POV-Ray : Newsgroups : povray.binaries.programming : An updated povr tarball for Unix/Linux. 1984d6ea : Re: An updated povr tarball for Unix/Linux. 1984d6ea Server Time
1 Jul 2025 12:25:01 EDT (-0400)
Date: 14 Jun 2021 06:35:17
Message: <60c730e5$1@news.povray.org>
On 6/12/21 7:12 PM, jr wrote:
> hi,
> William F Pokorny <ano### [at] anonymousorg> wrote:
>> On 6/9/21 11:46 AM, jr wrote:
> had a look at the xwd-1.0.6 source and modified (quick hack) the main function
> to create N files from the given window.  no syncing though, adding another
> option to specify a delay after each file might help a little.  patch attached
> just in case, but anyway, it would be a "crutch" at best.
> tested a couple of times with small number frames, running a 'povr' with the
> command-line given in 'rtr_kla.pov'.  then the modified 'xwd' ('-nfrm' + '-out'
> required):
>    $ ./xwd -nfrm 10 -out /tmp/foo -name "POV-Ray (povr) 3.8 povr X11 "
> creates '/tmp/foo_00.xwd' etc.  I used 'xv' for visual check:
>    $ xv /tmp/foo*.xwd
> (curiously, could only identify 'povr' window name + class, but no id shown)
Interesting. Thanks. I've captured your patch and this post to a sub
directory of my jr_causing_trouble directory... :-)
Bill P.
