![](/i/fill.gif) |
"Chris R" <car### [at] comcast net> wrote:
> "Samuel B." <stb### [at] hotmail com> wrote:
> > Hi,
> > It's like regular Truchet tiles, but the cells are subdivided, and subsets of
> > tiles are selected for each level of scale [...]
> Very cool! I'd be interested in seeing the code at some point.
> (Starts going down rabbit hole on Truchet tiles...)
> -- Chris R.
Hi Chris, thank you.
Truchet tiles are pretty versatile (:J) and simple at their most basic level.
But the multi-level stuff can complicate things a bit.
If you've got a compatible device (recent-ish PC or smart phone) you can search
Truchet tiles on Shadertoy.com to see what things other people have done. Crazy
stuff.
Anyway, here's the entire code, sans glare:
Multi-level-Truchet.pov
2023 Sam Benge
More tile types are possible but not yet implemented; the TilesSm, TilesMd and
TilesLg arrays can be expanded as needed.
Command line options:
+fn +f +a0.03 +am2 +r3
#version 3.7;
global_settings{assumed_gamma 1.0}
/*-- Settings --*/
#declare RenderSingleArea = false;
#declare RandomThreshold = 0.33; // (0.0-1.0)
#declare RandomSeed = 1003;
#declare TorusThickness = 0.2;
#declare GlobalTranslate = <-6.7, 0, -14.5>;
#declare UseFocalBlur = true;
#declare FocalBlurSamples = 10;
#declare SunDir = <1, .7, .5>;
#declare RGBSun = srgb 1.5*<2, 1.95, 1.9>;
#declare RGBSky = srgb .5;
#declare CamPos = .75 * <4, 15, -20>;
/*-- End Settings --*/
#default{ finish{ambient 0} }
#include "transforms.inc"
camera{
fisheye
right x*.7 up y*.7/1.77
location CamPos
look_at 0
angle 120
#if(UseFocalBlur)
aperture 1 focal_point 0 blur_samples FocalBlurSamples variance 0
// sky
#if(1)
sky_sphere{
pigment{
spherical
scale 2
translate y
poly_wave 4
Point_At_Trans(SunDir)
color_map{
[0 RGBSky]
[1 RGBSun]
// torus macros
#macro TorusQuarter(R1, R2)
#local Eps = 0.001;
torus{
R1, R2
clipped_by{box{<0, -R2-Eps, 0>, R2+Eps+<R1, 0, R1>}}
#macro TorusHalf(R1, R2)
#local Eps = 0.001;
torus{
R1, R2
clipped_by{plane{-z, 0}}
// some torus quarter and torus half objects
#declare TQ1 = object{TorusQuarter(1, TorusThickness)}
#declare TQ3 = object{TorusQuarter(3, TorusThickness)}
#declare TH1 = object{TorusHalf(1, TorusThickness)}
// small tiles
#declare TilesSm =
array[2]{
union{
object{TQ1 translate <-1, 0, -1>}
object{TQ1 rotate y*180 translate <1, 0, 1>}
union{
cylinder{-x, x, TorusThickness open}
cylinder{-z, z, TorusThickness open}
// medium tiles
#declare TilesMd =
array[3]{
union{
object{TQ1 translate <-2, 0, -2>}
object{TQ1 rotate y*90 translate <-2, 0, 2>}
object{TQ1 rotate y*180 translate <2, 0, 2>}
object{TQ1 rotate y*270 translate <2, 0, -2>}
union{
object{TH1 translate <0, 0, -2>}
object{TH1 translate <0, 0, -2> rotate y*90}
object{TH1 translate <0, 0, -2> rotate y*180}
object{TH1 translate <0, 0, -2> rotate y*270}
union{
object{TQ3 translate <-2, 0, -2> rotate y*180}
cylinder{-2*x, 2*x, TorusThickness open translate z}
cylinder{-2*z, 2*z, TorusThickness open translate x}
// large tiles
#declare TilesLg =
array[4]{
union{
object{TQ1 translate <-4, 0, -4>}
object{TQ1 rotate y*90 translate <-4, 0, 4>}
