POV-Ray : Newsgroups : povray.binaries.images : Helical SDF for Isosurfaces Server Time
14 Jul 2025 11:00:26 EDT (-0400)
  Helical SDF for Isosurfaces (Message 15 to 24 of 24)
Subject: Re: Helical SDF for Isosurfaces
Date: 24 Dec 2024 08:15:00
Message: <web.676ab2ea4a98c6d63bc22bca25979125@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> Hey guys, what I'm seeing is that this and the original version of Theta look
> the same in the isosurface-- or else I'm totally mistaken about what B.E.'s
> original problem was?? I thought it was the truncated spirals in -x, where they
> abruptly stop at y=0. Take a look at my comparison image.
> Sorry if I totally misunderstood the problem(?)
Nope - you got it.
I had a few spare minutes last night and pasted Chris' fix into my scene and it
worked as claimed.
Maybe start with a fresh copy of my scene and make the minimum necessary
correction.
(comment out my Theta function, and just paste Chris' 2 functions in after
that.)
I'm guessing that you have something in your scene that snuck in that you
haven't undone.
- BW
Date: 24 Dec 2024 09:40:00
Message: <web.676ac6794a98c6d6e83955656e066e29@news.povray.org>
> Nope - you got it.
> worked as claimed.
> correction.
> that.)
> haven't undone.
Interesting! I need to take another look at that. Admittedly, my eyes and brain
were starting to fuzz over from hours of 'ultra concentration' (although I
thought I double-checked everything before posting...)
Meanwhile...
I came up with this little change for your own code, using 'clamp'. It might be
considered a 'hack', but it solves two problems at once: no more truncated
spirals; and the rifling is now continuous in both +x and -x (with no glitch at
x=0.)
#declare Helix = function {select (mod (Theta(clamp(x,0,1.0),y,z),
                 tau/3) - tau/6, 0.25, 0.35)}
Limitations:
clamp's 'max' value needs to be 1.0 (or any integer multiple of 1.0; it doesn't
seem to matter.) But no fractional part.
The first tau's divisor: any integer of 1.0 or greater, no fractional part.
The second tau's divisor can be anything > 1.0, any float value.
Download 'rifling_for_be_3__kw.jpg' (261 KB)
Preview of image 'rifling_for_be_3__kw.jpg'
Date: 24 Dec 2024 10:15:00
Message: <web.676acf024a98c6d63a6dfc485cc1b6e@news.povray.org>
> "Chris R" <car### [at] comcastnet> wrote:
> > I got it to work by making the following change:
> > #declare natan2 = function(a,b) { select(a, 2*pi+atan2(a,b), atan2(a,b)) }
> > #declare Theta = function {((natan2 (y, z))/pi)*tau + x*tau}
> > The problem is that atan2 has that discontinuity where it jumps from pi/2 to
> > -pi/2, which happens along the edge you are looking at, and is made visible by
> > the switch in sign of the x value (x*tau).  The natan2 puts that discontinuity
> > at opposite ends of the value range, rather than in the middle and makes all of
> > the resulting angles positive (0-2*pi), and thus there is no abrupt switch when
> > x goes negative.
> > -- Chris R
> Most Excellent, fine Sir!
> Some days I can see what needs to be done - other days it's more . . . opaque.
> I'm officially voting that such be made an internal function, or at least
> something available in functions.inc
> This could save a lot of people a lot of trouble in the future.
> Thank you,
> - BW
No problem.  I don't know how many times I have been tripped up by how atan2
works.
If you grab my libfn.inc from GitHub, https://github.com/carath63/povlibrary I
have defined f_normalized_atan2(x,y) already.  It would be good to have as a
builtin in a future version of pov-ray, but in the meantime, if you are using
any of my code in your scenes, it is already defined there.
-- Chris R
Date: 24 Dec 2024 21:10:00
Message: <web.676b683e4a98c6d61da4838d89db30a9@news.povray.org>
> -pi/2, ...
Hi Chris
I think that should be "from +pi to -pi".
I would also suggest that you define your new atan2() function like this;
#declare natan2 =
    function(a, b) {
        atan2(a, b) + select(a, 2*pi, 0)
It makes what happens a little bit clearer at the expense of an extra addition.
Tor Olav
http://subcube.com
https://github.com/t-o-k
Date: 24 Dec 2024 22:20:00
Message: <web.676b78d74a98c6d61da4838d89db30a9@news.povray.org>
> > -pi/2, ...
> Hi Chris
> #declare natan2 =
>     function(a, b) {
I just noticed that both these variants have a little problem:
They have a discontinuity at a = -0
natan2(+1e-100, -1) = +3.141592653589793
natan2(     +0, -1) = +3.141592653589793
natan2(     -0, -1) = -3.141592653589793
natan2(-1e-100, -1) = +3.141592653589793
This variant does not have this problem:
#declare natan2 =
    function(a, b) {
        mod(atan2(a, b) + 2*pi, 2*pi)
Tor Olav
http://subcube.com
Date: 26 Dec 2024 10:00:00
Message: <web.676d6eaf4a98c6d64d6accde5cc1b6e@news.povray.org>
> > > -pi/2, ...
