![](/i/fill.gif) |
Here's what you can do with it; IF you can rotate around an axis. I don't know
how in POV. vrotate() is not rotation(r,axis,pnt). If you cant, you need
triangulation.inc ... added centering option, and y adjust.
CamAng change, scale stays ...
right=up.eye
eye=right.up
up=eye.right
#declare campos = <0,80,-250>;
#declare cameye = vnormalize(<20,12,0>-campos);
#declare camup = <-1,1,0>;
#declare camright = vnormalize(vcross(camup,cameye));
#declare camup = vnormalize(vcross(cameye,camright));
#declare FontSize = 1.0;
#declare camang = 30;
location campos
right camright
up camup *(image_height/image_width)
direction cameye*(image_height/image_width)
angle camang
#include "transforms.inc"
#macro label(Text,objv,r,col,top,center,ydeg)
#local fl = 1/tan(radians(camang/2));
#local vl = vlength(objv-campos)/(fl*20);
#if (top)
#local pnt = camup*(r*1.05)+objv;
#else
#local pnt = -camup*(vl*FontSize+r)+objv;
#local eye = vnormalize(pnt-campos);
object {
text {
ttf "Arial.ttf" Text 1 0
texture { pigment { rgb col } finish { ambient 1 diffuse 0 } }
#if (center) translate -x*((strlen(Text)/2) * FontSize / (2*FontSize)) #end
scale vl*FontSize
#if (ydeg) rotate y* ydeg #end
Matrix_Trans(vnormalize(vcross(camup,eye)),camup,eye,pnt)
no_shadow
label("HELLO 162",<60,24,80>,48,<0.0196, 0.0196, 0.2156>,1,1,0)
label("Here are 492",y* 29.9,24*.8,<0.0196, 0.0196, 0.2156>,0,1,0)
#declare pnt = rotation(radians(camang/2.04),camup,cameye)*10+campos;
#declare d = 1;
#declare rowh = camang * 0.005;
label("Display Info 0",pnt,0,0,1,0,d)
label("Row 1",pnt,rowh * 1,0,1,0,d)
label("Row 2",pnt,rowh * 2,0,1,0,d)
label("Row 3",pnt,rowh * 3,0,1,0,d)
label("Row 4",pnt,rowh * 4,0,1,0,d)
label("Row 5",pnt,rowh * 5,0,1,0,d)
label("Row 1",pnt,rowh * 0,0,0,0,d)
label("Row 2",pnt,rowh * 1,0,0,0,d)
label("Row 3",pnt,rowh * 2,0,0,0,d)
label("Row 4",pnt,rowh * 3,0,0,0,d)
label("Row 5",pnt,rowh * 4,0,0,0,d)
label(concat("CamAng ",str(camang,0,0)),pnt,rowh * 5,0,0,0,d)
Download 'screeninfo.png' (229 KB)
Preview of image 'screeninfo.png'
![screeninfo.png](/povray.binaries.images/attachment/%3Cweb.5e25661a28c763ef9da690110%40news.povray.org%3E/screeninfo.png?ttop=435905&toff=150&preview=1)
![](/i/fill.gif) |
![](/i/fill.gif) |
if u changed ydeg to zdeg,
auto tilt-correction for left-side display,
might look something like this.
#macro drwtext()
#local pnt = rotation(radians(camang/2.04),camup,cameye)*10+campos;
#local rowh = camang * 0.0036;
#declare FontSize = .8;
#local s = array[4] {
concat("Azimuth ",str(360-rascension(cameye),0,2)),
concat("Declination ",str(declination(cameye),0,2)),
concat("CamAng ",str(camang,0,1)),
concat("Time ",date("%H:%M:%S"))
#local strtn = 1; // start negative
#local i = -strtn;
#while (i < 3)
#local d = (i*-0.5 - 0.5)*(camang/80);
label(s[i+strtn],pnt,rowh * i,0,0,0,d)
#local i = i+1;
![](/i/fill.gif) |