object{TQ1 rotate y*180 translate <4, 0, 4>}
object{TQ1 rotate y*270 translate <4, 0, -4>}
object{TH1 translate <0, 0, -4>}
object{TH1 translate <0, 0, -4> rotate y*90}
object{TH1 translate <0, 0, -4> rotate y*180}
object{TH1 translate <0, 0, -4> rotate y*270}
union{
object{TH1 translate <-2, 0, -4>}
object{TH1 translate <2, 0, -4>}
object{TH1 translate <-2, 0, -4> rotate y*90}
object{TH1 translate <2, 0, -4> rotate y*90}
object{TH1 translate <-2, 0, -4> rotate y*180}
object{TH1 translate <2, 0, -4> rotate y*180}
object{TH1 translate <-2, 0, -4> rotate y*270}
object{TH1 translate <2, 0, -4> rotate y*270}
union{
object{TQ3 translate <-4, 0, -4>}
object{TQ1 translate <-4, 0, -4> rotate y*90}
object{TQ3 translate <-4, 0, -4> rotate y*90}
object{TQ1 translate <-4, 0, -4> rotate y*180}
object{TQ3 translate <-4, 0, -4> rotate y*180}
object{TQ1 translate <-4, 0, -4> rotate y*270}
object{TQ3 translate <-4, 0, -4> rotate y*270}
union{
// place variously-sized tiles into main array
#declare Tiles = array[3]{TilesLg, TilesMd, TilesSm}
// basic ground tile color
#declare GroundCol = <.55, .5, .65>;
// teture macro for ground tiles
#macro Texture(Col)
texture{
pigment{rgb Col}
normal{granite .1 scale .001}
finish{reflection{.5, 1 falloff 2 metallic 1} }//diffuse 0}
// ground tile macro
#macro Tile(Size)
height_field{
function Size*16, Size*16 {
pigment{
boxed
scale 1/2
translate (x+y)/2
color_map{
[0 rgb 0]
[.2/Size rgb 1]
smooth
translate -(x+z)/2
scale <2*Size, .1, 2*Size>
translate - y*.1
// Ground tiles. They must be declared before being placed into arrays because
of the texture macro.
#declare GT1 =
object{
Tile(4)
Texture(.75 * GroundCol)
#declare GT2 =
object{
Tile(2)
Texture(.50 * GroundCol)
#declare GT3 =
object{
Tile(1)
Texture(.25 * GroundCol)
// place ground tiles into array
#declare GroundTiles = array[3]{GT1, GT2, GT3}
// random integer
#macro rint(A) floor(A*rand(Seed)) #end
// the Truchet tile-subdivision macro
#macro Iterate(I, S, Pos)
// four diagonal directions
#local Dir = array[4] {<-1, 0, -1>, <1, 0, -1>, <-1, 0, 1>, <1, 0, 1>}
// if iteration value more than equals zero
#if(I>=0)
// test against threshold and iteration value
#if(rand(Seed)<RandomThreshold & I>0 | I=3)
// place new Iterate macros
#for(A, 0, 3)
Iterate(I-1, S/2, Pos+S*Dir[A])
#else
// place the objects
#local ID = max(0, 2-I);
// Truchet tile
object{
Tiles[ID][rint(dimension_size(Tiles[ID], 1))]
rotate y*90*rint(2)
translate Pos
// ground tile
object{
GroundTiles[ID]
translate Pos-y*TorusThickness
// a random seed
#declare Seed = seed(RandomSeed);
// render objects
union{
// render just one subdivided tile
#if(RenderSingleArea)
Iterate(3, 4, <0, 0, 0>)
translate -GlobalTranslate
// render a bunch of subdivided tiles along the x and z axes
#else
// a point of interest
sphere{y*2, 2 translate <4, -.19, 12>}
// loop over x & z axes and place tiles
#for(Z, -2, 7)
#for(X, -7, 7)
union{
translate 16*<X, 0, Z>
// a golden texture
texture{
pigment{rgb <.6, .4, .2>}
finish{reflection{ 1 metallic 1}}
// translate object
translate GlobalTranslate
![](/i/fill.gif) |