> > Hi Chris
> > #declare natan2 =
> >     function(a, b) {
> #declare natan2 =
>     function(a, b) {
> Tor Olav
> http://subcube.com
Good catch!
I actually modified f_normalized_atan2 as follows:
#declare f_normalized_atan2 = function(x,y) {
    select(x,
        tau + atan2(x,y),
        pi,
        atan2(x,y)
It's infinitesimally more efficient because you don't have to calculate
atan2(+/-0,N), and gets rid of the mod arithmetic and addition where it isn't
needed.
-- Chris R
Date: 26 Dec 2024 13:30:00
Message: <web.676d9f804a98c6d672cba4c589db30a9@news.povray.org>
> Good catch!
>     select(x,
>         tau + atan2(x,y),
>         pi,
>         atan2(x,y)
> needed.
Sorry Chris,
It looked promising, but f_normalized_atan2(0, 1) returns pi instead of 0.
Rewriting it like this will solve that problem:
    function(x, y) {
        select(
            x,
            atan2(x, y) + 2*pi,
            select(y, pi, 0),
            atan2(x, y)
Note that all these rewrites of the atan2() function does not trigger a "Domain
error", like atan2(0, 0) does when called outside a function.
Tor Olav
http://subcube.com
Date: 26 Dec 2024 21:05:00
Message: <web.676e0a8e4a98c6d63ecca46d89db30a9@news.povray.org>
Below are the results of some atan2-tests I just did.
Some constants:
  pi/2 = 1.570796326794897
  pi   = 3.141592653589793
3*pi/2 = 4.712388980384690
2*pi   = 6.283185307179586
tau = 2*pi
Z = 1e-100
Here the functions are given valid arguments:
The results for atan2() are all in the closed interval [-pi, +pi]
atan2(-0, -1) = -3.141592653589793
atan2(-Z, -1) = -3.141592653589793
atan2(-1, -Z) = -1.570796326794897
atan2(-1, -0) = -1.570796326794897
atan2(-1, +0) = -1.570796326794897
atan2(-1, +Z) = -1.570796326794897
atan2(-Z, +1) = -0
atan2(-0, +1) = -0
atan2(+0, +1) = +0
atan2(+Z, +1) = +0
atan2(+1, +Z) = +1.570796326794897
atan2(+1, +0) = +1.570796326794897
atan2(+1, -0) = +1.570796326794897
atan2(+1, -Z) = +1.570796326794897
atan2(+Z, -1) = +3.141592653589793
atan2(+0, -1) = +3.141592653589793
Atan2_Fn =
    function(a, b) {
        mod(atan2(a, b) + tau, tau)
The results for Atan2_Fn() are all in the half-open interval [+0, +tau)
Atan2_Fn(-Z, +1) = +0
Atan2_Fn(-0, +1) = +0
Atan2_Fn(+0, +1) = +0
Atan2_Fn(+Z, +1) = +0
Atan2_Fn(+1, +Z) = +1.570796326794897
Atan2_Fn(+1, +0) = +1.570796326794897
Atan2_Fn(+1, -0) = +1.570796326794897
Atan2_Fn(+1, -Z) = +1.570796326794897
Atan2_Fn(+Z, -1) = +3.141592653589793
Atan2_Fn(+0, -1) = +3.141592653589793
Atan2_Fn(-0, -1) = +3.141592653589793
Atan2_Fn(-Z, -1) = +3.141592653589793
Atan2_Fn(-1, -Z) = +4.712388980384690
Atan2_Fn(-1, -0) = +4.712388980384690
Atan2_Fn(-1, +0) = +4.712388980384690
Atan2_Fn(-1, +Z) = +4.712388980384690
n_atan2 =
    function(a, b) {
        atan2(a, b) + select(a, tau, 0)
The results for n_atan2() should all be in the half-open interval [+0, +tau)
n_atan2(-Z, +1) = +6.283185307179586  <--- NB
n_atan2(-0, +1) = +0
n_atan2(+0, +1) = +0
n_atan2(+Z, +1) = +0
n_atan2(+1, +Z) = +1.570796326794897
n_atan2(+1, +0) = +1.570796326794897
n_atan2(+1, -0) = +1.570796326794897
n_atan2(+1, -Z) = +1.570796326794897
n_atan2(+Z, -1) = +3.141592653589793
n_atan2(+0, -1) = +3.141592653589793
n_atan2(-0, -1) = -3.141592653589793  <--- NB !!!
