POV-Ray : Newsgroups : povray.binaries.programming : Blueprint output : Re: Blueprint output Server Time
28 Mar 2026 16:35:00 EDT (-0400)
Date: 13 Apr 2005 00:46:55
Message: <sMPHtBAcQKXCFwvo@econym.demon.co.uk>
Wasn't it Steely who wrote:
>Mike Williams <nos### [at] econymdemoncouk> wrote:
>> For a real blueprint, you probably don't want a wireframe of the whole
>> house, what you want is a slice through the house, like this:
>workaround to overcome the object pattern limitation of "no texture, no
>patches" ?
It would certainly be easier to change the POV program to remove those
limitations than it would be to get it to produce wireframe renderings
of things like isosurfaces and blobs.
>If I have to construct two buildings, one with, one without textures and
Instead of the object pattern, you could difference the building with a
thin box. The textures from the original building would only appear on
the faces that are perpendicular to the camera, and therefore invisible.
difference {
  box {<-100,0.1,-100><100,0.1001,100>}
  object {House}
  pigment {rgb <0,0,1>}
  finish {ambient 1}
// white bits seen through the hole
plane {y,0 pigment {rgb 1} finish {ambient 1}}
Mike Williams
Gentleman of Leisure
