POV-Ray : Newsgroups : povray.binaries.programming : new pattern simulating a wall of interlocking rectangular stones of unequal size Server Time
27 Nov 2026 22:30:16 EST (-0500)
  new pattern simulating a wall of interlocking rectangular stones of unequal size (Message 1 to 17 of 17)
Subject: new pattern simulating a wall of interlocking rectangular stones of unequal size
Date: 12 Jul 2001 21:35:58
Message: <01c10ad7$8462d300$4b821c26@jmsWin95>
I wrote a pattern simulating the appearance of a stone wall made of
rectangular blocks of random size that interlock perfectly.  For an
example, look at "http://cs.georgefox.edu/~jsnow/pov.html".  I haven't
figured out how to integrate it into Pov-RAY so that I can call the pattern
by name and pass in parameters, so the only way to play with it right now
is to copy and paste my code into patterns.c and rename my "ashlar"
function to match the name of another pattern, and comment out that
pattern.
My code has been tested with Megapov .5, gcc, and Linux.
If someone wants to integrate it correctly into Pov-RAY, Megapov, or
whatever, be my guest.  You can get my code at
"http://cs.georgefox.edu/~jsnow/ashlar.c".  Anyone interested?
-jim
Subject: Re: new pattern simulating a wall of interlocking rectangular stones of unequal size
Date: 12 Jul 2001 22:17:31
Message: <slrn9ksmi1.h91.ron.parker@fwi.com>
It's very interesting.  Have you done any calculations to determine what
the maximum search will have to be before you're guaranteed not to be on
a mortar line?  Have you considered using the Noise function instead of
a random array to determine the positions of the seed points?  That would
allow your "array" to be essentially infinite, if you could make it fit
into your algorithm, and it would constrain the positions of the seed
points to an extent that you might be able to better predict what the
maximum required search is.
With those two changes, I think it would be a very useful pattern to
have.  Also, I think you could get away with having just a single ratio
to determine the number of points horizontally vs. the number vertically,
since you can then scale the bricks to fit your space.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbt 1}hollow interior{media{emission T}}finish{
reflection.1}}#end Z(-x-x.2y)Z(-x-x.4x)camera{location z*-10rotate x*90}
Date: 12 Jul 2001 22:32:10
Message: <3b4e5daa@news.povray.org>
Isn't the cells pattern much like this?  I'm not exactly sure myself.
Bob H.
"Jim Snow" <jsn### [at] csgeorgefoxedu> wrote in message
news:01c10ad7$8462d300$4b821c26@jmsWin95...
pattern
> pattern.
> -jim
Date: 12 Jul 2001 23:04:47
Message: <3B4E660E.5D7C1577@yahoo.com>
cool except for one thing.  from your picture, it looks like it is a 2d
pattern, not a 3d one.  bummer.
> pattern.
> -jim
Date: 13 Jul 2001 00:02:57
Message: <slrn9kssno.hbu.ron.parker@fwi.com>
He mentions that in the code, actually.  I think the concept could be
extended to 3d without too much work, but it'd take some thought to
do it right.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 13 Jul 2001 03:31:10
Message: <01c10b09$249f10a0$93811c26@jmsWin95>
Ryan Constantine <rco### [at] yahoocom> wrote in article
<3B4E660E.5D7C1577@yahoo.com>...
I think the algorithm can be generalized to 3d (but it might be beyond my
ability to do so), however there would be a problem with the mortar joints
parallel to the surface of the object occasionally being at the surface of
the object, resulting in an oddly textured block.  It might not be that big
of deal, but it would probably be annoying to anyone who just wants their
stone wall to look good from one side.
-jim
Date: 13 Jul 2001 04:11:32
Message: <01c10b0e$c7526cc0$93811c26@jmsWin95>
Ron Parker <ron### [at] povrayorg> wrote in article
<slr### [at] fwicom>...
a-z)R(a
T)merge{
T}}finish{
I think that a mortar line can continue infinitely if the points are
arranged in an "unlucky" fashion.
Therefore, it doesn't matter how big the search grid is, you could still
get lines that abruptly stop
without running into anything.  However, I have modified the way "random"
points are chosen in
such a way to make it unlikely that a line makes it much more than one unit
away.  I haven't tested
it enough to be sure, but with search=2, bad lines should be very rare.
The test image on my web
page used search=1.
I thought of two possible solutions to this:
1.	Pick "random" points within each box such that it is impossible to
project a vertical or horizontal line through the box without it
intersecting a mortar line.
2.	Any mortar line longer than some maximum distance from its originating
point automatically splits at the max distance and sends out mortar lines
in either direction perpendicular to the original mortar line that continue
until they collide with some other mortar line.
I haven't come up with a trivial algorithm for either solution.
I'll think about using a noise function for the "random" data - my array of
random vectors isn't very elegant, even if it is fast.
extra note:  I tried out Megapov 0.7 today - My patch didn't work quite
right without adding &0xFFF to the arguments to Hash2d(int, int).  Strange.
-jim
Date: 13 Jul 2001 04:20:36
Message: <01c10b10$0b7fed40$93811c26@jmsWin95>
Bob H. <omn### [at] msncom> wrote in article <3b4e5daa@news.povray.org>...
> Bob H.
No, the cells pattern picks a random value between 0 and 1 for each unit
cube, such that every point in each cube has the same value.  My pattern
creates blocks of random dimensions that interlock.
