POV-Ray : Newsgroups : povray.binaries.images : Allchin traction engine Server Time
15 Sep 2024 12:26:23 EDT (-0400)
  Allchin traction engine (Message 11 to 19 of 19)
Subject: Re: Allchin traction engine
Date: 16 Mar 2024 03:40:00
Message: <web.65f54bfb1a42083b9a328caa7597fb06@news.povray.org>
> Op 16/03/2024 om 02:35 schreef Ton:
> > And another one:
> Musing: It must be great fun to drive such an engine! Especially
> compared to modern cars...
> Thomas
It will be hard work. You have to keep the fire going, the brake is a leather
belt! Steering is with a chain around the front axle, no springs, and it is
slow.
Have you ever seen Fred Dibnah on his traction engine?
Date: 16 Mar 2024 04:11:47
Message: <65f55443@news.povray.org>
Op 16-3-2024 om 08:36 schreef Ton:
>>> And another one:
>> Thomas
> slow.
Oh yes! I am aware of the difficulties and I remember Fred Dibnah
indeed. However, that is all the (boy scout) fun, and you get an idea
about how things work and are controlled (or not). Modern cars are
convenient and comfortable, but they have become too complex to be
understood by us, simple mortals. My 2CV was the last car I thought I
understood and could repair myself (to a certain degree); but that is
something from far back in the 20th century already and is a completely
different story...
Date: 16 Mar 2024 19:35:00
Message: <web.65f62c871a42083b1f9dae3025979125@news.povray.org>
"Ton" <ton### [at] gmailcom> wrote:
> I couldn't find a Povray equivalent, so I
> want to create a Bolt macro, and a Nut macro. I found already that f_helix2()
> creates a good looking thread. Then throw a selectable head on top and done!
https://news.povray.org/povray.general/thread/%3C875zph8073.fsf%40munyer.com%3E/?ttop=437822&toff=200
Date: 17 Mar 2024 18:55:00
Message: <web.65f774321a42083b9a328caa7597fb06@news.povray.org>
That looks a lot like what I have already. I use f_helix2(). Being a former
software engineers I take your comments seriously about "magic", hard-coded
numbers, so I'll avoid them. Make the code as clear as possible!
Here is a sneak preview:
Ton.
Download 'nutsboltstest.png' (182 KB)
Preview of image 'nutsboltstest.png'
Date: 17 Mar 2024 20:50:00
Message: <web.65f78f121a42083b1f9dae3025979125@news.povray.org>
Likely.  I just remembered that short thread and figured I'd mention it, if it
would help any.
Yeah, I've suffered from not being able to easily understand my own code due to
doing that sort of thing all to often.
That looks great.  :)
If you watch machining channels like Inheritence Machining, Clickspring, or This
Old Tony, most shop-made threads are cut with dies or single-point threading
tools on a lathe.
Mass-produced threads are rolled, which interestingly enough yields better
threads since they are work-hardened.
I guess where I was going with that, is that all of those operations leave tool
marks and patterns on the surface of the metal, and you could probably make some
really nice renders of just a pile of screws if you added a radial normal
perturbation or something like that to the threads.
What you have now would probably make a good threading on nylon or Delrin type
material.
- BW
Date: 18 Mar 2024 07:05:00
Message: <web.65f81ec91a42083b875a37746a8f0b95@news.povray.org>
> Hello again,
> after ten months I've finished my Allchin traction engine model. The used
> drawings are by Julius de Waal
> (https://www.modelengineeringwebsite.com/Allchin_1_4_scale.html). The details of
> these drawings are quite good (it's 27 sheets after all!). It was fun doing
> this, figuring out how to SDL all the parts.
> Cheers
> Ton.
Wow, that is attention to detail. Amazing modelling, do you have plans to put
this into a scene or just the challenge of creating the model is enough?
Sean
Date: 19 Mar 2024 02:20:00
Message: <web.65f92e121a42083b1686e436cde94f1@news.povray.org>
hi,
> > > I couldn't find a Povray equivalent, so I ...
Mike Miller posted code last year.
<https://news.povray.org/povray.binaries.images/thread/%3Cweb.6446dab9a70a9db41f9dae3025979125%40news.povray.org%3E/>
regards, jr.
Date: 20 Mar 2024 19:05:00
Message: <web.65fb6acf1a42083b9a328caa7597fb06@news.povray.org>
> Sean
I'll leave it as it is, Ten months is long enough.
The model is inside a museum, so people can admire it.
About my nuts and bolts, it is not my intention to make a close-up render of
them. I want to use them in machines and other stuff that's bolted together. I
probably don't need too much detail.
Ton.
Date: 26 Mar 2024 16:35:39
Message: <6603319b$1@news.povray.org>
Hi(gh)!
The same goes for computers: just compare a Commodore 64 to any
desktop/laptop/tablet/smartphone of 2024...
> understood
The perfect choice for travelling the Hippie Trail! The only
Afghanistan-worthy compact car ever built!
See you in Khyberspace!
Yadgar
VBI BENE, IBI BACTRIA!
