POV-Ray : Newsgroups : povray.binaries.images : New WIP Server Time
2 Jun 2024 10:12:44 EDT (-0400)
  New WIP (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: New WIP
Date: 18 Jun 2022 07:55:00
Message: <web.62adbc63ba1cac86b0d648f25cc1b6e@news.povray.org>
> Op 18/06/2022 om 04:47 schreef Chris R:
> > "Chris R" <car### [at] comcastnet> wrote:
> >> I went back and did some more work generalizing the code I use to create brick
> >> walls, and some new code I wrote to create concrete sidewalks.  The new code
> >> includes the ability to create American and English spanning layouts for bricks,
> >> but still uses isosurfaces with brick pigment functions.
> >> The tufts of grass are generated using parts of the makegrass.inc macros from
> >> Gilles Tran.
> Good work, especially for the bricks. Something I like less are
> fractures through the concrete. Those need to be "smoother" in their
> "irregularity" if you understand what I mean. :-)
> Thomas
Thanks.  The early versions of the fractures were too smooth, and I probably
went a bit overboard.  I'll play with dialing it back.
-- Chris R.
Date: 20 Jun 2022 06:55:00
Message: <web.62b0514fba1cac8616086ed06830a892@news.povray.org>
> > Gilles Tran.
> > -- Chris R.
> This time with the image!
> -- Chris R.
The floor looks great !  I think the light is too desaturated,
omnidirectional/ambient. Having a sun-like spot/direct light lower at the
horizon and grazing more from the side would reveal more of the specularity of
bricks and concrete (which should be quite low intensity less than 0.2 but high
roughness /size and diffuse multiplier should also be lower to let it reveal).
For realism possibly with a slightly warmer temperature than the sky sphere
lightbouncing through radiosity if you like that mood?
Date: 25 Jun 2022 23:45:00
Message: <web.62b7d62dba1cac864ebf5035cc1b6e@news.povray.org>
> > Gilles Tran.
> > -- Chris R.
> -- Chris R.
I made some updates after resolving some issues noted in the "transparent box"
thread.  I have another version where I tried to show tendrils of steam rising
from the sidewalk, the way a wet sidewalk would look in the heat of the day, but
they looked more like streaks of rain, which didn't match the fact that the sun
was out in the rest of the image, so I took them out.  I left some media fog
right on the sidewalk, though.
-- Chris R.
Download 'scene-v1.1-hq-rad11-2022-06-25b.png' (1242 KB)
Preview of image 'scene-v1.1-hq-rad11-2022-06-25b.png'
Date: 26 Jun 2022 02:15:30
Message: <62b7f982$1@news.povray.org>
Op 26/06/2022 om 05:44 schreef Chris R:
I like it. Starting to look like my unkempt garden. ;-)
Date: 27 Jun 2022 07:20:00
Message: <web.62b99192ba1cac8616086ed06830a892@news.povray.org>
> > > Gilles Tran.
> > > -- Chris R.
> > -- Chris R.
> -- Chris R.
This media fog effect is really interesting ! And the flower in the middle
really takes on some awesome dramatic composition through its lighting.
(there's still an issue with lack of perceptible finish for the red bricks. and
it's the only issue now. I believe it would help a lot since they take up so
much space in the image)
Date: 27 Jun 2022 09:55:00
Message: <web.62b9b5a0ba1cac864ebf5035cc1b6e@news.povray.org>
bricks,
> > > > Gilles Tran.
> > > > -- Chris R.
> > > -- Chris R.
> > -- Chris R.
Thanks!  The sun in this scene was positioned to cause the triangular highlight
on the limestone block and light the downspout.  I placed the flower to face the
sun as well.  However, that essentially puts the sun just behind the wall, so
the face doesn't get lit by it except by ambient light.
If I could think of a logical reason for there to be another light source that
would show off the bricks, I'd add it in.  I suppose I could try changing the
time of day a little bit to get the sun just in front of the wall, and hope I
don't lose the interesting highlight on the block.
-- Chris R.
Date: 27 Jun 2022 19:45:00
Message: <web.62ba4060ba1cac861f9dae3025979125@news.povray.org>
Reflection off another wall.   Like a white concrete wall.
Or a white gravel or sand area of ground.
Just add it in..   ;)
Date: 28 Jun 2022 02:06:38
Message: <62ba9a6e$1@news.povray.org>
Op 27/06/2022 om 15:50 schreef Chris R:
You probably did already, but turning normal to 'on' in the radiosity
block could improve this.
Date: 28 Jun 2022 04:25:00
Message: <web.62baba94ba1cac8616086ed06830a892@news.povray.org>
brick
bricks,
from
> > > > > Gilles Tran.
> > > > > -- Chris R.
> > > > -- Chris R.
> > > -- Chris R.
> -- Chris R.
I expected that was the reason. very reasonable and indeed not braking the
quality of light on the main subject is hard, but would become easier with a
third lighting (sky being one with radiosity and your current sun the second). I
think Bald Eagle's suggestion can be a good possibility, there might even be
some glass windows (/ shop's display?) on that wall or cars from the street
reflecting hotter points ? In any case, if the most tolerable variation to you
(whichever you end up chosing) appears to not be enough to bring some realism to
that texture, maybe the texture is the culprit? even if itsn't I think the
finish could still be worked upon to maximize it : e.g. by having some sand
grain sized freckles acting more in normal than pigment,
injecting something like normal {wrinkles 0.75 scale 0.1} inside what you
currently have
Using rather phong (below 0.25) than specular, and diffuse with albedo keyword
such as:
diffuse albedo 0.65
....and lowering the brilliance parameter a little below 1.0 to really simulate
an Oren nayar shader of maximal sigma and roughness material as such minerals
should be. (also check that this finish ambient value is left to zero)
Date: 29 Jun 2022 16:00:00
Message: <web.62bcae85ba1cac86833fbc6f5cc1b6e@news.povray.org>
brick
code
bricks,
from
> > > > > > Gilles Tran.
> > > > > > -- Chris R.
> > > > > -- Chris R.
but
sun
> > > > -- Chris R.
> > -- Chris R.
> currently have
> such as:
> diffuse albedo 0.65
Thanks for the suggestions; I'll play around with some of them when I get back
to this scene.  (I am off in another direction at the moment.)
I did try advancing the time of day by an hour.  It changes the scene, some in
good ways, some in bad, but still wasn't enough to really light the bricks up.
I'll look at the brick finish elements again, and also check my radiosity
settings when I get back to it.
-- Chris R.
