POV-Ray : Newsgroups : povray.binaries.images : Spiral Honeycomb Mosaic Progress Server Time
26 Jan 2026 13:41:29 EST (-0500)
  Spiral Honeycomb Mosaic Progress (Message 1 to 7 of 7)
Subject: Spiral Honeycomb Mosaic Progress
Date: 2 Nov 2018 15:25:01
Message: <web.5bdca3898f0be1adfd6b6fe10@news.povray.org>
Now with a coordinate system...
The coordinates are actually calculated based on the order the tiles are placed.
 I can't take credit for the method, but figuring out the notation was an
adventure.
https://gamedev.stackexchange.com/questions/71785/converting-between-spiral-honeycomb-mosaic-and-axial-hex-coordinates
The coordinate system is called Cube Coordinates. It's basically a 3D coordinate
system projected on a 2D plane.
Green = x
Red   = y
Blue  = z
I'm still trying to work out how the reverse conversion works.
A.D.B.
Download 'shm_2018-6.png' (86 KB)
Preview of image 'shm_2018-6.png'
Subject: Re: Spiral Honeycomb Mosaic Progress
Date: 3 Nov 2018 10:32:32
Message: <5bddb180@news.povray.org>
Reminds me for the map of a computer game. :-)
http://www.avg.com
Date: 3 Nov 2018 10:32:34
Message: <5bddb182@news.povray.org>
http://www.avg.com
Date: 4 Nov 2018 05:50:00
Message: <web.5bdecde053b393dcaa3b06300@news.povray.org>
If you don't already know this site, I recommend it to you. It's my definite
reference for hexagonal grids:
https://www.redblobgames.com/grids/hexagons/
> adventure.
s
> Green = x
> Red   = y
> Blue  = z
> Regards,
> A.D.B.
Date: 4 Nov 2018 07:10:09
Message: <5bdee1a1@news.povray.org>
Impressive. Now, what would it take to make hexagonal, seamless,
height_fields? In POV-Ray?
At the moment, I make seamless height_fields with the help of
GeoControl, which is able to turn out seamless, square,  tga maps.
Making hexagonal ones would be a challenge I suppose. Are there
applications that are able to do this?
Date: 4 Nov 2018 15:25:01
Message: <web.5bdf546e53b393dcfd6b6fe10@news.povray.org>
> Thomas
Once I get the reverse lookup function working, I'll be able to convert freely
between the index of each hexagon and it's location in cube-space. At that
point, I'll be able to create landscapes using Cellular Automata.
Making a height map might not be a good idea as sharp transitions tend not to
render well in my experience, but I could use tiles and just scale them
vertically.
The only problem I foresee with the reverse lookup is that it uses a matrix
transform which I'm unsure about how to implement in PoV SDL. That is, without
implementing a matrix math macro library.
A.D.B.
Date: 6 Nov 2018 04:29:05
Message: <5be15ee1$1@news.povray.org>
Am 04.11.2018 um 21:19 schrieb Anthony D. Baye:
Implement it as a matrix transform, and make use of the `vtransform()`
function?
You wouldn't even need to figure out the inverse transform matrix
yourself; just make use the `inverse` keyword.
