Hi all,
I try to improve Pycao with some tools to handle objects and textures more
efficiently. Here are two images of what I can get by now. The first image
requires around 100 lines of python code (using the library), and the second
around 40 lines (using predefined wood stubs).
Download 'pycaooutput.png' (414 KB)
Preview of image 'pycaooutput.png'
The cabinet:
Download 'meuble.png' (342 KB)
Preview of image 'meuble.png'
With some textures added. Still need to work on the doors.
Download 'pycaooutput.png' (2316 KB)
I have a small problem with your wooden doors : I've never seen any
wooden door that rounded, ever.
You could use simple box for them.
If you really want to use rounded boxes, you need to drastically reduce
the radius of the round parts. Like reducint the radius used by a factor
of about 20..50.
Thank you for the comment. Yes, you are right, i like rounded corners but this
is too much. Here is a new attempt.
Download 'pycaooutput.png' (1401 KB)
And a new version of the cabinet, with the grain of the wood now with the
correct orientation.
Download 'pycaooutput.png' (913 KB)
