POV-Ray : Newsgroups : povray.binaries.images : The Superellipsoidal Brain Server Time
2 Jul 2024 22:04:46 EDT (-0400)
  The Superellipsoidal Brain (Message 3 to 12 of 12)
<<< Previous 2 Messages Goto Initial 10 Messages
Subject: Re: The Superellipsoidal Brain
Date: 15 Jan 2019 21:55:01
Message: <web.5c3e9c663a551e31264be49d0@news.povray.org>
"And" <49341109@ntnu.edu.tw> wrote:
> Very pretty.
Thank you And !
Tor Olav
http://subcube.com
Date: 15 Jan 2019 23:25:01
Message: <web.5c3eb1113a551e31765e06870@news.povray.org>
"Tor Olav Kristensen" <tor### [at] TOBEREMOVEDgmailcom> wrote:
> Here's an image I made a while ago.
> All
> these superellipsoids were made with a single isosurface statement.
Whoa!
That's pretty cool!  :)
Have you tried experimenting with making them "supershapes"?
Good to see you dropping in, and dropping more mind-bending [sic] projects on
us.
May 2019 see many more   :)
Date: 16 Jan 2019 02:04:06
Message: <XnsA9D952139821Aseed7@news.povray.org>
in news:web.5c3e1168d8b92d66a09309da0@news.povray.org Tor Olav Kristensen
Oh yes. A fossilised amber brain.
ingo
Date: 16 Jan 2019 04:19:24
Message: <5c3ef71c$1@news.povray.org>
Tor Olav Kristensen wrote on 15/01/2019 18:06:
> I got the data for the brain from Paul Bourke's file mri.df3, that can be found
> in the file mri.tar.gz available at this page:
> http://paulbourke.net/miscellaneous/povexamples/
> All the voxels with a density above a certain threshold are filled with a
> superellipsoid with a color corresponding to the density in each voxel. All
> The colors were borrowed from the Inferno color map in Matplotlib:
> https://matplotlib.org/examples/color/colormaps_reference.html
> Tor Olav
> http://subcube.com
The discrete state of thinking... a nice image,
  Paolo
Date: 16 Jan 2019 06:55:01
Message: <web.5c3f1a9f3a551e311fbfafc10@news.povray.org>
> Tor Olav
> http://subcube.com
Much better than my own approach to depict mri scans.
How did you remove bones, eyes etc.?
Norbert
Download 'self-image5a.jpg' (602 KB)
Preview of image 'self-image5a.jpg'
Date: 18 Jan 2019 19:20:01
Message: <web.5c426ca33a551e31264be49d0@news.povray.org>
> > All
> Whoa!
Thank you Bill !
I had forgotten about the supershapes, so I searched for them
- and ended up at one of Paul Bourke's web pages again:
http://paulbourke.net/geometry/supershape/
I see now that there's two files there that I've made; ss_macro1.inc &
example1.pov
- So apparently I have been experimenting with them once...
It seems that they are commonly made with parametric meshes. Perhaps it is
possible to model some of them as isosurfaces. But that would be very slow, so I
think I'll wait some years (for more computing power) before looking into that.
> us.
For a long while I have not had much time to work with POV-Ray, so I hope that I
will have more time for it soon.
Tor Olav
http://subcube.com
Date: 18 Jan 2019 19:30:00
Message: <web.5c426f143a551e31264be49d0@news.povray.org>
Hehe, you're right, it looks like amber. I hadn't thought about that.
- Then maybe there's some insects somewhere within it...
Tor Olav
http://subcube.com
Date: 18 Jan 2019 19:40:01
Message: <web.5c4270dc3a551e31264be49d0@news.povray.org>
Yes, that would be a very good title for it.
I'm glad you like it.
Tor Olav
http://subcube.com
Date: 18 Jan 2019 20:10:01
Message: <web.5c4278043a551e31264be49d0@news.povray.org>
I really like the way you have arranged the glass sheets and how the light
escapes at their edges.
BTW: Where did you find the MRI-data for this ?
Luckily I did not have to deal with that. It had already been done, so the
DF3-file only contains the brain.
A while ago I made some (not very successful) attempts at filtering the data (in
Python) for a CT-scan according to a range of Hounsfield units for bone:
https://en.wikipedia.org/wiki/Hounsfield_scale
IIRC the problem was that the range for the bones overlapped the range for some
other tissue. (It might be that it wasn't a high quality scan.) I suspect that
they now use quite advanced techniques to isolate the different organs. I would
guess that some techniques find "gradient surfaces" in the data.
Tor Olav
http://subcube.com
Date: 18 Jan 2019 21:40:00
Message: <web.5c428dd13a551e31765e06870@news.povray.org>
> example1.pov
I did it in 8/2017 with isosurfaces, so I would imagine you could do an
approximation of some sort to speed it up.
Here's my see-them-all scene if you wanted some code to to run a quick test
scene:
#version 3.71;
global_settings {
 assumed_gamma 1.0
#declare m  =  7;  // number of lobes
#declare n1 =  5;
#declare n2 =  5;
#declare n3 =  5;
#declare a  =  1;
#declare b  =  1;
#declare M = 10;  // iterations
#declare AL = 20;
#declare L = 0.05;
cylinder {<-AL*4, 0, 0>, <AL*4, 0, 0>, L pigment {Red} no_shadow}
cylinder {<0, -AL*4, 0>, <0, AL*4, 0>, L pigment {Green} no_shadow}
cylinder {<0, 0, -AL*4>, <0, 0, AL*4>, L pigment {Blue} no_shadow}
  location <M*4, 0, -75>
  look_at  <0, 0, 0>
  up 1*y
#declare LS = <M*4, M*2, -100>;
light_source {LS color White}
cylinder {LS, <0, 0, 0>, 0.01 pigment {White} no_shadow}
#declare CB = 4;
#for (n1, 1, M)
 #for (n2, 1, M)
  #for (m, 1, M)
   isosurface {
    function {
     pow (
      pow (abs (cos (0.25 * m * acos (y/sqrt(x*x+y*y)) * abs(y)/y) / a), n2)  +
      pow (abs (sin (0.25 * m * acos (y/sqrt(x*x+y*y)) * abs(y)/y) / b), n3)
      , (1/n1)
     //* sqrt (x*x+y*y) - 1 }
     * sqrt ((x*x)+(y*y)+(z*z)) - 1
        contained_by { box { <-CB, -CB, -CB>, <CB, CB, CB> } }
        accuracy 0.01
        max_gradient 12
        scale <1, 1, 1>
        #declare Hue = m * (360/M);
        texture {pigment {color CHSV2RGB (rgb <Hue, 1, 1>)} finish {specular
0.2}}
        translate -x*M
        translate  x*m*3
        translate  y*M
        translate -y*n2*3
        translate -z*M
        translate  z*n1*3
  #end // end for m
 #end // end for n2
#end // end for n1
