POV-Ray : Newsgroups : povray.binaries.scene-files : And's pattern blend playground : And's pattern blend playground Server Time
20 Mar 2026 19:06:37 EDT (-0400)
Date: 9 Mar 2018 07:20:26
Message: <5aa27c0a@news.povray.org>
With thanks to And, a little playground when you have nothing better to
do :-)
  Persistence of Vision Ray Tracer Scene Description File
  File name   : And_Pattern blend.pov
  Version     : 3.71
  Description : Pattern blending of a photograph.
  Date        : 2 March 2018
  Author      : And
  E-mail      : in p.b.i. pattern blend (by And):
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5a996d03fe35f84f1c2f7e850%40news.povray.org%3E/
  See also:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5a996d03fe35f84f1c2f7e850%40news.povray.org%3E/?mtop=421077&moff=20
// Render settings 3.7 (right-click on a line below):
// Be sure to set the image width and height
// for glasses.jpg:
// +w1024 +h768 +a0.3 +am2 +bm2 +rp0 +bs8 +wt6
#version 3.71;
//#version unofficial patch 3.71; //UberPOV
#include "stdinc.inc"
#local Rad     = off;     // radiosity switch
global_settings {
   assumed_gamma 1.0
   max_trace_level 5
   noise_generator 2
   #if (Rad)
     radiosity {
       pretrace_start   0.08
       pretrace_end     0.004
       count            100, 1000
       nearest_count    10, 5
       error_bound      1
       recursion_limit  1
       low_error_factor 0.3
       gray_threshold   0.0
       minimum_reuse    0.015
       maximum_reuse    0.1
       brightness       1
       adc_bailout      0.01/2
       normal           off
       media            off
       always_sample    off
       //max_sample     1.0
   orthographic
   location  <0.0, 0.0, -10.0>
   look_at   <0.0, 0.0,  0.0>
   right     x*image_width
   up        y*image_height
   angle 5.8*1
background {color rgb 1}
// Controls:
#local Mono    = off;    // monochrome/polychrome switch
#local Gamma   = 5;      // play with this value for interesting results
#local Pattern = 1;      // 1=crackle solid; 2=granite; 3=agate;
4=bumps; 5=quilted; 6=bozo;
#local N       = 0.1;  // use N <= 1.0
#local rotZ    = 40;     // rotation angle of the pattern around the z-axis
// Load here your image:
#declare p_original =
   image_map {
     jpeg "glasses.jpg" gamma Gamma
     map_type 0
     interpolate 2
#if (Mono)
#declare p_modify =
pigment{
     pigment_pattern{p_original}
     pigment_map {
     #for(i,0,255)
       [i/255  #switch (Pattern)
               #case(1)
                 crackle solid
               #break #case(2)
                 granite
               #break #case(3)
                 agate
               #break #case(4)
                 bumps
               #break #case(5)
                 quilted control0 0.5 control1 1
               #break #case(6)
                 bozo
               scale (1/<image_width, image_height, 1>)*N
               rotate <0,0, rotZ>
               color_map {
                 [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.1>]
                 [0.2+0.6*(1-pow(i/255,1/3)) rgbt<0,0,0,0.9>]
#else
#declare f_original =
function {pigment {p_original}}
#declare f_o_R = function {f_original (x,y,z).red}
#declare f_o_G = function {f_original (x,y,z).green}
#declare f_o_B = function {f_original (x,y,z).blue}
#declare f_modify =
   average
   pigment_map {
     [1    function {f_o_R (x,y,z)}
           pigment_map {
             #for (i, 0, 255)
                          #case(1)
                            crackle solid
                          #break #case(2)
                            granite
                          #break #case(3)
                            agate
                          #break #case(4)
                            bumps
                          #break #case(5)
                          #break #case(6)
                            bozo
                          rotate <0,0, rotZ>
                          color_map {
                            [0.2+0.6*(1-pow (i/255,1/3)) srgbt <0,0,0,0.1>]
                            [0.2+0.6*(1-pow (i/255,1/3)) srgbt <3,0,0,0.9>]
     [1    function {f_o_G (x,y,z)}
           pigment_map {
             #for (i, 0, 255)
                          #case(1)
                            crackle solid
                          #break #case(2)
                            granite
                          #break #case(3)
                            agate
                          #break #case(4)
                            bumps
                          #break #case(5)
                          #break #case(6)
                            bozo
                          rotate <0,0, rotZ>
                          color_map {
                            [0.2+0.6*(1-pow (i/255,1/3)) srgbt <0,3,0,0.9>]
     [1    function {f_o_B (x,y,z)}
           pigment_map {
             #for (i, 0, 255)
                          #case(1)
                            crackle solid
                          #break #case(2)
                            granite
                          #break #case(3)
                            agate
                          #break #case(4)
                            bumps
                          #break #case(5)
                          #break #case(6)
                            bozo
                          rotate <0,0, rotZ>
                          color_map {
                            [0.2+0.6*(1-pow (i/255,1/3)) srgbt <0,0,3,0.9>]
plane {
   z, 0
   #if (Mono)
     pigment {p_modify
   #else
     pigment {f_modify
     translate -0.5
     scale <image_width, image_height, 1>
     scale 0.001
   finish {emission 1 diffuse 0}
   no_shadow
