POV-Ray : Newsgroups : povray.binaries.programming : Updated yuqk tarballs for Unix/Linux. 16941651 Server Time
19 Mar 2026 10:55:14 EDT (-0400)
  Updated yuqk tarballs for Unix/Linux. 16941651 (Message 7 to 16 of 16)
<<< Previous 6 Messages Goto Initial 10 Messages
Subject: Re: Updated yuqk tarballs for Unix/Linux. 16941651 (HS ?)
Date: 17 Mar 2024 10:43:31
Message: <65f70193$1@news.povray.org>
On 16/03/2024 19:40, William F Pokorny wrote:
> On 3/16/24 11:15, kurtz le pirate wrote:
>> Do you think your yuqk is compatible with JellyFish (Ubuntu 22.4.4) ?
> Hi.
> Yes. My primary development machine is running Ubuntu 22.4.4 too.  :-)
> Bill P.
Great !!!
I made my ubuntu's vm, add somes essantials package and libray.
Now, I get this error when run "make" :
make[2] : on entre dans le répertoire
« /home/doubled/build_yuqk/povray-3.8.0-x.yuqk_16941651/source »
  CXX      backend/bounding/boundingtask.o
In file included from ../source/backend/bounding/boundingtask.h:58,
                 from backend/bounding/boundingtask.cpp:39:
../source/backend/support/task.h:53:10: fatal error: boost/function.hpp:
Aucun fichier ou dossier de ce nom
   53 | #include <boost/function.hpp>
compilation terminated.
"function.hpp" does not exist anywhere.
What do you think?
Kurtz le pirate
Compagnie de la Banquise
Date: 17 Mar 2024 11:35:00
Message: <web.65f70cb4cfbb5f8e1686e436cde94f1@news.povray.org>
hi,
> What do you think?
I think you're the "victim" of the Debian / Ubuntu "bright minds" -- who split
every software, at least, into three "packages".  "-devel" typically for the
headers, and documentation too needs to be requested, "-doc" I think.  (you'll
need headers for the other to-be-linked-to libraries too)
regards, jr.
Date: 17 Mar 2024 14:10:46
Message: <65f73226$1@news.povray.org>
> What do you think?
I'll assume your './configure ...' command ran OK since you are running
make.
Did you install the libboost-dev or libboost-all-dev Ubuntu package?
You want the latter one - though in total it install much more than
POV-Ray absolutely needs.
Bill P.
Date: 18 Mar 2024 12:26:55
Message: <65f86b4f$1@news.povray.org>
>> What do you think?
> make.
Yes it is.
libboost-all-dev has fixed the problem.
Now it's the x11 library which causes issues:(
/usr/bin/ld : disp_x11.cpp:(.text+0x2b8) : référence indéfinie vers
« XDestroyWindow »
/usr/bin/ld : disp_x11.cpp:(.text+0x2c8) : référence indéfinie vers
« XFreeColormap »
/usr/bin/ld : disp_x11.cpp:(.text+0x2d8) : référence indéfinie vers
« XFreeGC »
/usr/bin/ld : disp_x11.cpp:(.text+0x2e4) : référence indéfinie vers
« XCloseDisplay »
/usr/bin/ld : disp_x11.o : dans la fonction
« pov_frontend::UnixX11Display::UpdateScreen(bool) » :
I'm still researching and learning how Linux works.
Kurtz le pirate
Date: 18 Mar 2024 16:26:59
Message: <65f8a393$1@news.povray.org>
> « XDestroyWindow »
> « XFreeColormap »
> « XFreeGC »
> « XCloseDisplay »
I'm still learning how linux works too... :-)
If you cd to the directory:
/lib/x86_64-linux-gnu or /usr/lib/x86_64-linux-gnu/
Can you list libX11 files?  ls -l libX11*
On my Ubuntu machine I see:
-rw-r--r-- 1 root root 2209016 Oct  2 15:13 libX11.a
lrwxrwxrwx 1 root root      15 Oct  2 15:13 libX11.so -> libX11.so.6.4.0
lrwxrwxrwx 1 root root      15 Oct  2 15:13 libX11.so.6 -> libX11.so.6.4.0
-rw-r--r-- 1 root root 1306280 Oct  2 15:13 libX11.so.6.4.0
lrwxrwxrwx 1 root root      19 Oct  2 15:13 libX11-xcb.so.1 ->
libX11-xcb.so.1.0.0
-rw-r--r-- 1 root root   14048 Oct  2 15:13 libX11-xcb.so.1.0.0
If you don't see these, maybe your libx11 files are located somewhere
else? If you can find that location, you can add a link time flag to
point to it.
