POV-Ray : Newsgroups : povray.binaries.programming : Updated yuqk tarballs for Unix/Linux. 16941651 : Re: Updated yuqk tarballs for Unix/Linux. 16941651 (HS ?) Server Time
20 Mar 2026 04:18:35 EDT (-0400)
Date: 20 Mar 2024 15:25:00
Message: <web.65fb3702cfbb5f8e1686e436cde94f1@news.povray.org>
hi,
kurtz le pirate <kur### [at] gmailcom> wrote:
> finally, rebuilding the cache with ldconfig solved the problem.
super.  glad you're "up and running".
> last messages on terminal :
most got lost, containing accents :-(.
> As everything is ok, i run make check
> I can see the rendering of an image which also closes when finished.
> I don't know where it's saved (or not).
you wrote you're "new to Linux".  recommend getting to know 'script(1)'.  for
instance when you render a scene, you can "record" all terminal i/o, eg:
  $ script -c 'povray myscene.pov' log-file
and you have a full "transcript" in the 'log-file'.
regards, jr.