-jim
Date: 13 Jul 2001 08:51:25
Message: <slrn9ktrme.hq9.ron.parker@fwi.com>
Quite true.  That happens with bricks and with crackle occasionally as
well.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 13 Jul 2001 09:29:43
Message: <3b4ef7c6@news.povray.org>
> pattern.
Very interesting.  Have you seen my isosurface stone walling code?  It looks
to be doing similar sorts of things, though I think mine is a little bit
more intelligent (in that it does things as a stone mason might do, like
making sure stones are wider than tall, etc)  It's slow, since it's in pov
native code, and then uses iso surfaces, but on the other hand, allows for
lots of nifty stuff like roughing up the surface and morphing it into cones
and cylinders and such by changing the iso function.
I haven't looked at your code since I'm pretty much a novice to the POV
source.
Geoff
Date: 13 Jul 2001 11:12:57
Message: <slrn9ku3vq.hs6.ron.parker@fwi.com>
I'm not convinced that that is true, but proving it either way could be
an interesting project all by itself.
This seems like the best solution.  I have some not-very-well-formed thoughts
on this, which I'll elucidate below.
You might find how the crackle function works interesting.  As you probably
know, the crackle pattern is a 3d voronoi diagram.  Each "stone" has an
apparently randomly positioned centroid, and every point that is closer to
that centroid than to any other is part of that stone.  What isn't so
obvious on casual examination is that the centroids are not really as
random as they appear.  All of space is divided into 1x1x1 cubes, and each
cube contains exactly one centroid.  The location of each centroid is
determined by the values of the Noise3D function at some fixed point within
its enclosing cube, allowing it to be reproducibly calculated as needed.
So, here is my thought:  Pick your seed points the same way crackle picks
its centroids (except in 2D, obviously.)  For each square, determine the
sum of its coordinates.  If that sum is even, make the seed point draw a
horizontal line.  If it's odd, make the seed point draw a vertical line.
Now, when a mortar line leaves its enclosing square it's likely to meet a
line going the other way within the next square (unless the line going the
other way was stopped by the line that came from the opposite face of the
square.)   It's still possible to have infinite lines, but they're very
very unlikely.  It's unlikely that a line will make it more than 3 squares
away, I'd think, meaning you might need to search as many as 50 points
for each test.  But you should be able to cache the results of those tests
to some extent to take advantage of some of the spatial coherence in the
raytracing algorithm, as the crackle pattern does.
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 13 Jul 2001 11:56:08
Message: <3B4F1AC9.160D7877@comtrade.ee>
Macro HashXd was changed in last version of MegaPOV, see file texture.h,
there is conditional directive:
#ifdef NoiseTranslateFixPatch
In megapov news ( http://nathan.kopp.com/patched.htm ) probably this
line refers to it:
7. Fixed a bug, reported by Nicolas Calimet, in the TransformPatch
(9.2.9)
Unfortunately I don't remember, what was the proble with this
transformation.
In order to fix this 'nicely' you have to use conditional compilation:
// use this:
x = Hash2d(a&0xfff, b&0xfff);
#else
x = Hash2d(a, b);
#endif
I had the same problem when merged my code with MegaPOV.
Date: 13 Jul 2001 15:33:26
Message: <01c10b6e$0a7607a0$86811c26@jmsWin95>
the
squares
tests
a-z)R(a
T)merge{
3-T}}}#end
I thought about alternating verticals and horizontals, but decided it would
make the texture look a little too predictable.  However, the algorithm
could be vastly simplified - instead of testing distance from the
originating points to determine which mortar line wins when they intersect,
I could make it so that a mortar line always wins within its own square and
loses outside its own square.  The search grid would only have to be 3x3 to
garuntee that no line escapes the grid.
Maybe I should try to make a 3d version with the simpler algorithm.
-jim
Date: 13 Jul 2001 15:59:37
Message: <slrn9kukon.i5j.ron.parker@fwi.com>
I drew a dozen or so squares by hand and it didn't look as predictable as
one might expect, believe it or not.
And you wouldn't have to test the corner squares, either.
Date: 13 Jul 2001 19:22:13
Message: <3b4f82a5@news.povray.org>
news:01c10b10$0b7fed40$93811c26@jmsWin95...
Sorry, yes, I see now.  I thought the cells pattern could be changed somehow
but it looks like turbulence is about it, and that only deforms the
boundaries in nonlinear ways.
Thanks for replying to clear that up.
Bob H.
Date: 13 Jul 2001 20:55:15
Message: <01c10b9a$ffe2b040$87811c26@jmsWin95>
Geoff Wedig <wed### [at] darwinepbicwruedu> wrote in article
<3b4ef7c6@news.povray.org>...
looks
pov
for
cones
> source.
> Geoff
Where can I find this code?
By the way, you can make the stones tend to be more wide than high and vice
versa with my algorithm by tweaking some numbers in the c code.  I was
thinking of using my function in an isosurface, but I haven't really
figured out how isosurfaces work.
-jim
Date: 16 Jul 2001 08:55:36
Message: <3b52e448@news.povray.org>
> looks
> pov
> for
> cones
>> source.
>> Geoff
It's never been publically released, due to lack of docs.  But it's pretty
well commented.  It started out as an isosurface update to the mur.inc, but
then I decided that the algorithm used in mur.inc was inadequate for my
needs.  If you want a copy, let me know and I'll send you the files.
They're not as hard as they seem to be at first glance.  I've become quite
enamored with them.  But there is a learning curve, mostly due to a lot of
parameters that, without a good idea of how they work, don't make much
sense.
Geoff