n_atan2(-Z, -1) = +3.141592653589793
n_atan2(-1, -Z) = +4.712388980384690
n_atan2(-1, -0) = +4.712388980384690
n_atan2(-1, +0) = +4.712388980384690
n_atan2(-1, +Z) = +4.712388980384690
    function(a, b) {
        select(
            a,
            atan2(a, b) + tau,
            select(b, pi, 0),
            atan2(a, b)
The results for f_normalized_atan2() are all in the half-open interval [+0,
+tau)
f_normalized_atan2(-Z, -1) = +3.141592653589793
f_normalized_atan2(-0, -1) = +3.141592653589793
f_normalized_atan2(+0, -1) = +3.141592653589793
f_normalized_atan2(+Z, -1) = +3.141592653589793
f_normalized_atan2(-Z, +1) = +6.283185307179586  <--- NB
f_normalized_atan2(-0, +1) = +0
f_normalized_atan2(+0, +1) = +0
f_normalized_atan2(+Z, +1) = +0
f_normalized_atan2(+1, -Z) = +1.570796326794897
f_normalized_atan2(+1, -0) = +1.570796326794897
f_normalized_atan2(+1, +0) = +1.570796326794897
f_normalized_atan2(+1, +Z) = +1.570796326794897
f_normalized_atan2(-1, -Z) = +4.712388980384690
f_normalized_atan2(-1, -0) = +4.712388980384690
f_normalized_atan2(-1, +0) = +4.712388980384690
f_normalized_atan2(-1, +Z) = +4.712388980384690
Here the functions are given invalid arguments:
Atan2 =
    function(a, b) {
        atan2(a, b)
Atan2(-0, -0) = -3.141592653589793
Atan2(-0, +0) = -0
Atan2(+0, +0) = +0
Atan2(+0, -0) = +3.141592653589793
Atan2_Fn =
    function(a, b) {
Atan2_Fn(+0, +0) = +0
Atan2_Fn(+0, -0) = +3.141592653589793
Atan2_Fn(-0, -0) = +3.141592653589793
Atan2_Fn(-0, +0) = +0
n_atan2 =
    function(a, b) {
n_atan2(+0, +0) = +0
n_atan2(+0, -0) = +pi
n_atan2(-0, -0) = -pi  <--- NB !!!
n_atan2(-0, +0) = +0
    function(a, b) {
        select(
            a,
            atan2(a, b) + tau,
            select(b, pi, 0),
            atan2(a, b)
f_normalized_atan2(+0, +0) = +0
f_normalized_atan2(-0, +0) = +0
f_normalized_atan2(-0, -0) = +0
f_normalized_atan2(+0, -0) = +0
When looking at the results from both the valid and invalid arguments, it seems
to me that POV-Ray's built in atan2() gives the most consistent results,
followed by Atan2_Fn().
Tor Olav
http://subcube.com
Date: 27 Dec 2024 09:30:00
Message: <web.676eb94a4a98c6d6a40969eb5cc1b6e@news.povray.org>
> Some constants:
> tau = 2*pi
> Z = 1e-100
> atan2(-Z, +1) = -0
> atan2(-0, +1) = -0
> atan2(+0, +1) = +0
> atan2(+Z, +1) = +0
> Atan2_Fn =
>     function(a, b) {
> n_atan2 =
>     function(a, b) {
>     function(a, b) {
>         select(
>             a,
>             atan2(a, b) + tau,
>             select(b, pi, 0),
>             atan2(a, b)
> +tau)
> Atan2 =
>     function(a, b) {
>         atan2(a, b)
> Atan2(-0, +0) = -0
> Atan2(+0, +0) = +0
> Atan2_Fn =
>     function(a, b) {
> n_atan2 =
>     function(a, b) {
>     function(a, b) {
>         select(
>             a,
>             atan2(a, b) + tau,
>             select(b, pi, 0),
>             atan2(a, b)
> Tor Olav
> http://subcube.com
Nice analysis of the various options!
I have adopted your updated f_normalized_atan2, which I find works well with my
isosurfaces.  Others may have different expectations and use a different
implementation.
My question would be, (and I should look at the pov code at some point to
check), when an isosurface is being evaluated, are there cases where -0 is
supplied to the isosurface function?
-- Chris R
Date: 28 Dec 2024 06:32:04
Message: <676fe1b4$1@news.povray.org>
Might be. It depends on the function(s) being used in the isosurface and
what x,y,z values you might see given, environmental-usage of the
isosurface. Also, potentially, on the build compile for the executable.
Using the f_boom() inbuilt in the yuqk fork:
//--- Should be the f_sphere() version of this will run in v3.8 beta 2
#version 3.8;
#include "functions.inc"
isosurface {
     function { f_boom(x/-2,y,z,0/-2,0,0) }
   //function { f_sphere(x/-2,y,z-1,0.1) }
     contained_by { box { -2.0,2.0 } }
     threshold 0
     accuracy 0.0005
     max_gradient 1.1
     finish { emission 1.0 }
f_boom
1(x) -> -0,
2(y) -> 0,
3(z) -> 0,
4(0) -> -0,
5(1) -> 0,
6(2) -> 0
Bill P.
