POV-Ray : Newsgroups : povray.binaries.programming : Updated yuqk tarballs for Unix/Linux. 9871ed6e : Re: Updated yuqk tarballs for Unix/Linux. 9871ed6e Server Time
5 Apr 2026 06:37:48 EDT (-0400)
Date: 23 Dec 2024 04:50:00
Message: <web.676931757aadcd32b2e841a6cde94f1@news.povray.org>
hi,
William F Pokorny <ano### [at] anonymousorg> wrote:
> On 12/22/24 23:54, jr wrote:
> > builds, then an error while running 'make check' (see attached). ...
> No worries. I appreciate your testing the release.
> The error you're getting is a standard early exit by a user. It's one I
> can duplicate if I hit 'q' to cancel shortly after the preview window
> opens and before it closes while running 'make check' from a terminal
> window. (I do not see the "Script done" message which I suppose is
> coming from your build script).
> Are you able to render the biscuit.pov scene in the ...
> directory, directly?
>  yuqk biscuit.pov
thanks, invoking 'yuqk scenes/biscuit.pov' in the build directory works.  will
now  need to find out where the key event could have come from (I'd switched to
a different desktop while the build script ran); the "Script done" you (too)
should see when running eg 'script -c ./somescript the_log'.  sorry about the ..
excitement ;-).
regards, jr.
