POV-Ray : Newsgroups : povray.binaries.images : brain_attack.jpg Server Time
18 Oct 2025 14:34:52 EDT (-0400)
Subject: brain_attack.jpg
Date: 5 Aug 2023 14:25:00
Message: <web.64ce92f84166a563c9deb24ddabc9342@news.povray.org>
Brain Attack pulp style cover using brain bots, pipes and tanks. Looking closer
to a '70's magazine cover than the late 50's pulp book. Added text and stylized
in Photoshop. Final rendering done in 16K to get better line/edge effect in PS.
Miller.
Download 'brain_attack.jpg' (2715 KB)
Preview of image 'brain_attack.jpg'
Subject: Re: brain_attack.jpg
Date: 6 Aug 2023 10:41:53
Message: <64cfb131$1@news.povray.org>
Op 5-8-2023 om 20:20 schreef Mike Miller:
> Miller.
I love this! Also your separate "how to" images which, by the way, show
the same graphic quality as the finished product. And same applies to
your sketches too.
Date: 6 Aug 2023 11:00:00
Message: <web.64cfb4e2a73d0cdfc6193942edfc8715@news.povray.org>
> Miller.
Wow that's awesome Mike, It all came together great!
Date: 6 Aug 2023 12:30:00
Message: <web.64cfc99aa73d0cdfc9deb24ddabc9342@news.povray.org>
> > Miller.
Thanks.
It's a fun theme/art style to work on. Old sci-fi cover art inspires me - the
campier the better. :) Below is a link to some really early covers.
Mike.
https://www.pulpmagazines.org/pulp-magazines-to-read/
Date: 7 Aug 2023 17:25:00
Message: <web.64d160d7a73d0cdff8c47d526e741498@news.povray.org>
> Miller.
/It Came From a Lab!/ (and without proper authorization)
It's looking great, Mike! It could possibly benefit from a half-tone effect,
imo, to give it a magazine cover look. And perhaps greater atmospheric
perspective to make the foreground pop a bit more.
Are you using any reflection blurring? UberPOV supports it, but it's really slow
to render. I sometimes entertain the idea of making my own fork of UberPOV to
allow the number of blur samples to be set to a lower value, in order for them
to be multiplied by camera blur samples and AA whilst keeping the render times
lowish. But it's probably a lot of work...
Anyway, I'm looking forward to see what you produce next!~
Sam
Date: 7 Aug 2023 22:00:00
Message: <web.64d1a079a73d0cdf1f9dae3025979125@news.povray.org>
> Miller.
Pretty cool PS post-render effects.
I'm wondering what can be done in that respect directly in POV-Ray,
but also wondering if you could make a few ancillary renders that are in that
black-and white pen/line-drawing cross-hatched style of illustration to make a
few companion scenes.
- BW
Date: 7 Aug 2023 22:10:00
Message: <web.64d1a2f9a73d0cdfc9deb24ddabc9342@news.povray.org>
> > Miller.
> Sam
Thanks,
I'm not using reflection blurring but might be able to fake it a bit in post.
Rendering times could be a problem. I'm rendering in multiple passes with and
without reflections to control the art effects/edging. I'm looking at adding
more atmosphere/effects as I flush these out. I have a bit a gas leak effect
in the attached view. I'll be adding more background to this one... work in
progress. :)
Yes, a half-tone effect! ...I might play with that and maybe some chromatic
aberrations. I also have some distress maps for aging that might work well to
add some vintage.
Best regards,
Mike.
Download 'brain_attack_2.jpg' (1410 KB)
Preview of image 'brain_attack_2.jpg'
Date: 8 Aug 2023 00:15:00
Message: <web.64d1a9a2a73d0cdfc9deb24ddabc9342@news.povray.org>
> > Miller.
> - BW
Thanks,
Good thought...I'll run a few and upload for comparison. If I had a large format
printer, I could hand draw the edges and shading as a vellum overlay
- overtop of the printed POV rendering.
Not sure how to get the edge and cel-shade look directly from POV. Yesbird was
working on some type of POV cartoon shader look, I think?
Attached is styled with posterized shadows with a 1/2 tone process dot per Sam's
suggestion - thanks Sam. I'm liking the comic book feel. I also removed the
reflection pass to reduce the busyness, especially in the pipes. Will continue
to play with this.
Mike.
Download 'brain_attack_posterized.jpg' (2049 KB)
Preview of image 'brain_attack_posterized.jpg'
Date: 8 Aug 2023 15:30:00
Message: <web.64d296efa73d0cdf1f9dae3025979125@news.povray.org>
There are things like Canny edge detection, as well as better and more refined
versions of convolution kernels (Sobel operator, etc.)
Not sure about cel shading (might try things like the Anisotropic Kuwahara
Filter, etc.) - what I was suggesting is more a hatching-style shading of the
image, such as used in the old Hardy Boys, Nancy Drew, Tom Swift... (see
attached)
Download 'monochrome_be_sketch.png' (615 KB)
Preview of image 'monochrome_be_sketch.png'
Date: 8 Aug 2023 17:30:00
Message: <web.64d2b36ea73d0cdff8c47d526e741498@news.povray.org>
> > > Brain Attack pulp style cover using brain bots, pipes and tanks. [...]
> > I'm wondering what can be done in that respect directly in POV-Ray, [...]
One idea for the outlines is to build a new object out of several copies, like
so (I attached an image of the result):
#declare Obj =
 union{
  #local W = .3;
  #local Obj_ =
   merge{
    cylinder{-x, x, W}
    sphere{-x, W}
    sphere{x, W}
  object{Obj_}
  object{Obj_ rotate y*90}
  object{Obj_ rotate z*90}
// object without outlines
object{
 Obj
 pigment{rgb .7}
// outlines
merge{
 // change these two things
 #local NPts = 8;
 #local LineThickness = 0.03;
 // golden spiral points on sphere
 #local Inc = pi * (3 - sqrt(5));
 #local Off = 2 / NPts;
 #local Seed = seed(1001);
 #for(K, 0, NPts-1)
  #local Y = K * Off - 1 + (Off / 2);
  #local R = sqrt(1 - Y*Y);
  #local Phi = K * Inc;
  object{
   Obj
   translate LineThickness*<cos(Phi)*R, Y, sin(Phi)*R>
 texture{pigment{rgbt 1}}
 interior_texture{pigment{rgb 0}}
 interior{ior 1.0001}
 no_shadow
 no_reflection
^That technique requires some things to be merged.
Another idea is to keep using whatever post-process effect you have been using
up til now, but feed it a simpler image without reflections, shadows, etc. Maybe
give it an image rendered with +q0 or something. The problem with that, however,
is some areas will not have lines because the adjacent colors will be the same.
The only fix I know for that is to give different areas slightly different
colors, so that the line algorithm has something to work with. (I hope that
makes sense ;P)
> to play with this.
> Mike.
It's looking good!
Sam
Download 'basicobjectoutline.jpg' (18 KB)
Preview of image 'basicobjectoutline.jpg'
