Thomas de Groot wrote:
>> Beware that your font path is not for universal use! Users have to
>> edit your code in order to use it properly. For demonstration purposes
>> it is better to stick to the standard ttf's provided by POV-Ray.
> Here is the cleaned-up code!
> See you in Khyberspace!
> Yadgar
On a normally installed version of POV-Ray, the path to your fonts
should already be in your input paths.
That mean that you should not need to have that
«#local textpath = "/home/Raytracing/Povscn/Fonts/";"»
In fact, under Windows, in the message pane, you can find this :
Library paths:
...[some other paths]...
C:\Windows\Fonts
Without having that path in any of the ini files.
On a Linux system, or a Mac, you should have something similar.
