![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Norbert Kern" <nor### [at] t-online de> wrote:
> The figures are excellent - i love them...
Thanks Norbert!
> I dont like the structure and the material - you made materials much more
> elaborate than this...
Well, ancient aliens apparently have a very different design aesthetic!
No, seriously, I'm thinking of doing another version with something else there
instead. I've been working on a simple spaceship...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
"Kenneth" <kdw### [at] gmail com> wrote:
> ... I can't even get
> a *basic* experiment with a matrix to work in v3.8xx for Windows:
> #declare MY_MATRIX =
> transform{
> matrix
> <1,1,1,
> 1,1,1,
> 1,1,1,
> 0,0,1>
> .... with or without a semi-colon at the end. "Fatal error in parser:
> uncategorized error"
> So I must be doing something basically wrong-- or else my syntax is incorrect,
> although I don't see where.
the problem must be elsewhere, the syntax is correct, tried it on (Linux,
self-compiled) alpha.10064268.
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 20/02/2021 om 02:41 schreef Robert McGregor:
> Thomas de Groot <tho### [at] degroot org> wrote:
>> Excellent! And Thanks for the detailed explanation; I shall note that
>> carefully down for future study and use. The pose rig is particularly
>> interesting for me. I have done some of this in Poser and there it is -
>> not difficult - but demanding a close attention. How is this in Blender?
>> more straightforward? Somehow, I guess it needs a close attention there too.
> Thanks Thomas. The posing in Blender is pretty straightforward, it just takes
> time to get all the bones in situated properly within the mesh. I spent about 3
> hours building the rig and trying various poses.
Yes, that is pretty close to what Poser needs too. I good incentive to
explore that direction again.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > ... I can't even get a *basic* experiment with a matrix to work
> > incorrect, although I don't see where.
Thanks.
That's strange, though; I just ran my matrix code snippet in v3.7.1 beta 9
(Windows), and it fails there as well, same error.
But I found the cause (at least for Windows builds): It's the matrix vector
values themselves that I used-- which I chose blindly, as just some combination
of 0's and 1's! Thinking that any combination would work for a simple syntax
test; apparently a bad idea. :-[
So I substituted the example values given in POV-ray's "matrix" docs...
matrix < 1, 1, 0,
0, 1, 0,
0, 0, 1,
0, 0, 0 >
....and the #declared transform now runs without an error.
I guess it's not good to play around with things that I don't yet fully
understand ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> That's a wonderful scene, very mysterious and evocative. And thanks for sharing
> the details of your techniques, plus the image of the various assets you used.
Thanks Kenneth, I appreciate that.
> That idea gave me some thoughts about my recent post regarding AA problems with
> very bright objects, where AA fails for those bright pixels (Thanks!) So I put
> together something similar(?) to your idea: Rendering a scene the normal way,
> then bringing the image back into POV-ray and doing an
> image-to-function-to-pigments conversion on it (all 3 color channels). Then
> re-combining (using 'average') those 3 pigment functions-- with simple but
> proper r-g-b color_maps-- to re-create the image as before. At this point, I
> discovered that I could change the color_maps' index values to effectively
> mask-off (as black) any pixels over a certain 0-1 brightness threshold... like
> your idea. Great, so far!
Yes, this sounds very much like what I did (which was orginally inspired by
reading your bright pixels AA problems post and pondering ways to fix that!)
> This is the 2nd part of my task. I looked up 'gaussian blur', and I see that it
> involves matrix use in some way. I'm still a rank beginner when it comes to
> manipulating matrices, but aside from that small problem (ha), I can't even get
Okay, I didn't use a matrix in that sense, i.e., the matrix keyword as used for
transformations. I just built my own Gaussian smoothing matrix using a 2d array,
like this (note the symmetry):
#declare ConvolutionKernel = array[5][5] { // Smoothing matrix
{1, 4, 7, 4, 1},
{4, 16, 26, 16, 4},
{7, 26, 41, 26, 7},
{4, 16, 26, 16, 4},
{1, 4, 7, 4, 1}
This small kernel (matrix) represents pixel weights, and the central element
(with the highest value) is the calculation target, an average of all the
surrounding pixel colors. In a nutshell it works like this:
Place the center weight of the kernel (41 in this case) on an image pixel. The
colors of all pixels under the matrix (from the original image, as sampled from
the function pigment) are multiplied by the overlapping kernel pixel weights,
and the results of all pixels are all added together into a final summed color.
Each kernel weight that is multiplied against a pixel color is added to an
overall matrix sum (at image borders not all weights will have pixels under
them). An average color for the central pixel is then calculated as: summed
color divided by the matrix sum.
