POV-Ray : Newsgroups : povray.binaries.programming : An updated povr tarball for Unix/Linux. 6e4ed6c2 Server Time
13 May 2025 07:40:44 EDT (-0400)
  An updated povr tarball for Unix/Linux. 6e4ed6c2 (Message 1 to 2 of 2)
Subject: An updated povr tarball for Unix/Linux. 6e4ed6c2
Date: 26 Oct 2021 11:11:56
Message: <61781abc@news.povray.org>
See the attached tarball.
A work in progress. As time passes the povr branch is drifting farther
from POV-Ray v3.8 proper. I expect a majority of old scenes now would
need some changes to work.
And jr! I did not get to the x11 -into / -wid work again. However, some
of the recent rtr changes are related. My thinking now is to hook that
feature into the real time rendering stuff as completely new x11 code
rather than hack the existing code as I attempted last time. This will
also let us bypass the internal messaging (and the memory bubble) for
RTR display - and RTR is where I'd like to use the feature for cheap
modeling ;-).
The new amplify and intensity_max keywords work where they work, but not
everything is done - media being the pink elephant. Mostly you can just
not use them, but the old, long deprecated, shorthand of say 'reflection
1' will no longer works.  It must be the newer reflection { 1 } style.
The emission keyword on sky_spheres is now amplify. Oh, the global
settings ambient_light keyword is gone. In povr the direction is toward
adding 'amplify' in each block over the one global setting. The idea
with amplify is to set up global color vector variables - and so better
enable in SDL what many do already in scenes today for development and
debugging purposes.
#declare Amplify_ambient_emission = rgb <1,1,1>;
#declare Amplify_reflection       = rgb <1,1,1>;
... finish {amplify Amplify_ambient_emission ...}
Oh, I was asked about the new getenv() feature and why it was needed for
environmental HDRIs. It's not. It is a general feature to pull
environment variable settings into SDL as strings (probably, best to
stick with ascii). It just happened in my earlier post, that I used an
environment variable called HDRI and so the code to reference the
environment HDRI image file I was using ended up as: getenv("HDRI").
Still not a lot of shipped documentation though there is a povr specific
revision file in the <install_dir>/doc/povrTextDocumentation directory.
For more detail on compiling etc. see previous post:
http://news.povray.org/povray.binaries.programming/thread/%3C60b2aaf6%40news.povray.org%3E/
or
Web message: <60b2aaf6@news.povray.org>
Or <install>/INSTALL.txt
Bill P.
Download 'povray-3.8.0-x.povr_6e4ed6c2.tar.gz' (1821 KB)
Subject: Re: An updated povr tarball for Unix/Linux. 6e4ed6c2
Date: 4 Nov 2021 07:05:00
Message: <web.6183bdae71acfbfdd6c295506cde94f1@news.povray.org>
hi,
thanks.  built it, tested (so far) with two rtr scenes and the Filed()[*] demos,
all seems fine, feels .. snappy.  (ran into needing braces for reflection :-))
[*] now think that 'fild__rdFile()' is "the culprit".
> modeling ;-).
any excuse, as far as I'm concerned :-)  looking forward to that option.
regards, jr.
