Norbert Kern wrote on 13/03/2018 12:53:
> Paolo Gibellini <p.g### [at] gmailcom> wrote:
>> A significant scene.
>> Paolo
> Many thanks, Paolo.
> When will we see some new images from you?
> Norbert
Ha! You are right...
I've changed somehow my job and the pov-time has been absorbed into the
new tasks, but I have not stopped putting aside new ideas.
Before the end of the spring I should be able to post something.
Paolo
Alain <kua### [at] videotronca> wrote:
> Using intervals 1 and tripling the samples value would have been much
> faster.
> You ONLY use intervals >1 when using method 1 or 2, never ever with
> method 3 (default).
> It probably have taken less than a day using intervals 1 and 10 times as
> many samples.
You are right with the intervals 1 issue.
If it wasn't a Gilles Tran code, i'ld have checked more carefully...
Meanwhile I rendered with intervals 1 and samples 70.
It's not faster, but the result is slightly better.
Norbert
"s.day" <s.d### [at] uelacuk> wrote:
> Wow, this is an amazing scene. Making me want to dust off my povray skills (hope
> I haven't forgotten too much).
> Sean
Hi Sean,
it's time to come back...
Norbert
William F Pokorny <ano### [at] anonymousorg> wrote:
> Ah, I see now too Gilles did have it there. Thanks.
> I got a couple small renders done yesterday - with and without the
> emission - and compared them. At a high level adding in emission the
> color of the background sky makes the clouds look as if they are sitting
> in a hazy atmosphere without having modeled the hazy atmosphere. See the
> attached image.
> The difference image on the right shows an aspect or pitfall of the
> method - depending on one's goal I suppose. Once one or more color
> channels for the media 'interval' being sampled is maxed out (Red here),
> you get a 'disjoint' color-hue change in the media due the emission
> adder.
> > I remember your image - very impressive.
> Thanks - though I certainly don't play in your artistic league. :-)
> Bill P.
Interesting. I wouldn't have thought the effect of small emission value is that
strong. I've to do more tests...
Norbert
>> Sean
> Hi Sean,
> Norbert
Seconded!
Regards
Mike Horvath <mik### [at] gmailcom> wrote:
> Wow, very nice! I like the poofy-yet-hazy clouds and the grass especially.
> Mike
Thanks Mike,
the grass is an old mesh I used in my "boreal" image
(http://hof.povray.org/Boreal_big.html). Here I subdivided the mesh via PoseRay
-a very useful tool.
The 8 bit heightfield was enhanced by the method of Jaimes Vives Piqueres to get
a more detailed HF map
(http://www.ignorancia.org/en/index.php?page=Heightfield_based_Isosurfaces).
Norbert
"Norbert Kern" <nor### [at] t-onlinede> wrote:
> a comment on the present conditio humana.
> Norbert
Nicely done! I salute you :D
Dan
roadkillpuppy.com
>> attached image.
>> adder.
> Norbert
Sorry slow - busy with real life.
Emission is stronger by nature because the emission intensity increases
with depth of media. If you want to 'sort of' match a scattering
intensity with an emission media, you have to add absorption at about
the same value as the emissive value (1).
I've always used scattering+absorption, emission+absorption or
emission+scattering. Never all three - intentionally at least - as
Gilles did here (2).
Bill P.
(1) - An idea on my to play with list is some method to pre-render or
pre-calculate scattering with attenuation media so as to be able to
create a faster emission+absorption or a scattering without attenuation
+ absorption media model for use in follow-on renders.
(2) - I've wondered some recently about whether POV-Ray should support
two absorption specifications given Gilles technique looks useful.
Thanks for running again this way and reporting the speed! Your result
lines up with my recent experience and what I see in the media code as
I've been trying to digest it. In the code, intervals and samples end up
both combining to drive the number of initial samples taken.
If you need 70 initial samples to resolve the smaller/rapid changes in
your cloud or your shadows - you need them - no matter the intervals /
samples combination to get them and the performance won't be much
different due the initial specification. In some ways needing a higher
number of initial samples with a media is like needing a high
max_gradient value with isosurfaces due the function used.
In any case, intervals 1 is the way to go with method 3 for quality
always - and often enough the 'density/shadow function' will be such
that the adaptive method 3 with intervals 1 and a low samples setting is
much, much faster.
Bill P.
>>> attached image.
>>> adder.
>> value is that
>> Norbert
> Bill P.
Aha! This is an interesting notion I was not aware of. I am going to
follow that up. Thanks!
