POV-Ray : Newsgroups : povray.binaries.programming : yuqk errors : Re: yuqk errors Server Time
26 Mar 2026 11:28:25 EDT (-0400)
  Re: yuqk errors
Date: 24 Feb 2025 08:33:59
Message: <67bc7547$1@news.povray.org>
On 2/24/25 06:34, kurtz le pirate wrote:
> Porting scene from standard 3.8 version to last yuqk give me somme
> errors like that :
> The yuqk release 18 (3.8.0-x.yuqk_a5c25dda) version is: v0.6.12.0
> File 'vis_mesh03.pov' line 139:
> Parse Error:
> #local identifier 'i' using only a-z, 0-9 and _ characters.
> Fatal error in parser: Cannot parse input.
> Render failed
The yuqk fork, by default, builds with code that prevents the use of
lower case user identifiers as these are too often the source of obscure
bugs and meaning (*)(**). Also, with yuqk changing all the time, it is
more likely I'll add some feature which collides some user's identifier
if they are defining lower case ones. This happened when I created an
'e' immediate value similar to the long existing 'pi'.
Users like jr, who only write and code in lower case, and folks with old
scenes often have code with lower case characters, so there is an option
to the configure script in:
   --disable-no-lc-identifiers
which you can add when you run ./configure to turn the checking off.
The installs of the yuqk core are small, One of the development builds I
maintain is compiled with that option off as are all my prior version
builds. I too often run into scenes with lower case identifiers.
A quick aside I hope useful. A place where I've several times now gotten
myself tangled up is with our relatively new #for loop. When you
write:
   #for (I,0,SphCnt,4)
that 'I' is a created (or modified) identifier which persists. In the
default yuqk build, it must be upper case, but I still forget that 'I'
is not locally scoped to the for loop. If there is use of that 'I'
outside the loop you can end up with an 'I' you didn't expect or, by
accident, define an 'I' which should be defined / initialized in some
other way.
One protection would be to add an '#undef I' immediately following the
for loop when you are sure you don't need it to persist though I mostly
fail to do it.
I've though some about changing the implementation in yuqk so it does an
internal #undef of the loop identifier / variable at loop's end, IF, the
'I' wasn't already defined. But, users sometimes would be doing things
like breaking out and checking the 'I' value following the loop. I don't
know... Just something to remember perhaps.
Bill P.
(*) Official POV-Ray releases ship with stuff defined in our include
files which only look like inbuilt keywords and functions. These make
code passed around less clear and less stable. Users are somewhat likely
to create things by the same lower case name / identifier. Where these
do not have the same functionality - but are defined by the totality of
SDL included for the scene, the scene may run, but not render properly.
(**) - The 'ro_' read only prefix is another, new to yuqk, feature
related to preventing obscure bugs where, say, a macro call using an
identifier which exist outside the macros scope changes outside the
macro itself due some #local or #declare use of the 'macro parameter
name' within the called macro. This feature is also on by default in
yuqk, but it too can be configured off by using:
   --disable-read-only-identifiers
when running ./configure.
