POV-Ray : Newsgroups : povray.binaries.programming : MPI patch for povray 3.5c : Re: MPI patch for povray 3.5c Server Time
19 Mar 2026 10:53:37 EDT (-0400)
Date: 6 Oct 2006 04:30:00
Message: <web.452613224419f93c9d9c83740@news.povray.org>
Hi everyone,
I tried to setup mpi-povray based on Matthias patch, but i got this error
when i type make:
: undefined reference to `__ctype_b'
collect2: ld returned 1 exit status
make[1]: *** [povray] Error 1
make[1]: Leaving directory `/opt/povray3.5/povray-3.50c/src'
make: *** [all-recursive] Error 1
anyone have any idea bout this? thanx in advance!
Jack
"djzielin" <djz### [at] dukeedu> wrote:
> ah...I used wget to download the file, and I am able to unpack it.
> Best,
> -Dave
> > Matthias <mat### [at] webde> wrote:
> > > Hi folks,
> > > based on PVMPOV, we have created a MPI patch for povray 3.5c It works
> > > quite well and has been tested on Linux (SuSE 7.3&8.0), Solaris 8.0 and
> > > Irix.
> > > It works with the new automake/autoconf system of povray 3.5, so just
> > > unpack the archive to your povray directory and run './configure',
> > > 'make' and 'make install', nothing new for you guys ;-)
> > > It has statistics, options and other stuff, so try it out!!
> > > Requirements are povray3.5c and LAM/MPI 6.5.x
> > > What do you think about it??
> > > If you like it, I hope it can be added to the tools section on the
> > > povray homepage...
> > > Matthias
> > I think this file is corrupted. I have tried downloading it several times.
> > And made sure to clear the cache of the browser and delete the original
> > copy between tries. tar gives me errors when I try to unpack it. Is this
> > file hosted anywhere else?
> > Thanks,
> > -Dave
