POV-Ray : Newsgroups : povray.binaries.programming : ppm.cpp patch : ppm.cpp patch Server Time
3 Apr 2026 02:44:01 EDT (-0400)
  ppm.cpp patch
Date: 25 Jan 2003 07:19:04
Message: <3e3280b8@news.povray.org>
As reported in p.g, POV-Ray 3.5 does not read PPM files properly.
The proper format is
P6
width height
max_value
data
The POV reader expects the max_value on the same line as the width and
height.  If you don't want to patch POV-Ray, you can edit the PPM files
to make them work in POV.
Here's a patch to fix it. I only spent a short time on this, so it's
probably still broken but it loads the files that I've tried.
PoD.
Download 'us-ascii' (2 KB)
