POV-Ray : Newsgroups : povray.binaries.images : Chain library Server Time
18 Oct 2025 08:37:00 EDT (-0400)
  Chain library (Message 1 to 3 of 3)
Subject: Chain library
Date: 25 Mar 2025 12:50:00
Message: <web.67e2ddadccfeb8f1a40969eb5cc1b6e@news.povray.org>
In a continued spate of library development, I took a bunch of disparate code I
had written for chains used in other scenes and consolidated it into a library I
call libchain.inc.
The new library provides a number of macros for describing links, chains
consisting of one or more types of links, and chain layouts consisting of a set
of connected links.
I have provided a sample chain definition in library/chains/samples.inc that is
used in the demo scene Examples/chain_test.pov.
The chain layout macros borrowed from rope_sys.inc but I had to modify the
overall approach because chain links don't behave the way small segments of rope
do.  But, the library contains macros for adding single links, straight segments
of links, slack segments of links, catenaries, splines, and spirals.  They are
also written to allow specifying optional modifications to the positions of
individual chain links and their rotation.  There are still some bugs I haven't
chased down when using some of these offset functions for the coil, for example.
 TBD.
The image below creates a chain that begins with a straight segment from the
floor to a point near the cylinder, then wraps around the cylinder N+0.5 times,
and then drops straight to the floor again.  There is then a spline segment for
the chain on the floor where I changed the default link rotation function to
something that a chain resting on a flat surface would fall into.  There is then
a straight link to the top of the first pole, (no attempt to avoid intersecting
with the poles), a slack segment to the second pole, and a catenary to the last
pole.
Other work to come; code to drape a chain over an object, more tests and fixes
to the layouts with variations in the link offsets, more chain link examples,
including chains with multiple types of links.
As usual, the code can be pulled from my GitHub repository:
https://github.com/carath63/povlibrary.
-- Chris R
Download 'chain_test.png' (802 KB)
Preview of image 'chain_test.png'
Subject: Re: Chain library
Date: 25 Mar 2025 13:40:00
Message: <web.67e2ea62b19a970ecc5c2a9bf712fc00@news.povray.org>
> call libchain.inc.
> of connected links.
Interesting. I already downloaded it. Need to compare it with an file I know I
have somewhere that does the similar thing.
Found it! Links Created by Chris Colefax, 20 April 1998
Date: 28 Apr 2025 08:55:00
Message: <web.680f7a2fb19a970eb00a87a025979125@news.povray.org>
> call libchain.inc.
> -- Chris R
This is pretty nice.
I do recall the the rope system, as well as numerous attempts to write robust
catenary macros.
For whatever reason, I recently began digging back into the catenary curve, and
it's truly surprising how little I am able to look up in terms of solving for
regularly spaced points along the arc-length of the curve (which is obviously
needed to create chain links, etc.
I have a whole pile of code that makes bad catenary curves, and a few good
snippets that make a proper catenary that passes through 2 <x, y> points.
I have code that evaluates the integral for arc-length L.
But nothing that I'd dare claim was comprehensive or robust.
I'm not sure how much you copy-pasted, and how much you re-derived, but it would
be nice to have a didactic diagramming of the catenary that shows the roles of
a, b, c, x, and how the arc-length gets evenly subdivided.
I can fill in the idle hours with making the actual scene, etc.  I just need
quality equations and a good understanding of why they work (and ideally why
mine _don't_)
Looking forward to seeing more renders of new features.  :)
- BW
