POV-Ray : Newsgroups : povray.binaries.programming : Updated yuqk tarballs for Unix/Linux. 16941651 : Re: Updated yuqk tarballs for Unix/Linux. 16941651 (HS ?) Server Time
19 Mar 2026 05:41:51 EDT (-0400)
Date: 20 Mar 2024 04:55:00
Message: <web.65faa409cfbb5f8e1686e436cde94f1@news.povray.org>
hi,
kurtz le pirate <kur### [at] gmailcom> wrote:
> On 18/03/2024 21:26, William F Pokorny wrote:
> > Can you list libX11 files?  ls -l libX11*
> > On my Ubuntu machine I see:
> Yes, exactly the same thing
strange that the linker does not "see" the X11 libraries.  the linker works off
a set of cached directories, if you still have the same problem, have a look at
'/etc/ld.so.conf' and the files in '/etc/ld.so.conf.d/', are your library paths
listed ?  (if yes, the cache may need refreshing ( run 'ldconfig')).
also, wondering what (exact) arguments were given to './configure'.
regards, jr.
