POV-Ray : Newsgroups : povray.binaries.images : using 'object pattern' as media Server Time
3 Mar 2026 09:03:30 EST (-0500)
  using 'object pattern' as media (Message 12 to 21 of 23)
<<< Previous 10 Messages Goto Latest 10 Messages Next 2 Messages >>>
Subject: Re: using 'object pattern' as media
Date: 30 Apr 2022 17:25:00
Message: <web.626da6deac9c0ae18d86850a6e066e29@news.povray.org>
This object-pattern/media technique has another interesting use, a practical
one: It can show where a mesh or mesh2 object has any 'holes' in it (i.e., not a
completely 'closed' mesh.)
I used the mesh2 Bunny model again to show this effect. I removed my intersected
box object that I applied to seal up its few holes on the bottom, then rotated
the model to better show what happens.
The direction of the 'extra' media sticking out from the bottom is oriented
along the inside_vector that I chose, <1,1,1>. The faint sphere is my overall
media container.
I used scattering media here, but emission media performs just as well, and
renders much faster.
In effect, the object pattern can be thought of as a 'leaking-gas detector' ;-)
Download 'object_pattern_as_mesh_hole_detector.jpg' (29 KB)
Preview of image 'object_pattern_as_mesh_hole_detector.jpg'
Date: 30 Apr 2022 18:10:00
Message: <web.626db3a3ac9c0ae11f9dae3025979125@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
 Oh, I get it now.
> There are two aspects of this problem that initially threw me off: The docs
> about bezier_patches repeatedly refer to 'triangles', as if the patch or model
> is converted to a smooth-triangle mesh 'under the hood'. At least, that's what I
> took to be the meaning there... which is probably a misconception on my part(?).
It converts it to smooth triangles, but not a mesh object.
One has to remember that the path through the code to the render is different
for each and every type of primitive.  They may look the same, they may be
thought of as functionally equivalent, but they are separate and distinct
things.
I've run into that fast-and-loose "they're the same in my head" issue myself:
https://news.povray.org/povray.binaries.scene-files/message/%3C57b5bf9c%241%40news.povray.org%3E/#%3C57b5bf9c%241%40new
s.povray.org%3E
So, if you read the monograph (thread), William Pokorny confirms that POV-Ray
does indeed convert the bicubic patch object into smooth triangles at some point
in the processing, but it does not get converted into a proper mesh {} object.
Which is why I knew we'd have to go about this "the manual way".
- Walker, New Hampshire Ranger
Date: 1 May 2022 02:08:21
Message: <626e23d5$1@news.povray.org>
Op 30/04/2022 om 23:20 schreef Kenneth:
Yes, very good. By itself, this image has a very high surrealistic
(Magritte!) flavour. :-)
Date: 1 May 2022 06:55:00
Message: <web.626e6645ac9c0ae18d86850a6e066e29@news.povray.org>
Ha! You're right, and I did not even 'see' that-- the usual problem of being
'too close' to one's own work. :-\
It just needs a man wearing a suit plus a bowler hat... :-P
Date: 1 May 2022 10:21:51
Message: <626e977f$1@news.povray.org>
Le 2022-04-29 à 12:32, Kenneth a écrit :
> Here is another example, using a different and more complex set-up of the code--
> with 'solid' high-density emission + absorption medias rather than scattering.
> This one uses the object pattern as a 'pigment' (not a density)-- with some
> 'Bunny artwork' as the main pigment there. Some image-to-functions-to-pigment
> operations were required for its final use in the media, mainly because I used
> the 'once' keyword for the artwork image_map.
> For the art, I found a photo on Google that looked *somewhat* like the pose of
> the Stanford Bunny, then used my paint.net app to clone and shift various parts
> around so that the image covered the model as projected from the front. Even
> though the art is just a 2-D image_map, it projects through the entire media, so
> its colors are 'in depth' throughout the Bunny. Then I added a fake shadow under
> the model :-)
> BTW, the Stanford Bunny mesh2 model is not quite a closed mesh-- it has some
> holes on its bottom surface-- so I simply made an intersection of it with a
> larger and well-placed box object, which solidified those holes. Interestingly,
> this also eliminated the need for the model to have an inside_vector (for the
> media appearance.)