Aside: In official versions of POV-Ray there is a file in the unix
directory with more information on the packages to install, but it's out
of date and I've never gotten around to updating it. So, the yuqk
tarball doesn't ship with it. Maybe I should bump up the priority there.
FWIW, it should be you can configure with '--without-x' and get a text
only version of the 'povray' executable which the yuqk script wraps. It
will then have no preview display as the Simple Direct Media 'sdl'
options (like the x11 preview display) also need x11 to work... 'make
check' should run - and if so, you would be able to render to output
image files.
Bill P.
Date: 19 Mar 2024 10:33:30
Message: <65f9a23a$1@news.povray.org>
> libX11-xcb.so.1.0.0
Yes, exactly the same thing
I'm going to check the unix distribution to see if there's any
additional information.
> image files.
I'll take a look at it too...
Kurtz le pirate
Date: 20 Mar 2024 04:55:00
Message: <web.65faa409cfbb5f8e1686e436cde94f1@news.povray.org>
hi,
strange that the linker does not "see" the X11 libraries.  the linker works off
a set of cached directories, if you still have the same problem, have a look at
'/etc/ld.so.conf' and the files in '/etc/ld.so.conf.d/', are your library paths
listed ?  (if yes, the cache may need refreshing ( run 'ldconfig')).
also, wondering what (exact) arguments were given to './configure'.
regards, jr.
Date: 20 Mar 2024 12:51:34
Message: <65fb1416$1@news.povray.org>
everything looks good for '/etc/ld.so.conf' and the files in
'/etc/ld.so.conf.d/'. Library paths are present.
in accordance with 'INSTALL.txt' doc :
./configure -q COMPILED_BY="name" CXXFLAGS="-O2" --prefix=/tmp/yuqk_427af17e
no strange argument.
finally, rebuilding the cache with ldconfig solved the problem.
(I should have used -v to track what was going on).
so :
running ldconfig, then ./configure, then make, then after a long long
list of messages : no error :)
last messages on terminal :
cat ./povray.ini.in | sed
"s,__POVLIBDIR__,/tmp/yuqk_427af17e/share/povray-3.8,g" > ./povray.ini
As everything is ok, i run make check
I can see the rendering of an image which also closes when finished.
I don't know where it's saved (or not).
Then run make install.
No error :)
I think all these problems come from the fact that I made a
'./configure' and 'make' with the missing X11 library. Necessary links
and cache to the right shared libraries have become corrupted.
**THANKS** for all Jr.
Kurtz le pirate
Date: 20 Mar 2024 15:25:00
Message: <web.65fb3702cfbb5f8e1686e436cde94f1@news.povray.org>
hi,
super.  glad you're "up and running".
most got lost, containing accents :-(.
you wrote you're "new to Linux".  recommend getting to know 'script(1)'.  for
instance when you render a scene, you can "record" all terminal i/o, eg:
  $ script -c 'povray myscene.pov' log-file
and you have a full "transcript" in the 'log-file'.
regards, jr.
Date: 21 Mar 2024 06:35:13
Message: <65fc0d61@news.povray.org>
hum... hum...
Big differences between nntp and http.
I made screenshots of both interfaces:
Kurtz le pirate
Download 'nntp.jpg' (56 KB) Download 'http.jpg' (21 KB)
Preview of image 'nntp.jpg'
Preview of image 'http.jpg'
