Hi Ton
My previous message had been cut off
I've done something like that (with Basileus Base, NeMatollah Vali Slope with
120 degree twist but I was not able to find a correct texture
Philippe
Op 16-10-2021 om 09:14 schreef Mediat:
> Hi Thomas
>> OK. Fair enough.
> I have an idea and I'll let you know if it works
>> The main problem is that - even when doing that - the lower rollouts,
>> when opened, are only partly visible.
> At my place, it works, may be it's because my screen resolution is 1920 x 1080,
> what is yours ?
> Best regards
> Philippe
My resolution is the same. I attach a (scaled-down 50%) screenshot with
'Sharpening' opened, to illustrate.
Download 'domenatorscreen.jpg' (114 KB)
Preview of image 'domenatorscreen.jpg'
Op 16-10-2021 om 10:06 schreef Thomas de Groot:
>> Hi Thomas
>>> OK. Fair enough.
>> 1920 x 1080,
>> what is yours ?
>> Best regards
OK, I hit 'send' a bit too fast. I remembered that I can scale up or
down the screen content. My default is 125% (the 'recommended' value for
my laptop) which I also prefer for my old eyes. Setting scale to 100%...
solves the problem! Everything is a bit tiny as far as I am concerned,
but at least visible.
Problem solved! :-)
> Problem solved! :-)
Good to ear !
I'm working on something, I'll let you know
Philippe
Hi Ton
Here is an example of Cupcake, made of 2 Domes.
Need a bit of work on textures
Philippe
Download 'cupcake.jpg' (40 KB)
Preview of image 'cupcake.jpg'
Domenator continues to look more and more impressive! I still have not
downloaded it, but plan to do so.
> > [Thomas wrote]
> > The Domenator window needs a possibility to scroll up or down.
> Unfortunately I use GLUI as a library to handle the user interface, and it lacks
> many things, the possibility to scroll a window is one of them..
I do not know anything about GLUI, but it looks like v2.3 at Sourceforge
includes a 'widget' to create scroll sliders. I have attached a screenshot.
Download 'glui_2_point_3.jpg' (80 KB)
Preview of image 'glui_2_point_3.jpg'
Hi Kenneth,
Thanks a lot, I will have a look ...
Hi Kenneth,
Unfortunately this GLUI scrollbar is just that a scrollbar that do nothing else
; it can be used as an input widget butnotto actually scroll a window
Philippe
Slightly improved topping (always on ly 2 domes
Download 'cupcake2.png' (272 KB)
Preview of image 'cupcake2.png'
Yes, this sea-urchin is a Dome
Download 'seaurchin.jpg' (35 KB)
Preview of image 'seaurchin.jpg'
