POV-Ray : Newsgroups : povray.binaries.images : Cutty Sark Server Time
1 May 2026 07:14:08 EDT (-0400)
  Cutty Sark (Message 33 to 42 of 60)
Subject: Re: Cutty Sark
Date: 26 Nov 2025 21:30:00
Message: <web.6927b755392cce9138e9762c7597fb06@news.povray.org>
Slowly moving forward.
The three hatches are done, and the folk onboard can go to the loo.
Now on to the poop-deck.
Ton.
Download 'forum_011.jpg' (53 KB)
Preview of image 'forum_011.jpg'
Date: 4 Dec 2025 10:15:00
Message: <web.6931a48e392cce916925ea730225ff5@news.povray.org>
> Cheers
> Ton.
Great, always gets a little more finished :)
I'm also building a ship, but a spaceship.
I can't get any further with it, not enought time.
Maybe I should post pictures regularly like you, to push myself forward.
Ma
Date: 5 Dec 2025 00:40:00
Message: <web.69326efc392cce9138e9762c7597fb06@news.povray.org>
> Ma
Thanks Mates, one step at a time...
Why don't you post images of your work in progress? It is a motivation.
Ton
Date: 13 Dec 2025 22:15:00
Message: <web.693e2aa8392cce9138e9762c7597fb06@news.povray.org>
The poop deck is coming along nicely.
Ton
Download 'forum_012.jpg' (77 KB)
Preview of image 'forum_012.jpg'
Date: 15 Dec 2025 06:40:00
Message: <web.693ff28c392cce91475fba6a6cde94f1@news.povray.org>
hi,
indeed :-).  is there much work to be done before you can "plant" the masts ?
regards, jr.
Date: 24 Dec 2025 17:55:00
Message: <web.694c6f33392cce9138e9762c7597fb06@news.povray.org>
Hi all,
here is a in-between to show the progress of the poop deck.
Thanks jr. There is still a lot to do before the masts get placed.
The bell and compass on the poop deck, the rudder wheel, the railing along the
stern.
The two deck houses, with the lifeboats on top.
Several deck winches, fife rails....
It will be a while.
This is the last update this year.
A merry Christmas everybody and all the best wishes for 2026!
Ton
Download 'forum_013.jpg' (142 KB)
Preview of image 'forum_013.jpg'
Date: 24 Dec 2025 22:35:00
Message: <web.694cb0b0392cce911f9dae3025979125@news.povray.org>
> stern.
I modeled a naval bell to honor clipka's father.
It's yours if you'd like to use it.
I have a compass rosette kicking around somewhere as well.
If that helps you get that much farther.
Great work as always. :)
Merry Christmas.
#version 3.8;
global_settings {assumed_gamma 1.0 }
 location <0, 2, -8>
 up y
 look_at <0, 0, 0>
light_source {<1, 2, -5> rgb 1 shadowless}
sky_sphere {pigment {rgb 1}}
#declare bellSpline = array [12] {
     < 3.4688, 0.0001>,
     < 3.4688, 0.0002>,
     < 3.0938, 0.4375>,
     < 2.9375, 0.6250>,
     < 2.4844, 1.3438>,
     < 2.1719, 2.6094>,
     < 2.0469, 4.4688>,
     < 1.9063, 4.6875>,
     < 1.7500, 4.8750>,
     < 1.0313, 5.0938>,
     < 0.0001, 5.1563>,
     < 0.0001, 5.1564>
// braided rope handle
#declare Lines = 5;
#declare Pitch = 2;
#declare Degree = (1/360);
#declare Rad = 0.002;  // sphere radius
#declare Dia = Rad * 2;
#declare Cycles = 1;
#declare Freq = 1;
#declare R1 = 0.05; // radius of large spiral
#declare A = 0.01; //radius of small spiral