Move the center of the kernel to the next pixel and iterate the process until
all pixels have been assigned averaged colors. At that point the averaging has
blurred the image, in this case the 5x5 matrix gives a 3-pixel blur (see
attached sample image, left is a magnified 60x60 test image and right is the
blurred convolution result).
Doing it this way is a *slow* process, especially in SDL, because for a
1920x1080 pixel image the are 2 million+ pixels, and each needs to be averaged
with (for the most part, except edges) 24 neighboring pixels, for an estimated
48 million samples and calculations.
Download 'convolveexample.png' (1219 KB)
Preview of image 'convolveexample.png'
![convolveexample.png](/povray.binaries.images/attachment/%3Cweb.60311917a906d8e387570eab0%40news.povray.org%3E/convolveexample.png?ttop=438403&toff=150&preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> {1, 4, 7, 4, 1},
> {4, 16, 26, 16, 4},
> {7, 26, 41, 26, 7},
> {4, 16, 26, 16, 4},
> {1, 4, 7, 4, 1}
Yes, it's a mathematical "matrix" - but with what we're doing with it, it's
implemented as an _array_ in code. Not many working parts under the hood for
doing matrix math at the moment.
So I guess "array processing algorithm" would most clearly describe the
operation.
I did similar here:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.5e9e3e93521c7ab7fb0b41570%40news.povray.org%3E/?ttop=432310
&toff=50
And probably for the Fast Fourier Transform and other places where I needed the
matrix structure to accomplish what I wanted.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > ...So I put together something similar(?) to your idea: Rendering a scene
> > the normal way, then bringing the image back into POV-ray and doing an
> > image-to-function-to-pigments conversion on it (all 3 color channels)...
Ha! This is what I love about the newsgroups here: similar ideas feeding off of
each other, to find a common solution.
> > involves matrix use in some way...
> used for transformations.
Yes, I had a half-formed idea that this might be the case. Honestly, I had no
real idea as to how I was going to proceed with a 'typical' matrix, if I could
even get the darn thing to run ;-)
> {1, 4, 7, 4, 1},
> {4, 16, 26, 16, 4},
> {7, 26, 41, 26, 7},
> {4, 16, 26, 16, 4},
> {1, 4, 7, 4, 1}
[clip]
Ah, the key! That's brilliant and elegantly simple. I shall experiment with it.
Thanks again for your willingness to share, and for your clear comments.
Here's an alternate 'brute force' idea for finding / masking off pixels in an
image that go over a certain brightness limit: Years ago, I wrote some code
using eval_pigment to go over each and every pixel of a pre-rendered image, then
storing all of those found color values in a 2-D array. (Or alternately, just
the brightest pixel values according to a particular threshold, and their x/y
positions in the image). The final step was to 're-create' the image by
assigning each original pixel's color-- or black, as the case may be-- to a tiny
flat box or polygon in an x/y grid. For example, an 800X600 re-created image
would be made of 480,000 tiny box shapes! Crude but effective.
But a more elegant solution to this 'many boxes' idea would be to take all of
the arrays' eval_pigment color values (and positions in the image), and somehow
shove them into a FUNCTION of some sort-- to ultimately be applied as a *single*
pigment function to a single flat box. But HOW to do this has always eluded me.
In other words, how can a single function be 'built' using a repetitive
iteration scheme-- other than by assigning each and every pixel color to its own
initial pigment function, then combining/adding(?) all of the 480,000 functions
into 1 for the final image output?? (Which by itself leaves out the *positions*
of the individual pixels, another major problem.)
Can such a pigment function be built piece-by-piece-- in a #for loop, for
example-- AND in correct final order of the pixels? I was wondering if you have
ever devised a scheme to do something like this.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Kenneth" my namesake, wrote:
> ...take all of
Because it's hiding under you nose - under the hood.
It the image_map "function" that is all shoved into ... one pigment pattern.
Throughout all of my experiments over the years, I've used POV-Ray to help teach
myself math, and computer graphics, which has helped me learn about POV-Ray, and
what actually goes on (or is supposed to go on) under the hood.
I dabble in ShaderToy because there is no (or very little) "under the hood".
You have to write it all yourself. And that dispels the illusions of things
like light source, shadows, camera, 3D space.... it's all just "one function"
that evaluates to a certain rgb value at every x,y position of the screen, or
image file.
So how does a function work?
We take <x, y, z> and plug those into the function, which computes a color
value.
