POV-Ray : Newsgroups : povray.binaries.images : cf alpha freeze Server Time
26 Jan 2026 08:26:05 EST (-0500)
  cf alpha freeze (Message 1 to 6 of 6)
Subject: cf alpha freeze
Date: 4 Dec 2019 04:40:00
Message: <web.5de77d609f95edabfeeb22ff0@news.povray.org>
"using the pigment as shown, I get the single decal but the other texture has
turned transparent and the droid looks like a weird mix of glass and (white)
emissive media."
<http://news.povray.org/povray.bugreports/message/%3Cweb.5de6653248df159ffeeb22ff0%40news.povray.org%3E/#%3Cweb.5de6653
248df159ffeeb22ff0%40news.povray.org%3E>
for this image I scaled the decal down to show the effect.  it looks like much
of the 'finish{}' survives in 3.7.1, just not the colour.
Download 'a371.png' (107 KB)
Preview of image 'a371.png'
Subject: Re: cf alpha freeze
Date: 4 Dec 2019 09:01:55
Message: <5de7bc53$1@news.povray.org>
> emissive media."
That droid obviously have an interior that set an IOR. We see a fair
amount of total internal reflection.
When applying a decal, you should layer it over some other texture.
#declare textureWithDecal
texture{SomeBaseTexture}
texture{pigment{image_map png"Decal"once}}
Date: 4 Dec 2019 12:15:02
Message: <web.5de7e88ca76050e4feeb22ff0@news.povray.org>
hi,
> > emissive media."
> > ... > > for this image I scaled the decal down to show the effect.  it looks like
much
in the eye glass, the only other ior I found is used in the ground plane!
(unsure why)
thanks.  I opted (before reading your post) for a second, transparent cylinder
with the decal, and union'd with the body.  for now I haven't used a texture
keyword.  will have to play some more with different arrangements, perhaps
modify the Android code.
regards, jr.
Date: 5 Dec 2019 14:30:50
Message: <5de95aea$1@news.povray.org>
> emissive media."
It's not just internal reflections; the individual parts used to
construct the CSG are being reflected.  Try a merge rather than a union:
   AndroidRobot_Posed (yes, HeadRotate, LArmRotate, RArmRotate,
   LLegRotate, RLegRotate)
Date: 5 Dec 2019 20:14:26
Message: <5de9ab72$1@news.povray.org>
> hi,
>>> emissive media."
much
> (unsure why)
Setting an IOR is needed when you want to use fresnel reflection. Check
the finish of that plane. My bet is that you'll find something like :
finish{ reflection{ 1 fresnel } SomeOtherFinishComponent }
With no IOR set, it default to 1, witch effectively kill any reflection.
> regards, jr.
A texture{} contain a pigment and a finish, and possibly a normals
statement.
When you use a naked pigment or finish, you effectively apply the
default finish along with the pigment, and the default pigment with the
finish unless you also define the other.
Date: 6 Dec 2019 11:00:02
Message: <web.5dea7ad9a76050e4feeb22ff0@news.povray.org>
hi,
> >>> emissive media."
like much
> > (unsure why)
and you won.  :-)  used for the eyes only though, afaics.
thanks.  asides like this are so valuable, even if they don't always "sink in"
at first.
Cousin Ricky:
yes, like a .. cuddly version of the infamous T1000.  :-)  will try a merge, in
fact, will probably end up reusing chunks of your code but modified to suit.
regards, jr.
