POV-Ray : Newsgroups : povray.binaries.programming : Updated yuqk tarballs for Unix/Linux. 427af17e : Re: Updated yuqk tarballs for Unix/Linux. 427af17e Server Time
5 Apr 2026 03:28:26 EDT (-0400)
Date: 28 Jan 2024 15:59:30
Message: <65b6c032$1@news.povray.org>
On 1/28/24 11:30, Kenneth wrote:
> When I finally found a combination that worked, I settled on
> that...without running even*more*  possible(?) tests.
Yes, when testing POV-Ray the test combinations tend to explode. You can
never cover it all. Permutations - like Bald Eagles recent image! :-)
I ran the bug down to something sitting in v3.8 onward (perhaps older
code too - I didn't check). See:
https://news.povray.org/povray.beta-test/thread/%3C65b6ba93%241%40news.povray.org%3E/
Attached is an image. The left column are the results I see for v3.8
beta 2. The right column what I see with yuqk (R11 and my working version)
The top row shows the four combinations as you posted them. The results
match. In the just released yuqk R11, the default{} mechanism still exists.
The middle row shows both v3.8 beta 2 and yuqk (R12 working code)
without the default{} block. Yuqk being different on the right is how I
caught the bug up top. With that bug fixed the result again match. (The
fixed result is not shown).
The bottom row is a repeat on the left for v3.8 beta 2, but I have made
edits to your scene file to define a user default texture and make
explicit it is the base for derived textures below. This amounts to
replacing the default{} with:
#declare DfltTxtr = texture { finish{ambient 1 emission 0 diffuse 0} }
And below that changing :
texture{pigment{rgb 1}}
     and
pigment{OBJ_COLOR_}
to become:
texture{ DfltTxtr pigment{rgb 1} }
     and
texture{ DfltTxtr pigment{OBJ_COLOR_} }
Bill P.
Aside: Your test case triggers the 'always full depth' method 3 bug
still sitting in v3.8 beta 2.
Even when I force a minimum number of samples and use big jitter with
the recent yuqk release code using:
//   test 1  off                                   ****     *****
   yuqk test.pov   +w300 +h300 +a0.005 +am3 +ac0.90 +rm2 +r5 +j1.1
the following command:
   p380b2 test.pov +w300 +h300 +a0.005 +am3 +ac0.90     +r5
runs 400% slower. Results are of course good with both commands.
Download 'story.png' (70 KB)
Preview of image 'story.png'