But you could also pre-calculate the color values, and store them - in a file -
to reference when you're looping through all of the position values - and that's
called an image file. That gets implemented via the pigment {image_map} syntax.
Because IIRC POV-Ray even has a mechanism whereby you can "render" something in
memory and use that as an image_map style thing, without even rendering it, or
saving it to an image file first.
Now, you could manually construct a function as a giant polynomial that
intersects all the right rgb values given the right xyz values --- but that's
just encoding the image file data into an equation - which is probably wasteful
of effort, time, and storage. But it's also likely the kind of thing that _I'd_
be likely to do, in order to learn how to do it, prove that it's possible, and
possibly learn another dozen things and raise 34 more questions in the process.
You likely don't have to store ALL of the image data, if a lot of it is the same
- and then you can write a function, or an algorithm that encodes a lot of data
with - less data. That is image compression.
In the 80's, I was making a world map on an Atari 800 XL, and it seemed silly to
store EVERY "pixel" of the map, when I was only dealing with 2 colors, and I had
long stretches of same-color pixels. So I defined them as "lines" (or "boxes")
and just saved the starting point and the length. Like assembling a hardwood
floor.
So how does one take 48,000 boxes and color them all with one function?
union {
.... all your boxes ...
pigment {image_map}
All those boxes get immersed into the region where the image_map correlates to
the 3D space coordinates. It creates a 1:1 correspondence - a look-up table - a
function - that does what you'd essentially be doing from scratch, or through a
roundabout way with a hand-written function.
At least that's how it all works in my head at this point in time. There may
be some nuances and POV-Ray specific source code things that don't quite work in
exactly that way... but I hope this helps you "wrap your head around it"?
- Bill
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> [snip]
> value.
> file-- to reference when you're looping through all of the position values -
> and that's called an image file. That gets implemented via the pigment
> {image_map} syntax.
Yeah, I guess that my 'dream scheme' of...
trace --> eval_pigment --> a SINGLE function{pigment...} [somehow?]
....is kind of an attempt to mimic what goes on 'under the hood'... a sort of
'reverse engineering' scheme, devised in SDL.
The seemingly effortless way that POV-ray itself can take an image_map and turn
it into a single function{pigment...}-- with all of the original pixels in the
correct order-- is like Black Magic to me.
> wasteful of effort, time, and storage.
Yeah, those little caveats did occur to me. :-[
I agree: My hoped-for scheme seems to be not-so-elegant after all. Compared to
that, my older scheme of...
trace --> eval_pigment --> 480,000 colored boxes
.... suddenly looks like an elegant and simple stroke of genius! :-P
> union {
> pigment {image_map}
Yes, very straightforward-- once my single and way-too-elaborate function itself
is created! But I guess I need to discard my eval_pigment idea itself as
unworkable (i.e., initially evaluating every *individual* pixel of an input
image, to ultimately create some sort of single function to represent all the
colors and pixel positions.)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > [snip]
> > value.
> > {image_map} syntax.
But what you're essentially doing is exactly that. Because there is no
"function" - it's a look-up table - reading in the color values for each x,y
pixel in the image. It's simply the fact that it's done under the hood, via
compiled source code, that makes it seem "different".
povray-3.7-stable/povray-3.7-stable/source/backend/support/imageutil.cpp
bool image_map(const VECTOR EPoint, const PIGMENT *Pigment, Colour& colour)
int reg_number;
DBL xcoor = 0.0, ycoor = 0.0;
// If outside map coverage area, return clear
if(map_pos(EPoint, ((const TPATTERN *) Pigment), &xcoor, &ycoor))
colour = Colour(1.0, 1.0, 1.0, 0.0, 1.0);
return false;
else
image_colour_at(Pigment->Vals.image, xcoor, ycoor, colour, ®_number,
false);
return true;
"If the x,y position is outside of the image area, return a clear value, else
return the color of the image at that x,y value."
No function. Just an algorithm in a loop.
Why? Can we even count the number of software packages that can do that?
What about a movie player that can read them in fast enough to give you greater
than 15 fps?
I've done that kind of the opposite way - tracing objects, and converting the
height to a color value, but I realized it was just as easy to do with a
gradient pigment pattern...
Now, what I have wanted, and suggested in the past, is for there to be a
mechanism by which the compiled source code stores all the color data for an
image file in an SDL-accessible 2D array. Which would kinda give you what you
want without all of the mucking around.
> > union {
> > pigment {image_map}
what about function {pigment {image_map}} ?
And I guess I should point out that _form_ follows _function_.
What do you want to do with the function once you've got it, that you need to
have it in function form?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