//#declare B = 1.5;
#declare H = 0.002; //large spiral pitch smaller = tighter
#declare W = 8; // pitch of small spiral - how many cycles around one loop
#declare C = 0.01; // amplitude of undulation 1
#declare U = 0.1;  // undulation 2
#declare STEPS = 0.002*10;
#declare Strand1 = union {
 #for (i, -(Cycles/2)*360, (Cycles/2)*360, STEPS)
  #declare R = R1+(C*sin(U*i));   // adds undulation to cylindrical braid
  #local Angle = Degree * i;
  #local j = i + 45;     /// rotates green strand 45 deg from red
  #local Helix1_X = (R+A*cos(W*i))*cos(i);
  #local Helix1_Z = (R+A*cos(W*i))*sin(i);
  sphere {<0, 0, 0> Rad translate <Helix1_X, (H*i), Helix1_Z>} //weave
 #end // end for i
} // end union
#declare Strand2 = union {
  #local Helix2_X = (R+A*cos(W*j))*sin(j);
  #local Helix2_Z = (R+A*cos(W*j))*cos(j);
  sphere {<0, 0, 0> Rad translate <Helix2_X, (H*i), Helix2_Z>} //weave
 #end // end for i
} // end union
#declare AllStrands = union {
 #for (k, 1, W, 2)
  object {Strand1 rotate y*k*(360/W)}
  object {Strand2 rotate y*k*(360/W)}
 #end // end for k
#declare Handle = object {AllStrands texture {pigment {rgb 1} normal {bumps
0.01}} scale 2};
#declare arraySize = dimension_size (bellSpline, 1)-1;
#declare Rad = 0.1;
#declare Xmax = 0;
#declare Ymax = 0;
#declare Bell1 =
union {
 cylinder {<0, 0, 0>, <0, (5.0938/2)+1, 0> 0.125}
 sphere {0, 0.25}
 torus {0.125, 0.125/4 rotate x*90 translate -y*0.25}
 object {Handle translate -y*1}
 sor {
     arraySize+1,
  #for (B, 0, arraySize)
  #local NewSpline = bellSpline [B]/2;
  //#debug concat ("B = ", str (B, 3, 1), "| Point = ", vstr (2, bellSpline [B],
",", 5, 1), "\n")
  #declare Xmax = max (Xmax, NewSpline.x);
  #declare Ymax = max (Ymax, NewSpline.y);
  NewSpline,
     open
     sturm
 //texture { T_Gold_1B }
 //texture { mtex }
 pigment {rgb <1, 1, 0>}
object {Bell1}
Date: 25 Dec 2025 04:50:00
Message: <web.694d07f0392cce9138e9762c7597fb06@news.povray.org>
Thanks for the Christmas present, Bald Eagle.
On the forecastle deck is also a bell, which I modeled a couple of months ago
(see attachment), but I think your bell has more of a bell shape then mine.
So you might see your bell hanging in Cutty Sark.
All the best sir.
Ton
Download 'forum_014.jpg' (106 KB)
Preview of image 'forum_014.jpg'
Date: 25 Dec 2025 09:55:00
Message: <web.694d4f84392cce9152af7e976cde94f1@news.povray.org>
hi,
> Hi all,
now ringing the bell..  </grin>
and, in the spirit, a peaceful and productive year 2026 to you, Ton, and to you,
POV-Ray users everywhere.
regards, jr.
Date: 25 Dec 2025 11:05:00
Message: <web.694d6011392cce914eb3f9d830225ff5@news.povray.org>
> Hi all,
Great progress, as always.
How about some water under the keel?
Don't know if the lines look good with your sky, but they could be a start.
plane {
<0,1,0>, 0
pigment { rgb <0.2, 0.2, 0.2> transmit 0}
normal { bumps 0.08 scale <1,0.35,0.35> turbulence 0.16 }
finish { ambient 0.05 diffuse 0.55 brilliance 6.0 phong 0.8 phong_size 120
reflection 0.6 }
translate <0,0, 0>
also best wishes to all for 2026.
ma
