POV-Ray : Newsgroups : povray.binaries.programming : MPI patch for povray 3.5c Server Time
16 Jun 2024 23:06:21 EDT (-0400)
  MPI patch for povray 3.5c (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: MPI patch for povray 3.5c
Date: 14 Feb 2003 00:43:00
Message: <3e4c81e4@news.povray.org>
Matthias wrote:
> Hi folks,
> based on PVMPOV, we have created a MPI patch for povray 3.5c It works
> quite well and has been tested on Linux (SuSE 7.3&8.0), Solaris 8.0 and
> Irix.
> It works with the new automake/autoconf system of povray 3.5, so just
> unpack the archive to your povray directory and run './configure',
> 'make' and 'make install', nothing new for you guys ;-)
> It has statistics, options and other stuff, so try it out!!
> Requirements are povray3.5c and LAM/MPI 6.5.x
> What do you think about it??
> If you like it, I hope it can be added to the tools section on the
> povray homepage...
> Matthias
How well does this intergrate with radiosity, photons, and other nifty
features of v3.5c? I'm going to try the InformationRod.pov from the images
group to try this out on 4 machines. Should I expect artifacts in the
rendering vs using a single CPU?
---Christopher
Date: 25 Jul 2004 07:45:00
Message: <web.41039c554419f93c2718e9220@news.povray.org>
Matthias <mat### [at] webde> wrote:
> Hi folks,
> Irix.
I like it very much!
We use POVRay for rendering images to scientific publications, and need
sometimes to do very large images (think 600dpi). We have access to several
large (512 cpu size) installations. Both SMP machines and clusters. To get
the job done unfortunately we need povray 3.6.
Is there any chance you will port your patch to POVRay 3.6 ? I tried naively
to just dump parapov in the 3.6 source, and it didn't work. I would be
happy to help test - also large scale (up to 128 CPU) - runs if
needed/wanted.
Troels
Date: 29 Nov 2005 06:35:01
Message: <web.438c3bee4419f93c14f142ad0@news.povray.org>
> Hi folks,
> Irix.
> povray homepage...
> Matthias
For those who are interested in parallel versions of Povray - I found an
easy way to do this with any version of Povray. :) Read this article:
http://u.pereslavl.ru/~vadim/MCSharp/docs/povray/index.php
Best regards,
Vadim B. Guzev
Date: 29 Nov 2005 09:10:42
Message: <438c6162$1@news.povray.org>
... which happens to contain various incorrect statements about the
development of POV-Ray.  In particular the lengthy paragraph about the
"owner" and "developer" of POV-Ray is all wrong.  Persistence of Vision
Raytracer Pty. Ltd. only holds the copyright in order to protect individual
developers (against patent lawsuits, illegal use of POV-Ray, etc), it does
not develop POV-Ray.  This is a same setup similar to what most open source
projects are forced to use these days.  The paragraph also claims the
official version is not developed by volunteers, which is plain wrong, too.
	Thorsten
Date: 29 Nov 2005 09:38:45
Message: <dmhp4o$pcf$1@chho.imagico.de>
Which is just yet another
split-render-into-tiles-and-render-with-multiple-instances-of-POV-Ray
tool in someone's favourite pet language.
Various tools already exist for this:
http://www.imp.org/impfarm/default.asp
http://www.it-berater.org/smpov.htm
http://www.imagico.de/povany/index.html
which offer more functionality (esp. distributing a render across
different computers).
http://www.imagico.de/ (Last updated 31 Oct. 2005)
Date: 21 Feb 2006 16:15:00
Message: <web.43fb81e84419f93cd3852e870@news.povray.org>
> Hi folks,
> Irix.
> povray homepage...
> Matthias
I think this file is corrupted. I have tried downloading it several times.
And made sure to clear the cache of the browser and delete the original
copy between tries. tar gives me errors when I try to unpack it. Is this
file hosted anywhere else?
Thanks,
-Dave
Date: 23 Feb 2006 10:45:00
Message: <web.43fdd8174419f93cd3852e870@news.povray.org>
ah...I used wget to download the file, and I am able to unpack it.
Best,
-Dave
> > Hi folks,
> > Irix.
> > povray homepage...
> > Matthias
> Thanks,
> -Dave
Date: 6 Oct 2006 04:30:00
Message: <web.452613224419f93c9d9c83740@news.povray.org>
Hi everyone,
I tried to setup mpi-povray based on Matthias patch, but i got this error
when i type make:
: undefined reference to `__ctype_b'
collect2: ld returned 1 exit status
make[1]: *** [povray] Error 1
make[1]: Leaving directory `/opt/povray3.5/povray-3.50c/src'
make: *** [all-recursive] Error 1
anyone have any idea bout this? thanx in advance!
Jack
> Best,
> -Dave
> > > Hi folks,
> > > Irix.
> > > povray homepage...
> > > Matthias
> > Thanks,
> > -Dave
Date: 3 May 2007 10:40:04
Message: <web.4639f4054419f93c5fb7d6ee0@news.povray.org>
> Christoph
Hello:
Cristoph, as you already know from my previous posts regarding Povray and
Of all the links you list which one do you recommend the most?
I think povany would be a good one to try.
SMPov looks good to but do you know if it runs on Linux?
Thank You.
Date: 14 Jun 2008 19:20:01
Message: <web.485451174419f93c1219a6fe0@news.povray.org>
> Hi folks,
> Irix.
> povray homepage...
> Matthias
HI Matthias and Everyone!!
Sorry for my bad english, pero i need the patch for povray and lam, the patch
it's seems corrupted, and i can't uncompress this. Can you fix this please?, o
send me to mi mail??, fel### [at] gmailcom.
Bye and thank you!!!