> I made several animations of this example which I will post at
> binaries.animation; they rendered *much* faster than my aborted scattering-media
> version, in about 1/10 the time (but with no lighting interaction of course).
Bottom two images... Poor bunny.
Date: 1 May 2022 10:31:03
Message: <626e99a7$1@news.povray.org>
> The other odd thing during my render trials is that POV-ray *seems* to be
> evaluating my bicubic_patch model 'successfully' in the same way it treats the
> Bunny model-- that is, the render likewise slows down while evaluating the media
> container shape, and the render times are about identical. Except that no
> media-effect is produced. This behavior made me blame the problem simply on the
> 'missing inside_vector.'
The patch IS converted into smooth triangles, but, as an union of
triangles, not as a mesh.
The various triangles do not have any inside, they are just infinitely
thin surfaces.
Date: 7 May 2022 17:00:00
Message: <web.6276dab9ac9c0ae12eadabda6e066e29@news.povray.org>
> I plan to post the basic code for these examples...
Here are the basics for the most simple kind of example, using just scattering
media. A light_source is required to show this type of media in the best way, of
course.
BTW, the docs says that the object used for the object pattern must not have a
texture, but that does not matter. The texture is simply ignored.
#declare OBJ = ...object...  // to be used as the object pattern. Mesh and mesh2
require an inside_vector. CSG works too, but all of the parts should be
'merged' rather than in a union.
#declare OBJ_PATTERN =
density{
   object{
         OBJ
        // For the following two entries, full pigments are not allowed when
        //'density' is used for the pattern:
        // FIRST entry: everywhere OUTSIDE the 'object' shape
        rgb 0.0 // 0 means NO media density-- i.e., no visible media there
        // SECOND entry: INSIDE the object shape
        rgb 1.0  // 1 means 'full density' in the media
                warp{turbulence...}
// the required media container
sphere{...  // or box, etc.
hollow
pigment{rgbt 1} // or rgb 1 transmit 1
interior{
     media{
           scattering{1, multiplier * <...color...> extinction...}
        // I used 16*<1,1,1> extinction 0.5
        // emission ...
        // absorption ...
        //method 3
        //intervals 1
          samples ...
          aa_level ... // 4 is the default
          density{OBJ_PATTERN}
rotate ...
translate...
} // end of container object
Date: 7 May 2022 17:10:00
Message: <web.6276dfe8ac9c0ae12eadabda6e066e29@news.povray.org>
> Here are the basics for the most simple kind of example...
Be aware that the object pattern can reproduce an object that is anywhere in
space-- but will then create the pattern *at* that location. So it is probably
best to center your object at the origin, create the pattern and media in the
container there, *then* translate the whole thing.
Date: 11 May 2022 17:55:31
Message: <627c30d3$1@news.povray.org>
Il 28/04/2022 23:29, Kenneth ha scritto:
 > POV-ray's 'object pattern' is a really useful feature-- but the
single 'pigment'
 > example in the docs does not do it justice, IMO. It can instead be
used as
 > density for media, which is not mentioned there. Searching through
newsgroup
 > posts from the past, I could not find a reference to such a use. For
months, I
 > have been experimenting and testing this 'discovery'.
I absolutely love this technique. I tried something similar a few years
a go, but my results were not convincing so I had given up.
Very very interesting,
   Paolo
Date: 12 May 2022 19:00:00
Message: <web.627d8ffeac9c0ae12eadabda6e066e29@news.povray.org>
Thank you Paolo.
Here is another example, just emission media. I used an old CSG human model that
I made years ago (all of its parts are 'merged' for use as the  object-pattern).
I first made a CSG difference of it with a slightly smaller-scaled version, to
create a very thin 'shell'. When heavy warp{turbulence...} is applied, it looks
like wispy tendrils that are volumetric in 3-D. I had to use a very high
'samples' value for this.  The result looked like a nebula-- so I added a
spaceship! The background is a darkened photo of a real nebula.
I made an animation of this, with the camera moving through the media. I will
post it to my previous newsgroup thread in p.b.animations.
Download 'nebula_construction.jpg' (108 KB)
Preview of image 'nebula_construction.jpg'
