3.63 CONSOLE available, its in utilities.
http://news.povray.org/povray.binaries.utilities/thread/%3Cweb.5dd8c7be237dc3209da690110%40news.povray.org%3E/
had to test it
Download 'cylinder4.png' (69 KB)
Preview of image 'cylinder4.png'
a.bat
path %PATH%;c:\povray\scenes\camera
start cmd /e:8192 /c c:\povray\bin\povray.exe a.ini
THERE IT is, working! admin priv not needed.
all I know is, no bat file would run on win7,
files that used to run fine before.
command, went to cmd, doh.
"Melody" <nomail@nomail> wrote:
> a.bat
ImageMagick-7.0.9-5-portable-Q16-x86.zip (no dlls) result fail
C:\povray\scenes3\planetarium>composite -stereo pld_earth02R.png
composite: InvalidArgument '-stereo': pld_earth02R.png @
error/composite.c/CompositeImageCommand/1424.
IT IS NOT invalid arg DUH .... bloody hell
ImageMagick-6.3.7-2-Q16-windows-dll.exe
works fine
path to imagMagick was installed to system path.
console path is the scene files
anaglyph
composite.bat
path %PATH%;c:\povray\scenes3\planetarium
Download 'pld_earth02a.png' (508 KB)
Preview of image 'pld_earth02a.png'
not a great 3d scene,
just a test file to get it working again
> composite.bat
dont name it composite.bat and try to run it ... ... lol
anything but that.
; Composite stereo pairs to create an anaglyph
Post_Frame_Command="composite -stereo %sR.png %sL.png %sA.png"
only works with a 7 letter filename.
Console shortens stereo pairs to 7R and 7L = 8
apparently %s wasn't enlightened of the filename change.
; 3.63 2009 - in win7
; pvengine.exe, APPARENTLY POST COMMAND TO SHELL FUXORD FOR WIN7. WORKED IN
WIN98.
; seeks something not found or freezes. no Fatal_Error_Return=Q event. run
post.bat manually.
; povray.exe CONSOLE OK - Scene or Frame shell succeeds.
I'm not really sure what you're about now, but I've used POV 3.7 on Win 7 and
nowadays on Win 10 without any problems. The last time I remember making .bat
files was with POV 2.2 back in the day. :D
PS. My point being, I don't really get it why to use any older versions of POV
when the latest stable build works just fine.
before my time 2.2
stereo camera, motion blur, glow in 3.7?
compatible with what already exists?
make you put files where you dont want them?
and when F1 failed here, I'd had enough its antics.
enchantment missing, buried in issues.
hollow empty feeling.
delicacy of sensibility that progress becomes.
batch files run post image commands. but there were changes in OS upgrades that
failed previous work.
even pvengine wont shell in win7. That is not its fault. good thing for batch
files to save the day. but the console will, yea.
or lets just delete the past.
apparently for good reason that previous versions stick around.
