![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Alain Martel <kua### [at] videotron ca> wrote:
> > Your cloud do have some great properties. Although it is unexpected simple(the
> > pov-code). The fluffy appearance is what I want. And the coverage is moderate.
> > But in fact the real geometry shows the top and bottom are truncated by the
> > boundary(800m~1200m). I will think how to solve this in the future, but if you
> > have idea I think it will be nice.
> You may use a planar pattern to hide that. Just scale and translate it
> properly, and add a map or use an alternate wave type to control how it
> need to fade near the container's edges.
How do you combine these two(The original and the planar pattern)? I can't spend
time to try it right now, but I wish to look your code (even a simple example).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I think the planar (or equivalent) pattern can be used as an additional density
function (that will multiply with the main one). I did use this for some other
clouscapes atempts.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> clouscapes atempts.
Multiply is a straightforward idea that combine these functions. I have doubts
about it because it seem change the original pattern (unnatural) ....but I
hardly ever try it. You said that you have used it. Is the effect fine?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> clouscapes atempts.
The planar pattern start at 1 on the X-Z plane and drop to zero 1 unit
above and under it.
There is no distortion involved.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Op 19/12/2019 om 23:27 schreef Alain Martel:
>>>>>> is moderate.
>>>>>> truncated by the
>>>>>> future, but if you
>>>>> how it
>>>> can't spend
>>>> simple example).
>>> additional density
>>> some other
>>> clouscapes atempts.
>> have doubts
>> ....but I
> above and under it.
Also, do not forget the spherical and boxed patterns which work
according to the same principles as planar!! I use them regularly for
atmospheric or cloudscape business.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
simple(the
moderate.
you
> > clouscapes atempts.
I once could get this, and IIRC, the truncation was mitigated with such a
function. Alas, I lost the code after a USB stick corruption. But the principle
seems OK, provided the parameters are properly tweaked (tricky).
B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
simple(the
moderate.
the
you
spend
example).
> > > clouscapes atempts.
> B.
Thank you.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> clouscapes atempts.
> B.
Lesson :
Backup !
NEVER EVER leave your code and ANY important file in only one location.
Backup !
Several partitions on a single drive is still only a single location.
Backup !
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
hi,
> > Alas, I lost the code after a USB stick corruption. ...
> Lesson :
> Backup !
> Backup !
> Backup !
just to say, I agree with Alain, 100%, right down to the exclamation marks.
and will add that, ime, the "human" fallibility has to be allowed for,
therefore, always automate the back up. (mine run in the small hours, every
night)
regards, jr.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
simple(the
moderate.
you
spend
> >>> clouscapes atempts.
> > B.
> Lesson :
> Backup !
> Backup !
> Backup !
Believe me, I know very well about backup!! In this case, I was on vacation and
the code was on a usb. I used someone else's PC.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
