POV-Ray : Newsgroups : povray.binaries.images : city buildings-- WIP 9_29_2020 Server Time
29 May 2024 07:14:38 EDT (-0400)
  city buildings-- WIP 9_29_2020 (Message 11 to 20 of 49)
Subject: Re: city buildings-- WIP 9_29_2020
Date: 30 Sep 2020 16:20:03
Message: <web.5f74e7d832341a55d98418910@news.povray.org>
"BayashiPascal" <Pas### [at] BayashiInJapannet> wrote:
> You may find some useful resource for collision detection here:
https://gamedevelopment.tutsplus.com/tutorials/collision-detection-using-the-separating-axis-theorem--gamedev-169
Wow! That's quite complex for my poor brain-- but I will *try* to follow along.
Unfortunately, it looks like some of the visual 'demos' are missing(?)
> In your case, the objects are axis-aligned as far as I can see...
Yes, basically a '2-dimensional' field of greeble objects, all at simple
90-degree angles.
> ...so AABB collision detection may even be sufficient. Have a look here too:
> https://manbeardgames.com/tutorials/aabb-2d-collision-checks/
Thanks; I'll check that out as well.
Date: 30 Sep 2020 16:25:06
Message: <web.5f74e8cf32341a551b6c6b3a0@news.povray.org>
"Kenneth" <kdw### [at] gmailcom> wrote:
> At the rate I'm going, my *own* city may forever remain unfinished, ha. Ideas
> beget more ideas, etc. etc. But great fun nevertheless-- and a useful learning
> process, as always.
It's all about the journey, not the destination.
*achieves nirvana*
Date: 30 Sep 2020 16:50:05
Message: <web.5f74ee3232341a55d98418910@news.povray.org>
> > I still don't know the algorithm or technique for placing randomly-located
> > objects that don't overlap, each object having its own space...
> You can store objects in an array, and check each new one against existing
> positions and bounds, for example in dodgy pseudocode:
[snip]
> Alternatively, you can subdivide your region of interest, then pick a single
> random location in each sub-region. This has the advantage of not requiring
> extensive looping and testing, although subdivision might be non-trivial. For
> rectangles it's not too bad.
> If your objects are all roughly the same sort of size, you can lay a grid
> down, perturb the grid positions by some distance smaller than the grid
> spacing, then place objects at the perturbed grid positions. Using only
> a subset of the grid positions makes it look more random.
 Thanks a bunch! You've given me some good ideas to pursue. Btw, while trying to
come up with workable schemes 'on my own', I'm happy to say that the
grid-subdivision idea(s) did occur to me at various times, in rather fuzzy
ways-- but I didn't follow up on them. :-( It's nice to know that I wasn't too
far off in my thinking.
And it looks like POV-ray's  min_extent(...) and   max_extent(...) tools will be
useful here, especially since my greebles are of various sizes and shapes.
Date: 30 Sep 2020 18:15:01
Message: <web.5f7502f432341a551b6c6b3a0@news.povray.org>
Happy tinkering!
Don't forget that min_ and max_extent() might not return useful bounds for CSG
objects. It could be a good idea to manually bound your greebles if this is an
issue.
Date: 30 Sep 2020 20:55:00
Message: <web.5f75280d32341a551f9dae300@news.povray.org>
> issue.
Right - but assuming you get a good bounding of the objects (check out jr's
work, and my incomplete attempt(s) )
then perhaps you can use the size of the bounding box of the intersection
between two objects - and let POV-Ray do the heavy lifting.
if there's no intersection, then how big is the bounding box of the intersection
0 or NAN, or...
Date: 1 Oct 2020 02:56:20
Message: <5f757d94@news.povray.org>
Op 30/09/2020 om 22:17 schreef Kenneth:
> 90-degree angles.
I think there is a fairly simple way, close to what Bill suggested, by
using (1) random placement on the roof and (2) if more objects are to be
placed to test collisions using the inside(O,V) function. You may need
to provide a bit more room around the existing object O and the new
object by using test objects just a little larger than those you are
going to place.
Date: 1 Oct 2020 03:07:33
Message: <5f758035$1@news.povray.org>
Op 30/09/2020 om 21:40 schreef Kenneth:
>> The buildings seems tightly packed. Simply "forgetting" to place some of them
>> would help breaking the monotony too, as there would be spaces for
>> parking lot, park, etc... in a real city.
> That's a great idea, thanks! It did not even occur to me to leave some 'space'
> for other things, and you are correct-- even in New York City, with its
> EXPENSIVE real-estate values, there are humble parking lots here and there. (At
> one time long ago, I lived and worked in NYC for about a year-- well, I lived
> way off in the less-expensive suburbs, ha.) And small parks would be good too,
> to add some much-needed color and 'humanity' to the city. (At one point, I
> thought of putting small 'gardens' on the ROOFS of some of the buildings; I
> might do that as well.)
> Good ideas!
Look at the trends in some cities to have indeed roof gardens, balcony
gardens (if you have a balcony) and even whole vegetated curtain walls.
Architecture nowadays is going green! ;-)
See e.g.: https://www.dezeen.com/features/green/
Date: 1 Oct 2020 17:00:06
Message: <web.5f7642e832341a55d98418910@news.povray.org>
> I think there is a fairly simple way [for collision detection], close to what
> Bill suggested, by
> placed to test collisions using the inside(O,V) function...
The inside(...) function-- that tool sounds really useful for this. I've
actually never used it before(!) Thanks, Thomas. Now I need to do some hard
thinking (ouch).
Btw, another major change/addition to my scene will be to divide the city into
'blocks', with streets going at right angles to each other. It will be a
challenge to implement, because my building-placement code as-is was written in
a way that will not easily allow it.
One problem at a time, ha.
Date: 1 Oct 2020 17:25:09
Message: <web.5f76481832341a554d00143e0@news.povray.org>
hi,
> > Bill suggested, by
> thinking (ouch).
I wrote a macro based on 'inside()' for the purpose (ie getting the smallest
"axis-aligned" bounding box), maybe it'll be of use.
<http://news.povray.org/web.5dc0bff634d8ef06feeb22ff0%40news.povray.org>
regards, jr.
Date: 1 Oct 2020 17:45:05
Message: <web.5f764cc232341a55d98418910@news.povray.org>
> The scene so far parses 'reasonably' quickly: For 650 buildings, with AA but no
> radiosity yet--  78 seconds total render time on my old Windows 7 machine (at
> 1600 X 900). The 'peak memory used' is about 1.1MB.
Duh. That should be 1.1 GB of memory, not MB. Sorry.
1000 buildings uses about 1.4GB
One trick that I learned long ago was to pre-#declare image_map pigments, when
they are going to be used repeatedly in a scene. That saves a whopping amount of
memory usage later.
Like,
#declare MY_PIGMENT = pigment{image_map{png "my_image.png" interpolate 2}}
#for(i,1,1000)
box{0,1 pigment{MY_PIGMENT} translate ...}
instead of...
#for(i,1,1000)
box{0,1 pigment{image_map{png "my_image.png" interpolate 2}}
translate ...}
